TileMapServiceImageryProvider
new Cesium.TileMapServiceImageryProvider(options)
To construct a TileMapServiceImageryProvider, call TileMapServiceImageryProvider.fromUrl. Do not call the constructor directly.
An imagery provider that provides tiled imagery as generated by MapTiler, GDAL2Tiles, etc.
options TileMapServiceImageryProvider.ConstructorOptions optional Object describing initialization options
const tms = await Cesium.TileMapServiceImageryProvider.fromUrl(
   "../images/cesium_maptiler/Cesium_Logo_Color", {
     fileExtension: 'png',
     maximumLevel: 4,
     rectangle: new Cesium.Rectangle(
       Cesium.Math.toRadians(-120.0),
       Cesium.Math.toRadians(20.0),
       Cesium.Math.toRadians(-60.0),
       Cesium.Math.toRadians(40.0))
Extends
Inherited From:
Default Value: undefined
Gets or sets a value indicating whether feature picking is enabled. If true, UrlTemplateImageryProvider#pickFeatures will request the options.pickFeaturesUrl and attempt to interpret the features included in the response. If false, UrlTemplateImageryProvider#pickFeatures will immediately return undefined (indicating no pickable features) without communicating with the server. Set this property to false if you know your data source does not support picking features or if you don't want this provider's features to be pickable.
Inherited From:
Default Value: true
Inherited From:
Inherited From:
Default Value: true
Gets the maximum level-of-detail that can be requested, or undefined if there is no limit.
Inherited From:
Inherited From:
Default Value: 0
Gets the URL template to use to use to pick features. If this property is not specified, UrlTemplateImageryProvider#pickFeatures will immediately return undefined, indicating no features picked. The URL template supports all of the keywords supported by the UrlTemplateImageryProvider#url property, plus the following:
  • {i}: The pixel column (horizontal coordinate) of the picked position, where the Westernmost pixel is 0.
  • {j}: The pixel row (vertical coordinate) of the picked position, where the Northernmost pixel is 0.
  • {reverseI}: The pixel column (horizontal coordinate) of the picked position, where the Easternmost pixel is 0.
  • {reverseJ}: The pixel row (vertical coordinate) of the picked position, where the Southernmost pixel is 0.
  • {longitudeDegrees}: The longitude of the picked position in degrees.
  • {latitudeDegrees}: The latitude of the picked position in degrees.
  • {longitudeProjected}: The longitude of the picked position in the projected coordinates of the tiling scheme.
  • {latitudeProjected}: The latitude of the picked position in the projected coordinates of the tiling scheme.
  • {format}: The format in which to get feature information, as specified in the GetFeatureInfoFormat.
Inherited From:
Inherited From:
Inherited From:
Default Value: tilingScheme.rectangle
Inherited From:
Inherited From:
Default Value: 256
Inherited From:
Default Value: 256
Inherited From:
Default Value: new WebMercatorTilingScheme()
Gets the URL template to use to request tiles. It has the following keywords:
  • {z}: The level of the tile in the tiling scheme. Level zero is the root of the quadtree pyramid.
  • {x}: The tile X coordinate in the tiling scheme, where 0 is the Westernmost tile.
  • {y}: The tile Y coordinate in the tiling scheme, where 0 is the Northernmost tile.
  • {s}: One of the available subdomains, used to overcome browser limits on the number of simultaneous requests per host.
  • {reverseX}: The tile X coordinate in the tiling scheme, where 0 is the Easternmost tile.
  • {reverseY}: The tile Y coordinate in the tiling scheme, where 0 is the Southernmost tile.
  • {reverseZ}: The level of the tile in the tiling scheme, where level zero is the maximum level of the quadtree pyramid. In order to use reverseZ, maximumLevel must be defined.
  • {westDegrees}: The Western edge of the tile in geodetic degrees.
  • {southDegrees}: The Southern edge of the tile in geodetic degrees.
  • {eastDegrees}: The Eastern edge of the tile in geodetic degrees.
  • {northDegrees}: The Northern edge of the tile in geodetic degrees.
