SimplePolylineGeometry
new Cesium.SimplePolylineGeometry(options)
A description of a polyline modeled as a line strip; the first two positions define a line segment, and each additional position defines a line segment from the previous position.
Name Type Default Description
positions Array.<Cartesian3> An array of Cartesian3 defining the positions in the polyline as a line strip.
colors Array.<Color> optional An Array of Color defining the per vertex or per segment colors.
colorsPerVertex boolean false optional A boolean that determines whether the colors will be flat across each segment of the line or interpolated across the vertices.
arcType ArcType ArcType.GEODESIC optional The type of line the polyline segments must follow.
granularity number CesiumMath.RADIANS_PER_DEGREE optional The distance, in radians, between each latitude and longitude if options.arcType is not ArcType.NONE. Determines the number of positions in the buffer.
ellipsoid Ellipsoid Ellipsoid.default optional The ellipsoid to be used as a reference.
Throws:
// A polyline with two connected line segments
const polyline = new Cesium.SimplePolylineGeometry({
  positions : Cesium.Cartesian3.fromDegreesArray([
    0.0, 0.0,
    5.0, 0.0,
    5.0, 5.0
const geometry = Cesium.SimplePolylineGeometry.createGeometry(polyline);
  • SimplePolylineGeometry#createGeometry
static Cesium.SimplePolylineGeometry.createGeometry(simplePolylineGeometry) → Geometry|undefined
Computes the geometric representation of a simple polyline, including its vertices, indices, and a bounding sphere.
simplePolylineGeometry SimplePolylineGeometry A description of the polyline.
The computed vertices and indices.
static Cesium.SimplePolylineGeometry.pack(value, array, startingIndex) → Array.<number>
value SimplePolylineGeometry The value to pack.
array Array.<number> The array to pack into.
startingIndex number 0 optional The index into the array at which to start packing the elements.
static Cesium.SimplePolylineGeometry.unpack(array, startingIndex, result) → SimplePolylineGeometry
array Array.<number> The packed array.
startingIndex number 0 optional The starting index of the element to be unpacked.
result SimplePolylineGeometry optional The object into which to store the result.
The modified result parameter or a new SimplePolylineGeometry instance if one was not provided.
