BufferPrimitiveCollection
Collection of primitives held in ArrayBuffer storage for performance and memory optimization.
To get the full performance benefit of using a BufferPrimitiveCollection containing "N" primitives, be careful to avoid allocating "N" instances of any related JavaScript object. BufferPrimitive, Color, Cartesian3, and other objects can all be reused when working with large collections, using the flyweight pattern.
abstract new Cesium.BufferPrimitiveCollection(options)
options BufferPrimitiveCollectionOptions optional
Experimental
static constant Cesium.BufferPrimitiveCollection.DEFAULT_CAPACITY : number
Default capacity of buffers on new collections. A quantity of elements: number of vertices in the vertex buffer, primitives in the primitive buffer, etc. This value is arbitrary, and collections cannot be resized, so specific per-buffer capacities should be provided in the collection constructor when available.
protected readonly _boundingVolumeAutoUpdate : boolean
Transforms geometry from model to world coordinates.
Default Value: Matrix4.IDENTITY
Determines how primitives in the collection are blended with the scene. Must be BlendOption.OPAQUE or BlendOption.TRANSLUCENT; BlendOption.OPAQUE_AND_TRANSLUCENT is not supported.
BlendOption.OPAQUE disables blending and writes depth, so primitives occlude each other and the geometry behind them. BlendOption.TRANSLUCENT alpha blends primitives and does not write depth, so they are resolved by order-independent translucency instead.
Default Value: BlendOption.TRANSLUCENT
World-space bounding volume for all primitives in the collection, including both shown and hidden primitives.
Total byte length of buffers owned by this collection. Includes any unused space allocated by primitiveCountMax, even if no primitives have yet been added in that space.
This property is for debugging only; it is not for production use nor is it optimized.
Draws the bounding sphere for each draw command in the primitive.
Default Value: false
Determines which surfaces the collection is draped onto, in addition to being drawn as standalone geometry. Draping requires that the collection has been added to Scene#primitives.
The component datatype used to store position values.
When true, integer position values are treated as normalized values, where the full integer range maps to [-1, 1] (signed) or [0, 1] (unsigned).
Number of primitives in collection. Must be <= primitiveCountMax.
Maximum number of primitives this collection can contain. Must be >= primitiveCount.
Default Value: BufferPrimitiveCollection.DEFAULT_CAPACITY
Determines if primitives in this collection will be shown.
Default Value: true
Number of vertices in collection. Must be <= vertexCountMax.
Maximum number of vertices this collection can contain. Must be >= vertexCount.
static Cesium.BufferPrimitiveCollection.clone(collection, result, predicate)
Duplicates the contents of this collection into the result collection. Result collection is not resized, and must contain enough space for all primitives in the source collection. Existing primitives in the result collection will be overwritten.
Useful when allocating more space for a collection that has reached its capacity, and efficiently transferring features to the new collection.
collection BufferPrimitiveCollection.<T>
result BufferPrimitiveCollection.<T>
predicate function optional When provided, only primitives for which this returns true are copied. Surviving primitives are compacted into contiguous indices.
const result = new BufferPrimitiveCollection({ ... }); // allocate larger 'result' collection
BufferPrimitiveCollection.clone(collection, result);   // copy primitives from 'collection' into 'result'
static Cesium.BufferPrimitiveCollection.fromCollection(collection, options, predicate) → BufferPrimitiveCollection.<T>
Returns a copy of the given collection, overriding any constructor options provided. Omitted options are inherited from the source collection. Any resized buffers must be large enough to hold every primitive.
Collection-level state (model matrix, blend option, picking, bounding-volume mode, etc.) is carried over, but GPU resources are not: the source collection retains ownership of its renderer resources, so the caller is responsible for calling BufferPrimitiveCollection#destroy on the source once it is no longer needed.
collection BufferPrimitiveCollection.<T> Source collection to copy.
options BufferPrimitiveCollectionOptions optional Constructor options to override. Omitted options are inherited from the source collection.
Examples:
const grown = BufferPrimitiveCollection.fromCollection(collection, {
  primitiveCountMax: collection.primitiveCountMax * 2,
  vertexCountMax: collection.vertexCountMax * 2,
collection.destroy(); // release the source collection's GPU resources
// Grow while dropping hidden primitives.
const compacted = BufferPrimitiveCollection.fromCollection(
  collection,
  { primitiveCountMax: collection.primitiveCountMax * 2 },
  (primitive) => primitive.show,
Adds a new primitive to the collection, with the specified options. A BufferPrimitive instance is linked to the new primitive, using the 'result' argument if given, or a new instance if not. For repeated calls, prefer to reuse a single BufferPrimitive instance rather than allocating a new instance on each call.
options BufferPrimitiveOptions
Destroys collection and its GPU resources.
Makes the given BufferPrimitive a view onto this collection's primitive at the given index, for use when reading/writing primitive properties. When iterating over a large collection, prefer to reuse the same BufferPrimitive instance throughout the loop — rebinding an existing instance to a different primitive is cheap, and avoids allocating in-memory objects for every object.
index number
The BufferPrimitive instance passed as the 'result' argument, now bound to the specified primitive index.
const primitive = new BufferPrimitive();
for (let i = 0; i < collection.primitiveCount; i++) {
  collection.get(i, primitive);
  primitive.setColor(Color.RED);
abstract setPositions(positions, primitiveOffset, primitiveCount)
Updates vertex positions over the specified range of primitives. For position-only updates to many primitives, `setPositions()` is more efficient than updating each primitive individually. Argument `positions` must contain the same total number of vertices as the target primitive range; vertices cannot be added/removed by this method.
positions TypedArray
primitiveOffset number
primitiveCount number
Sorts primitives of the collection. Because sorting changes the indices (but not the feature IDs) of primitives in the collection, the function also returns an array mapping from previous index to new index. When sorting repeatedly, the array can be reused and passed as the 'result' argument for each call.
sortFn function
result Uint32Array
Mapping from previous index to new index.
Returns a JSON-serializable array representing the collection. This encoding is not memory-efficient, and should generally be used for debugging and testing.
List of JSON-serializable objects, one for each primitive in the collection.
console.table(collection.toJSON());
frameState object