  • {westProjected}: The Western edge of the tile in projected coordinates of the tiling scheme.
  • {southProjected}: The Southern edge of the tile in projected coordinates of the tiling scheme.
  • {eastProjected}: The Eastern edge of the tile in projected coordinates of the tiling scheme.
  • {northProjected}: The Northern edge of the tile in projected coordinates of the tiling scheme.
  • {width}: The width of each tile in pixels.
  • {height}: The height of each tile in pixels.
Inherited From:
readonly urlSchemeZeroPadding : object
Gets the URL scheme zero padding for each tile coordinate. The format is '000' where each coordinate will be padded on the left with zeros to match the width of the passed string of zeros. e.g. Setting: urlSchemeZeroPadding : { '{x}' : '0000'} will cause an 'x' value of 12 to return the string '0012' for {x} in the generated URL. It has the following keywords:
  • {z}: The zero padding for the level of the tile in the tiling scheme.
  • {x}: The zero padding for the tile X coordinate in the tiling scheme.
  • {y}: The zero padding for the the tile Y coordinate in the tiling scheme.
  • {reverseX}: The zero padding for the tile reverseX coordinate in the tiling scheme.
  • {reverseY}: The zero padding for the tile reverseY coordinate in the tiling scheme.
  • {reverseZ}: The zero padding for the reverseZ coordinate of the tile in the tiling scheme.
Inherited From:
static Cesium.TileMapServiceImageryProvider.fromUrl(url, options)Promise.<TileMapServiceImageryProvider>
Creates a TileMapServiceImageryProvider from the specified url.
url Resource | string Path to image tiles on server.
options TileMapServiceImageryProvider.ConstructorOptions optional Object describing initialization options.
A promise that resolves to the created TileMapServiceImageryProvider.
Throws:
  • RuntimeError : Unable to find expected tilesets or bbox attributes in tilemapresource.xml
  • RuntimeError : tilemapresource.xml specifies an unsupported profile attribute
   '../images/cesium_maptiler/Cesium_Logo_Color', {
     maximumLevel: 4,
level number The tile level;
Inherited From:
pickFeatures(x, y, level, longitude, latitude)Promise.<Array.<ImageryLayerFeatureInfo>>|undefined
Asynchronously determines what features, if any, are located at a given longitude and latitude within a tile.
level number The tile level.
A promise for the picked features that will resolve when the asynchronous picking completes. The resolved value is an array of ImageryLayerFeatureInfo instances. The array may be empty if no features are found at the given location. It may also be undefined if picking is not supported.
Inherited From:
requestImage(x, y, level, request)Promise.<ImageryTypes>|undefined
Inherited From:
Type Definitions
Cesium.TileMapServiceImageryProvider.ConstructorOptions
Initialization options for the TileMapServiceImageryProvider constructor
Properties:
fileExtension string <optional>
'png' The file extension for images on the server.
'' A credit for the data source, which is displayed on the canvas.
minimumLevel number <optional>
0 The minimum level-of-detail supported by the imagery provider. Take care when specifying this that the number of tiles at the minimum level is small, such as four or less. A larger number is likely to result in rendering problems.
The maximum level-of-detail supported by the imagery provider, or undefined if there is no limit.
Rectangle.MAX_VALUE The rectangle, in radians, covered by the image.
tilingScheme TilingScheme <optional>
The tiling scheme specifying how the ellipsoidal surface is broken into tiles. If this parameter is not provided, a WebMercatorTilingScheme is used.
The ellipsoid. If the tilingScheme is specified, this parameter is ignored and the tiling scheme's ellipsoid is used instead. If neither parameter is specified, the WGS84 ellipsoid is used.
tileWidth number <optional>
256 Pixel width of image tiles.
tileHeight number <optional>
256 Pixel height of image tiles.
flipXY boolean <optional>
Older versions of gdal2tiles.py flipped X and Y values in tilemapresource.xml.
tileDiscardPolicy TileDiscardPolicy <optional>
A policy for discarding tile images according to some criteria Specifying this option will do the same, allowing for loading of these incorrect tilesets.
