A
MaterialProperty that maps to polyline outline Material uniforms.
| Name | Type | Description | ||||||||||||||||
options |
object |
optional
Gets or sets the Property specifying the
Color of the line.
Default Value:
Color.WHITE
The definition is considered to have changed if a call to getValue would return
a different result for the same time.
outlineColor : Property|undefined
Color of the outline.
Default Value:
Color.BLACK
outlineWidth : Property|undefined
Gets or sets the numeric Property specifying the width of the outline.
Default Value:
1.0
other |
Gets the
Material type at the provided time.
time |
JulianDate | The time for which to retrieve the type. |
The type of material.
time |
JulianDate |
JulianDate.now()
result |
object | optional The object to store the value into, if omitted, a new instance is created and returned. |
