DynamicEnvironmentMapManager
new Cesium.DynamicEnvironmentMapManager(options)
Generates an environment map at the given position based on scene's current lighting conditions. From this, it produces multiple levels of specular maps and spherical harmonic coefficients than can be used with ImageBasedLighting for models or tilesets.
options DynamicEnvironmentMapManager.ConstructorOptions optional An object describing initialization options.
Examples:
// Enable time-of-day environment mapping in a scene
scene.atmosphere.dynamicLighting = Cesium.DynamicAtmosphereLightingType.SUNLIGHT;
// Decrease the directional lighting contribution
scene.light.intensity = 0.5
// Increase the intensity of of the environment map lighting contribution
const environmentMapManager = tileset.environmentMapManager;
environmentMapManager.atmosphereScatteringIntensity = 3.0;
// Change the ground color used for a model's environment map to a forest green
const environmentMapManager = model.environmentMapManager;
environmentMapManager.groundColor = Cesium.Color.fromCssColorString("#203b34");
static readonly Cesium.DynamicEnvironmentMapManager.AVERAGE_EARTH_GROUND_COLOR : Color
Average hue of ground color on earth, a warm green-gray.
static readonly Cesium.DynamicEnvironmentMapManager.DEFAULT_SPHERICAL_HARMONIC_COEFFICIENTS : Array.<Cartesian3>
The default third order spherical harmonic coefficients used for the diffuse color of image-based lighting, a white ambient light with low intensity.
There are nine Cartesian3 coefficients. The order of the coefficients is: L0,0, L1,-1, L1,0, L1,1, L2,-2, L2,-1, L2,0, L2,1, L2,2
The intensity of the scattered light emitted from the atmosphere. This should be adjusted relative to the value of Scene.light intensity.
Default Value: 2.0
  • DirectionalLight.intensity
  • SunLight.intensity
The brightness of light emitted from the environment. 1.0 uses the unmodified emitted environment color. Less than 1.0 makes the light darker while greater than 1.0 makes it brighter.
Default Value: 1.0
If true, the environment map and related properties will continue to update.
Default Value: true
The gamma correction to apply to the range of light emitted from the environment. 1.0 uses the unmodified incoming light color.
Default Value: 1.0
The percentage of light reflected from the ground. The average earth albedo is 0.31.
Default Value: 0.31
Solid color used to represent the ground.
Default Value: DynamicEnvironmentMapManager.AVERAGE_EARTH_GROUND_COLOR
The maximum difference in position before a new environment map is created, in meters. Small differences in position will not visibly affect results.
Default Value: 1000
The maximum amount of elapsed seconds before a new environment map is created.
Default Value: 3600
The position around which the environment map is generated.
The saturation of the light emitted from the environment. 1.0 uses the unmodified emitted environment color. Less than 1.0 reduces the saturation while greater than 1.0 increases it.
Default Value: 1.0
static Cesium.DynamicEnvironmentMapManager.isDynamicUpdateSupported(scene) → boolean
Returns true if dynamic updates are supported in the current WebGL rendering context. Dynamic updates requires the EXT_color_buffer_float or EXT_color_buffer_half_float extension.
scene Scene The object containing the rendering context
true if supported
Destroys the WebGL resources held by this object. Destroying an object allows for deterministic release of WebGL resources, instead of relying on the garbage collector to destroy this object.
Throws:
mapManager = mapManager && mapManager.destroy();
Type Definitions
Cesium.DynamicEnvironmentMapManager.ConstructorOptions
Options for the DynamicEnvironmentMapManager constructor
Properties:
enabled boolean <optional>
true If true, the environment map and related properties will continue to update.
mipmapLevels number <optional>
7 The maximum desired number of mipmap levels to generate for specular maps. More mipmap levels will produce a higher resolution specular reflection. The actual number of mipmaps used will be bounded by the cubemap texture size supported on the client machine. The number of mipmaps must be at least one for the environment map to be generated.
maximumSecondsDifference number <optional>
3600 The maximum amount of elapsed seconds before a new environment map is created.
maximumPositionEpsilon number <optional>
1000 The maximum difference in position before a new environment map is created, in meters. Small differences in position will not visibly affect results.
atmosphereScatteringIntensity number <optional>
2.0 The intensity of the scattered light emitted from the atmosphere. This should be adjusted relative to the value of Scene.light intensity.
gamma number <optional>
1.0 The gamma correction to apply to the range of light emitted from the environment. 1.0 uses the unmodified emitted light color.
brightness number <optional>
1.0 The brightness of light emitted from the environment. 1.0 uses the unmodified emitted environment color. Less than 1.0 makes the light darker while greater than 1.0 makes it brighter.
saturation number <optional>
1.0 The saturation of the light emitted from the environment. 1.0 uses the unmodified emitted environment color. Less than 1.0 reduces the saturation while greater than 1.0 increases it.
groundColor Color <optional>
DynamicEnvironmentMapManager.AVERAGE_EARTH_GROUND_COLOR Solid color used to represent the ground.
groundAlbedo number <optional>
0.31 The percentage of light reflected from the ground. The average earth albedo is 0.31.
