GroundPolylinePrimitive
new Cesium.GroundPolylinePrimitive(options)
A GroundPolylinePrimitive represents a polyline draped over the terrain or 3D Tiles in the Scene.
Only to be used with GeometryInstances containing GroundPolylineGeometry.
Name Type Default Description
geometryInstances Array | GeometryInstance optional GeometryInstances containing GroundPolylineGeometry
appearance Appearance optional The Appearance used to render the polyline. Defaults to a white color Material on a PolylineMaterialAppearance.
show boolean true optional Determines if this primitive will be shown.
interleave boolean false optional When true, geometry vertex attributes are interleaved, which can slightly improve rendering performance but increases load time.
releaseGeometryInstances boolean true optional When true, the primitive does not keep a reference to the input geometryInstances to save memory.
allowPicking boolean true optional When true, each geometry instance will only be pickable with Scene#pick. When false, GPU memory is saved.
asynchronous boolean true optional Determines if the primitive will be created asynchronously or block until ready. If false initializeTerrainHeights() must be called first.
classificationType ClassificationType ClassificationType.BOTH optional Determines whether terrain, 3D Tiles or both will be classified.
debugShowBoundingVolume boolean false optional For debugging only. Determines if this primitive's commands' bounding spheres are shown.
debugShowShadowVolume boolean false optional For debugging only. Determines if the shadow volume for each geometry in the primitive is drawn. Must be true on creation to have effect.
// 1. Draw a polyline on terrain with a basic color material
const instance = new Cesium.GeometryInstance({
  geometry : new Cesium.GroundPolylineGeometry({
     positions : Cesium.Cartesian3.fromDegreesArray([
         -112.1340164450331, 36.05494287836128,
         -112.08821010582645, 36.097804071380715
     width : 4.0
  id : 'object returned when this instance is picked and to get/set per-instance attributes'
scene.groundPrimitives.add(new Cesium.GroundPolylinePrimitive({
  geometryInstances : instance,
  appearance : new Cesium.PolylineMaterialAppearance()
// 2. Draw a looped polyline on terrain with per-instance color and a distance display condition.
// Distance display conditions for polylines on terrain are based on an approximate terrain height
// instead of true terrain height.
const instance2 = new Cesium.GeometryInstance({
         -112.08821010582645, 36.097804071380715,
         -112.13296079730024, 36.168769146801104
     loop : true,
     width : 4.0
  attributes : {
     color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.fromCssColorString('green').withAlpha(0.7)),
     distanceDisplayCondition : new Cesium.DistanceDisplayConditionGeometryInstanceAttribute(1000, 30000)
  geometryInstances : instance2,
  appearance : new Cesium.PolylineColorAppearance()
Default Value: true
The Appearance used to shade this primitive. Each geometry instance is shaded with the same appearance. Some appearances, like PolylineColorAppearance allow giving each instance unique properties.
Default Value: undefined
Determines if the geometry instances will be created and batched on a web worker.
Default Value: true
Default Value: ClassificationType.BOTH
This property is for debugging only; it is not for production use nor is it optimized.
Draws the bounding sphere for each draw command in the primitive.
Default Value: false
readonly debugShowShadowVolume : boolean
If true, draws the shadow volume for each geometry in the primitive.
The geometry instances rendered with this primitive. This may be undefined if options.releaseGeometryInstances is true when the primitive is constructed.
Changing this property after the primitive is rendered has no effect.
Determines if geometry vertex attributes are interleaved, which can slightly improve rendering performance.
Determines if the primitive is complete and ready to render. If this property is true, the primitive will be rendered the next time that GroundPolylinePrimitive#update is called.
readonly releaseGeometryInstances : boolean
Default Value: true
Determines if the primitive will be shown. This affects all geometry instances in the primitive.
Default Value: true
static Cesium.GroundPolylinePrimitive.initializeTerrainHeights() → Promise.<void>
Initializes the minimum and maximum terrain heights. This only needs to be called if you are creating the GroundPolylinePrimitive synchronously.
A promise that will resolve once the terrain heights have been loaded.
static Cesium.GroundPolylinePrimitive.isSupported(scene) → boolean
Checks if the given Scene supports GroundPolylinePrimitives. GroundPolylinePrimitives require support for the WEBGL_depth_texture extension.
scene Scene The current scene.
Whether or not the current scene supports GroundPolylinePrimitives.
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Throws:
e = e && e.destroy();
getGeometryInstanceAttributes(id) → object
Returns the modifiable per-instance attributes for a GeometryInstance.
id * The id of the GeometryInstance.
The typed array in the attribute's format or undefined if the is no instance with id.
Throws:
  • DeveloperError : must call update before calling getGeometryInstanceAttributes.
const attributes = primitive.getGeometryInstanceAttributes('an id');
attributes.color = Cesium.ColorGeometryInstanceAttribute.toValue(Cesium.Color.AQUA);
attributes.show = Cesium.ShowGeometryInstanceAttribute.toValue(true);
Called when Viewer or CesiumWidget render the scene to get the draw commands needed to render this primitive.
Do not call this function directly. This is documented just to list the exceptions that may be propagated when the scene is rendered:
Throws:
  • DeveloperError : For synchronous GroundPolylinePrimitives, you must call GroundPolylinePrimitives.initializeTerrainHeights() and wait for the returned promise to resolve.
  • DeveloperError : All GeometryInstances must have color attributes to use PolylineColorAppearance with GroundPolylinePrimitive.
