UrlTemplate3DTilesDataProvider
Base provider for URL-template vector sources that are rendered through a runtime-generated 3D Tiles tileset.
new Cesium.UrlTemplate3DTilesDataProvider(urlTemplate, options)
urlTemplate Resource | string URL template containing {z}, {x}, and {y} placeholders.
options object optional Provider options.
Name Type Default Description
minZoom number 0 optional Minimum zoom level represented in the generated tileset.
maxZoom number 14 optional Maximum zoom level represented in the generated tileset.
extent Rectangle optional Optional geographic extent in radians to constrain the generated tile tree.
featureIdProperty string optional Feature property name to use as feature ID when supported by content decoding.
heightReference HeightReference optional Drapes the vector content onto the surfaces selected by the value. Requires options.scene.
scene Scene optional The scene the generated tileset is rendered in, required when options.heightReference is a clamping value.
Experimental
Optional geographic extent in radians used to generate tile headers.
Resource derived from the URL template.
Determines if the generated tileset is shown.
Backing 3D Tileset.
URL template containing {z}/{x}/{y}.
async static Cesium.UrlTemplate3DTilesDataProvider.fromUrl(url, options) → Promise.<UrlTemplate3DTilesDataProvider>
Creates a provider from a URL template.
url Resource | string URL template containing {z}, {x}, and {y} placeholders.
_tileset Cesium3DTileset
Subclasses must return a runtime content codec describing how to turn a downloaded tile payload into a Cesium3DTileContent. See Cesium3DTileset#_runtimeContentCodec for the expected shape.
protected _createTilesetLoadOptions() → object
