A description of the outline of a a cartographic rectangle on an ellipsoid centered at the origin.
| Name | Type | Description | ||||||||||||||||||||||||||||
options |
object |
Throws:
- RectangleOutlineGeometry#createGeometry
const rectangle = new Cesium.RectangleOutlineGeometry({
ellipsoid : Cesium.Ellipsoid.WGS84,
rectangle : Cesium.Rectangle.fromDegrees(-80.0, 39.0, -74.0, 42.0),
height : 10000.0
const geometry = Cesium.RectangleOutlineGeometry.createGeometry(rectangle);
static Cesium.RectangleOutlineGeometry.createGeometry(rectangleGeometry) → Geometry|undefined
Computes the geometric representation of an outline of a rectangle, including its vertices, indices, and a bounding sphere.
rectangleGeometry |
RectangleOutlineGeometry | A description of the rectangle outline. |
The computed vertices and indices.
Throws:
DeveloperError : Rotated rectangle is invalid.
value |
RectangleOutlineGeometry | The value to pack. | |
array |
Array.<number> | The array to pack into. | |
startingIndex |
number |
0
optional The index into the array at which to start packing the elements. |
static Cesium.RectangleOutlineGeometry.unpack(array, startingIndex, result) → RectangleOutlineGeometry
array |
Array.<number> | The packed array. | |
startingIndex |
number |
0
optional The starting index of the element to be unpacked. |
result |
RectangleOutlineGeometry | optional The object into which to store the result. |
The modified result parameter or a new RectangleOutlineGeometry instance if one was not provided.
