Cesium3DTilesSelection Namespace Reference
Classes that implement the 3D Tiles standard. More...
Classes
class  CesiumIonTilesetContentLoaderFactory
 A factory for creating a TilesetContentLoader for assets from Cesium ion. More...
class  DebugTileStateDatabase
 Helps debug the tile selection algorithm by recording the state of tiles each frame to a SQLite database. More...
class  EllipsoidTilesetLoader
 A loader that will generate a tileset by tesselating the surface of an ellipsoid, producing a simple globe tileset without any terrain features. More...
struct  FogDensityAtHeight
 Defines the fog density at a certain height. More...
class  GltfModifier
 An abstract class that allows modifying a tile's glTF model after it has been loaded. More...
struct  GltfModifierInput
 The input to GltfModifier::apply. More...
struct  GltfModifierOutput
 The output of GltfModifier::apply. More...
struct  GltfModifierVersionExtension
 An extension holding the "version" of a glTF produced by GltfModifier. More...
class  IModelMeshExportContentLoaderFactory
 A factory for creating a TilesetContentLoader from data from the iModel Mesh Export API. More...
class  IPrepareRendererResources
 When implemented for a rendering engine, allows renderer resources to be created and destroyed under the control of a Tileset. More...
class  ITileExcluder
 An interface that allows tiles to be excluded from loading and rendering when provided in TilesetOptions::excluders. More...
class  ITilesetHeightSampler
 An interface to query heights from a tileset that can do so efficiently without necessarily downloading individual tiles. More...
class  ITwinCesiumCuratedContentLoaderFactory
 A factory for creating a TilesetContentLoader from data from the iTwin Cesium Curated Content API. More...
class  ITwinRealityDataContentLoaderFactory
 A factory for creating a TilesetContentLoader from data from the iTwin Reality Management API. More...
class  LoadedConstTileEnumerator
 A "virtual collection" that allows enumeration through the loaded tiles in a subtree rooted at a given Tile. More...
class  LoadedTileEnumerator
struct  LoaderCreditResult
 Credit information obtained from a TilesetContentLoader. More...
class  RasterizedPolygonsTileExcluder
 When provided to TilesetOptions::excluders, uses the polygons owned by a CesiumRasterOverlays::RasterizedPolygonsOverlay to exclude tiles that are entirely inside any of the polygon from loading. This is useful when the polygons will be used for clipping. More...
class  RasterMappedTo3DTile
 The result of applying a CesiumRasterOverlays::RasterOverlayTile to geometry. More...
class  RasterOverlayCollection
 A collection of CesiumRasterOverlays::RasterOverlay instances that are associated with a Tileset. More...
struct  SampleHeightResult
 The result of sampling heights with Tileset::sampleHeightMostDetailed. More...
class  Tile
 A tile in a Tileset. More...
struct  TileChildrenResult
 Store the result of creating tile's children after invoking TilesetContentLoader::createTileChildren. More...
class  TileContent
 A tile content container that can store and query the content type that is currently being owned by the tile. More...
struct  TileEmptyContent
 A content tag that indicates a tile has no content. More...
struct  TileExternalContent
 A content tag that indicates a tile content points to an external tileset. When this tile is loaded, all the tiles in the external tileset will become children of this external content tile. More...
struct  TileIdUtilities
 Utility functions related to TileID objects. More...
struct  TileLoadInput
 Store the parameters that are needed to load a tile. More...
class  TileLoadRequester
 The base class for something that requests loading of specific tiles from a 3D Tiles Tileset. More...
struct  TileLoadResult
 Store the result of loading a tile content after invoking TilesetContentLoader::loadTileContent. More...
struct  TileLoadResultAndRenderResources
struct  TileLoadTask
 Represents the need to load a particular Cesium3DTilesSelection::Tile with a particular priority. More...
class  TileOcclusionRendererProxy
 An interface for client renderers to use to represent tile bounding volumes that should be occlusion tested. More...
class  TileOcclusionRendererProxyPool
 A pool of TileOcclusionRendererProxy objects. Allows quick remapping of tiles to occlusion renderer proxies so new proxies do not have to be created for each new tile requesting occlusion results. More...
struct  TileRasterOverlayStatus
 Captures the tile overlay status as produced by RasterOverlayCollection::updateTileOverlays. More...
class  TileRenderContent
 A content tag that indicates a tile has a glTF model content and render resources for the model. More...
struct  TileSelectionContext
 Per-frame inputs for the tile selection algorithm. More...
class  TileSelectionState
 A description of the selection state of a Tile during the Tileset::updateViewGroup process. More...
class  Tileset
 A 3D Tiles tileset, used for streaming massive heterogeneous 3D geospatial datasets. More...
class  TilesetContentLoader
 The loader interface to load the tile content. More...
class  TilesetContentLoaderFactory
 A factory to create a tileset loader. More...
