A
Property which evaluates to a Cartesian3 vector
based on the velocity of the provided PositionProperty.
position |
PositionProperty | optional The position property used to compute the velocity. | |
normalize |
boolean |
true
optional Whether to normalize the computed velocity vector. |
//Create an entity with a billboard rotated to match its velocity.
const position = new Cesium.SampledProperty();
position.addSamples(...);
const entity = viewer.entities.add({
position : position,
billboard : {
image : 'image.png',
alignedAxis : new Cesium.VelocityVectorProperty(position, true) // alignedAxis must be a unit vector
Gets a value indicating if this property is constant.
Gets or sets whether the vector produced by this property
will be normalized or not.
position : Property|undefined
Gets or sets the position property used to compute the velocity vector.
| Name | Type | Description |
other |
getValue(time, result) → Cartesian3
time |
JulianDate |
JulianDate.now()
result |
Cartesian3 | optional The object to store the value into, if omitted, a new instance is created and returned. |
