origin |
Cartesian3 | The point on the surface of the ellipsoid where the tangent plane touches. | |
ellipsoid |
Ellipsoid |
Ellipsoid.default
optional The ellipsoid to use. |
Throws:
DeveloperError : origin must not be at the center of the ellipsoid.
Gets the ellipsoid.
Gets the origin.
readonly plane : Plane
Gets the plane which is tangent to the ellipsoid.
readonly xAxis : Cartesian3
Gets the local X-axis (east) of the tangent plane.
readonly yAxis : Cartesian3
Gets the local Y-axis (north) of the tangent plane.
readonly zAxis : Cartesian3
Gets the local Z-axis (up) of the tangent plane.
static Cesium.EllipsoidTangentPlane.fromPoints(cartesians, ellipsoid) → EllipsoidTangentPlane
Creates a new instance from the provided ellipsoid and the center
point of the provided Cartesians.
cartesians |
Array.<Cartesian3> | The list of positions surrounding the center point. | |
ellipsoid |
Ellipsoid |
Ellipsoid.default
The new instance of EllipsoidTangentPlane.
projectPointOntoEllipsoid(cartesian, result) → Cartesian3
Computes the projection of the provided 2D position onto the 3D ellipsoid.
| Name | Type | Description |
cartesian |
Cartesian2 | The points to project. |
result |
Cartesian3 | optional The Cartesian3 instance to store result. |
The modified result parameter or a new Cartesian3 instance if none was provided.
projectPointOntoPlane(cartesian, result) → Cartesian2
Computes the projection of the provided 3D position onto the 2D plane, radially outward from the
EllipsoidTangentPlane.ellipsoid coordinate system origin.
cartesian |
Cartesian3 | The point to project. |
result |
Cartesian2 | optional The object onto which to store the result. |
The modified result parameter or a new Cartesian2 instance if none was provided. Undefined if there is no intersection point
projectPointsOntoEllipsoid(cartesians, result) → Array.<Cartesian3>
Computes the projection of the provided 2D positions onto the 3D ellipsoid.
cartesians |
Array.<Cartesian2> | The array of points to project. |
result |
Array.<Cartesian3> | optional The array of Cartesian3 instances onto which to store results. |
The modified result parameter or a new array of Cartesian3 instances if none was provided.
projectPointsOntoPlane(cartesians, result) → Array.<Cartesian2>
Computes the projection of the provided 3D positions onto the 2D plane (where possible), radially outward from the global origin.
The resulting array may be shorter than the input array - if a single projection is impossible it will not be included.
cartesians |
Array.<Cartesian3> | The array of points to project. |
result |
Array.<Cartesian2> | optional The array of Cartesian2 instances onto which to store results. |
The modified result parameter or a new array of Cartesian2 instances if none was provided.
- EllipsoidTangentPlane.projectPointOntoPlane
projectPointsToNearestOnPlane(cartesians, result) → Array.<Cartesian2>
Computes the projection of the provided 3D positions onto the 2D plane, along the plane normal.
cartesians |
result |
The modified result parameter or a new array of Cartesian2 instances if none was provided. This will have the same length as
cartesians.
- EllipsoidTangentPlane.projectPointToNearestOnPlane
projectPointToNearestOnPlane(cartesian, result) → Cartesian2
Computes the projection of the provided 3D position onto the 2D plane, along the plane normal.
cartesian |
result |