struct  TilesetContentLoaderResult
 The result of creating a TilesetContentLoader, including the status, request, and any errors, as well as the root tile, credits, and the loader itself. More...
struct  TilesetContentOptions
 Options for configuring the parsing the contents of a Tileset, including construction of its glTF models. More...
class  TilesetExternals
 External interfaces used by a Tileset. More...
class  TilesetFrameState
 Captures information about the current frame during a call to Tileset::updateViewGroup. More...
class  TilesetLoadFailureDetails
class  TilesetMetadata
 Holds the metadata associated with a Tileset or an external tileset. This holds all of the fields of CesiumTilesetJson::Tileset except for the root tile. More...
struct  TilesetOptions
 Additional options for configuring a Tileset. More...
class  TilesetSharedAssetSystem
 Contains assets that are potentially shared across multiple Tilesets. More...
class  TilesetViewGroup
 Represents a group of views that collectively select tiles from a particular Tileset. More...
struct  TileUnknownContent
 A content tag that indicates the TilesetContentLoader does not know if a tile's content will point to a mesh content or an external tileset. The content of the tile is only known when the loader loads the tile to inspect the content. More...
class  ViewState
 The state of the view that is used during the traversal of a tileset. More...
class  ViewStateMeasureDelegate
 A handler for customizing calculation of the selection measure for tiles. By default that value is the screen space error, but it be another criteria such as absolute tile geometric error or the depth of a tile in the tileset. More...
class  ViewStateVisibilityDelegate
 A delegate for determining if a tile's content is visible, using user-defined criteria. For example, a tile's group might be tested. More...
class  ViewUpdateResult
 Reports the results of Tileset::updateViewGroup. More...
Typedefs
using GeneralCullingVolume
 A general culling volume for selecting and filtering tiles.
typedef std::variant< std::string, CesiumGeometry::QuadtreeTileID, CesiumGeometry::OctreeTileID, CesiumGeometry::UpsampledQuadtreeNode > TileID
 An identifier for a Tile inside the tile hierarchy.
using TileContentKind
 Store the content of the tile after finishing loading tile using TilesetContentLoader::loadTileContent :
Enumerations
enum class  GltfModifierState { Idle , WorkerRunning , WorkerDone }
enum class  TileLoadState {
  Unloading = -2 , FailedTemporarily = -1 , Unloaded = 0 , ContentLoading = 1 ,
  ContentLoaded = 2 , Done = 3 , Failed = 4
enum class  TileLoadResultState { Success , Failed , RetryLater }
 Indicate the status of Cesium3DTilesSelection::TilesetContentLoader::loadTileContent and Cesium3DTilesSelection::TilesetContentLoader::createTileChildren operations. More...
enum class  TileLoadPriorityGroup { Preload = 0 , Normal = 1 , Urgent = 2 }
 Enumerates broad categories of priority for loading a Cesium3DTilesSelection::Tile for a Cesium3DTilesSelection::TilesetViewGroup. More...
enum class  TileOcclusionState { OcclusionUnavailable , NotOccluded , Occluded }
 The occlusion state of a tile as reported by the renderer proxy. More...
enum class  TilesetLoadType { Unknown , CesiumIon , TilesetJson }
 The type of load that failed in TilesetLoadFailureDetails. More...
Functions
bool isBoundingVolumeVisible (const GeneralCullingVolume &cullingVolume, const Cesium3DTiles::BoundingVolume &boundingVolume)
 Test if a general culling volume intersects a bounding volume.
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: Cesium3DTilesSelection Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px Cesium3DTilesSelection[Cesium3DTilesSelection] --> Cesium3DTiles[Cesium3DTiles] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumAsync[CesiumAsync] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumGeometry[CesiumGeometry] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumGeospatial[CesiumGeospatial] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumGltf[CesiumGltf] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumGltfConverters[CesiumGltfConverters] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumGltfReader[CesiumGltfReader] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumImage[CesiumImage] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumQuantizedMeshTerrain[CesiumQuantizedMeshTerrain] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumRasterOverlays[CesiumRasterOverlays] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumTilesetJson[CesiumTilesetJson] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumTilesetJsonReader[CesiumTilesetJsonReader] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumUtility[CesiumUtility] Cesium3DTilesSelection[Cesium3DTilesSelection] --> CesiumVectorData[CesiumVectorData] Cesium3DTilesSelection[Cesium3DTilesSelection] --> draco_draco{{draco::draco}} Cesium3DTilesSelection[Cesium3DTilesSelection] --> libmorton_libmorton{{libmorton::libmorton}} Cesium3DTilesSelection[Cesium3DTilesSelection] --> nonstd_expected-lite{{nonstd::expected-lite}} Cesium3DTilesSelection[Cesium3DTilesSelection] --> spdlog_spdlog{{spdlog::spdlog}} Cesium3DTilesSelection[Cesium3DTilesSelection] --> tinyxml2_tinyxml2{{tinyxml2::tinyxml2}} class draco_draco,libmorton_libmorton,nonstd_expected-lite,spdlog_spdlog,tinyxml2_tinyxml2 dependencyNode class Cesium3DTiles,CesiumAsync,CesiumGeometry,CesiumGeospatial,CesiumGltf,CesiumGltfConverters,CesiumGltfReader,CesiumImage,CesiumQuantizedMeshTerrain,CesiumRasterOverlays,CesiumTilesetJson,CesiumTilesetJsonReader,CesiumUtility,CesiumVectorData,Cesium3DTilesSelection libraryNode
Typedef Documentation
◆ GeneralCullingVolume
Initial value:
std::variant<CesiumGeometry::CullingVolume, Cesium3DTiles::BoundingVolume>
While CesiumGeometry::CullingVolume represents orthographic and perspective view frustums, GeneralCullingVolume also includes Cesium3DTiles::BoundingVolume, which allows more general filtering (e.g., on geographic areas).
