CoplanarPolygonGeometry
new Cesium.CoplanarPolygonGeometry(options)
A description of a polygon composed of arbitrary coplanar positions.
Name Type Default Description
polygonHierarchy PolygonHierarchy A polygon hierarchy that can include holes.
stRotation number 0.0 optional The rotation of the texture coordinates, in radians. A positive rotation is counter-clockwise.
vertexFormat VertexFormat VertexFormat.DEFAULT optional The vertex attributes to be computed.
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid to be used as a reference.
textureCoordinates PolygonHierarchy optional Texture coordinates as a PolygonHierarchy of Cartesian2 points.
const polygonGeometry = new Cesium.CoplanarPolygonGeometry({
 polygonHierarchy: new Cesium.PolygonHierarchy(
    Cesium.Cartesian3.fromDegreesArrayHeights([
     -90.0, 30.0, 0.0,
     -90.0, 30.0, 300000.0,
     -80.0, 30.0, 300000.0,
     -80.0, 30.0, 0.0
static Cesium.CoplanarPolygonGeometry.createGeometry(polygonGeometry)Geometry|undefined
Computes the geometric representation of an arbitrary coplanar polygon, including its vertices, indices, and a bounding sphere.
polygonGeometry CoplanarPolygonGeometry A description of the polygon.
The computed vertices and indices.
static Cesium.CoplanarPolygonGeometry.fromPositions(options)CoplanarPolygonGeometry
A description of a coplanar polygon from an array of positions.
positions Array.<Cartesian3> An array of positions that defined the corner points of the polygon.
// create a polygon from points
const polygon = Cesium.CoplanarPolygonGeometry.fromPositions({
  positions : Cesium.Cartesian3.fromDegreesArray([
    -72.0, 40.0,
    -70.0, 35.0,
    -75.0, 30.0,
    -70.0, 30.0,
    -68.0, 40.0
const geometry = Cesium.PolygonGeometry.createGeometry(polygon);
  • PolygonGeometry#createGeometry
static Cesium.CoplanarPolygonGeometry.pack(value, array, startingIndex)Array.<number>
value CoplanarPolygonGeometry The value to pack.
array Array.<number> The array to pack into.
startingIndex number 0 optional The index into the array at which to start packing the elements.
static Cesium.CoplanarPolygonGeometry.unpack(array, startingIndex, result)CoplanarPolygonGeometry
array Array.<number> The packed array.
startingIndex number 0 optional The starting index of the element to be unpacked.
result CoplanarPolygonGeometry optional The object into which to store the result.
The modified result parameter or a new CoplanarPolygonGeometry instance if one was not provided.
