GoogleEarthEnterpriseImageryProvider
new Cesium.GoogleEarthEnterpriseImageryProvider(options)
To construct a GoogleEarthEnterpriseImageryProvider, call GoogleEarthEnterpriseImageryProvider.fromMetadata. Do not call the constructor directly.
Provides tiled imagery using the Google Earth Enterprise REST API. Notes: This provider is for use with the 3D Earth API of Google Earth Enterprise, GoogleEarthEnterpriseMapsProvider should be used with 2D Maps API.
options GoogleEarthEnterpriseImageryProvider.ConstructorOptions optional Object describing initialization options
const geeMetadata = await GoogleEarthEnterpriseMetadata.fromUrl("http://www.example.com");
const gee = Cesium.GoogleEarthEnterpriseImageryProvider.fromMetadata(geeMetadata);
Gets a value indicating whether or not the images provided by this imagery provider include an alpha channel. If this property is false, an alpha channel, if present, will be ignored. If this property is true, any images without an alpha channel will be treated as if their alpha is 1.0 everywhere. Setting this property to false reduces memory usage and texture upload time.
Gets the name of the Google Earth Enterprise server url hosting the imagery.
static Cesium.GoogleEarthEnterpriseImageryProvider.fromMetadata(metadata, options) → GoogleEarthEnterpriseImageryProvider
Creates a tiled imagery provider using the Google Earth Enterprise REST API.
metadata GoogleEarthEnterpriseMetadata A metadata object that can be used to share metadata requests with a GoogleEarthEnterpriseTerrainProvider.
options GoogleEarthEnterpriseImageryProvider.ConstructorOptions Object describing initialization options.
Throws:
level number The tile level;
pickFeatures(x, y, level, longitude, latitude) → undefined
Picking features is not currently supported by this imagery provider, so this function simply returns undefined.
level number The tile level.
Undefined since picking is not supported.
Type Definitions
Cesium.GoogleEarthEnterpriseImageryProvider.ConstructorOptions
Initialization options for the GoogleEarthEnterpriseImageryProvider constructor
Properties:
Ellipsoid.default The ellipsoid. If not specified, the default ellipsoid is used.
tileDiscardPolicy TileDiscardPolicy <optional>
The policy that determines if a tile is invalid and should be discarded. If this value is not specified, a default is to discard tiles that fail to download.
