SingleTileImageryProvider
new Cesium.SingleTileImageryProvider(options)
Provides a single, top-level imagery tile. The single image is assumed to be in the Geographic projection (i.e. WGS84 / EPSG:4326), and will be rendered using a GeographicTilingScheme.
options SingleTileImageryProvider.ConstructorOptions Object describing initialization options
Gets the URL of the single, top-level imagery tile.
static Cesium.SingleTileImageryProvider.fromUrl(url, options) → Promise.<SingleTileImageryProvider>
Creates a provider for a single, top-level imagery tile. The single image is assumed to use a
url Resource | string The url for the tile
options SingleTileImageryProvider.fromUrlOptions optional Object describing initialization options.
The resolved SingleTileImageryProvider.
const provider = await SingleTileImageryProvider.fromUrl("https://yoururl.com/image.png");
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
The resolved image
Type Definitions
Cesium.SingleTileImageryProvider.ConstructorOptions
Initialization options for the SingleTileImageryProvider constructor
Properties:
url Resource | string The url for the tile.
tileWidth number <optional>
The width of the tile, in pixels.
tileHeight number <optional>
The height of the tile, in pixels.
Rectangle.MAX_VALUE The rectangle, in radians, covered by the image.
The ellipsoid. If not specified, the WGS84 ellipsoid is used.
Cesium.SingleTileImageryProvider.fromUrlOptions
Initialization options for the SingleTileImageryProvider constructor when using SingleTileImageryProvider.fromUrl
Properties:
