ClippingPlaneCollection
new Cesium.ClippingPlaneCollection(options)
Specifies a set of clipping planes. Clipping planes selectively disable rendering in a region on the outside of the specified list of ClippingPlane objects for a single gltf model, 3D Tileset, or the globe.
In general the clipping planes' coordinates are relative to the object they're attached to, so a plane with distance set to 0 will clip through the center of the object.
For 3D Tiles, the root tile's transform is used to position the clipping planes. If a transform is not defined, the root tile's Cesium3DTile#boundingSphere is used instead.
Name Type Default Description
planes Array.<ClippingPlane> [] optional An array of ClippingPlane objects used to selectively disable rendering on the outside of each plane.
enabled boolean true optional Determines whether the clipping planes are active.
modelMatrix Matrix4 Matrix4.IDENTITY optional The 4x4 transformation matrix specifying an additional transform relative to the clipping planes original coordinate system.
unionClippingRegions boolean false optional If true, a region will be clipped if it is on the outside of any plane in the collection. Otherwise, a region will only be clipped if it is on the outside of every plane.
edgeColor Color Color.WHITE optional The color applied to highlight the edge along which an object is clipped.
edgeWidth number 0.0 optional The width, in pixels, of the highlight applied to the edge along which an object is clipped.
// This clipping plane's distance is positive, which means its normal
// is facing the origin. This will clip everything that is behind
// the plane, which is anything with y coordinate < -5.
const clippingPlanes = new Cesium.ClippingPlaneCollection({
    planes : [
        new Cesium.ClippingPlane(new Cesium.Cartesian3(0.0, 1.0, 0.0), 5.0)
// Create an entity and attach the ClippingPlaneCollection to the model.
const entity = viewer.entities.add({
    position : Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, 10000),
    model : {
        uri : 'model.gltf',
        minimumPixelSize : 128,
        maximumScale : 20000,
        clippingPlanes : clippingPlanes
viewer.zoomTo(entity);
Demo:
Default Value: Color.WHITE
Default Value: 0.0
If true, clipping will be enabled.
Default Value: true
Returns the number of planes in this collection. This is commonly used with ClippingPlaneCollection#get to iterate over all the planes in the collection.
Default Value: Matrix4.IDENTITY
An event triggered when a new clipping plane is added to the collection. Event handlers are passed the new plane and the index at which it was added.
An event triggered when a new clipping plane is removed from the collection. Event handlers are passed the new plane and the index from which it was removed.
Default Value: false
Adds the specified ClippingPlane to the collection to be used to selectively disable rendering on the outside of each plane. Use ClippingPlaneCollection#unionClippingRegions to modify how modify the clipping behavior of multiple planes.
plane ClippingPlane The ClippingPlane to add to the collection.
Checks whether this collection contains a ClippingPlane equal to the given ClippingPlane.
clippingPlane ClippingPlane optional The ClippingPlane to check for.
true if this collection contains the ClippingPlane, false otherwise.
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Throws:
clippingPlanes = clippingPlanes && clippingPlanes.destroy();
Returns the plane in the collection at the specified index. Indices are zero-based and increase as planes are added. Removing a plane shifts all planes after it to the left, changing their indices. This function is commonly used with ClippingPlaneCollection#length to iterate over all the planes in the collection.
index number The zero-based index of the plane.
The ClippingPlane at the specified index.
Removes the first occurrence of the given ClippingPlane from the collection.
true if the plane was removed; false if the plane was not found in the collection.
Removes all planes from the collection.
Called when Viewer or CesiumWidget render the scene to build the resources for clipping planes.
Do not call this function directly.