Definition at line 19 of file GeneralCullingVolume.h.
◆ TileContentKind
Initial value:
std::variant<
Definition TileContent.h:52
A content tag that indicates a tile content points to an external tileset. When this tile is loaded,...
Definition TileContent.h:60
A content tag that indicates the TilesetContentLoader does not know if a tile's content will point to...
Definition TileContent.h:29
Definition Model.h:14
  1. Returning TileUnknownContent means that the loader doesn't know the content of the tile. This content type is useful when loader fails to load the tile content; or a background task is running to determine the tile content and the loader wants the client to retry later at some point in the future
  2. Returning TileEmptyContent means that this tile has no content and mostly used for efficient culling during the traversal process
  3. Returning TileExternalContent means that this tile points to an external tileset
  4. Returning CesiumGltf::Model means that this tile has glTF model
Definition at line 38 of file TileLoadResult.h.
◆ TileID
This ID is stored in the tile as the Tile::getTileID. It is assigned to the tile at construction time, and may be used to identify and access the children of a given tile.
Depending on the exact type of the tile and its contents, this identifier may have different forms:
  • A std::string: This is an explicitly-described tile and the ID is the URL of the tile's content.
  • A CesiumGeometry::QuadtreeTileID : This is an implicit tile in the quadtree. The URL of the tile's content is formed by instantiating the context's template URL with this ID.
  • A CesiumGeometry::OctreeTileID : This is an implicit tile in the octree. The URL of the tile's content is formed by instantiating the context's template URL with this ID.
  • A CesiumGeometry::UpsampledQuadtreeNode : This tile doesn't have any content, but content for it can be created by subdividing the parent tile's content.
Definition at line 39 of file TileID.h.
◆ GltfModifierState
The state of the GltfModifier process for a given tile content's model.
Enumerator
Idle
Modifier is not currently processing this tile.
WorkerRunning
Worker-thread phase is in progress.
WorkerDone
The worker-thread phase is complete, but the main-thread phase is not done yet. When the main thread phase eventually runs, it will call TileRenderContent::replaceWithModifiedModel and then transition the GltfModifier back to the Idle state.
Definition at line 7 of file GltfModifierState.h.
◆ TileLoadPriorityGroup
Enumerator
Preload
Low priority tiles that aren't needed right now, but are being preloaded for the future.
Normal
Medium priority tiles that are needed to render the current view at the appropriate level-of-detail.
Urgent
High priority tiles whose absence is causing extra detail to be rendered in the scene, potentially creating a performance problem and aliasing artifacts.
Definition at line 12 of file TileLoadTask.h.
◆ TileLoadResultState
Enumerator
Success
The operation is successful and all the fields in TileLoadResult or TileChildrenResult are applied to the tile.
Failed
The operation is failed and none of the fields in TileLoadResult or TileChildrenResult are applied to the tile.
RetryLater
The operation requires the client to retry later due to some background work happenning and none of the fields in TileLoadResult or TileChildrenResult are applied to the tile.
Definition at line 50 of file TileLoadResult.h.
◆ TileLoadState
The current state of this tile in the loading process.
Enumerator
Unloading
This tile is in the process of being unloaded, but could not be fully unloaded because an asynchronous process is using its loaded data.
FailedTemporarily
Something went wrong while loading this tile, but it may be a temporary problem.
Unloaded
The tile is not yet loaded at all, beyond the metadata in tileset.json.
ContentLoading
The tile content is currently being loaded.
Note that while a tile is in this state, its Tile::getContent, and Tile::getState, methods may be called from the load thread, and the state may change due to the internal loading process.
ContentLoaded
The tile content has finished loading.
Done
The tile is completely done loading.
Failed
Something went wrong while loading this tile and it will not be retried.
Definition at line 55 of file Tile.h.
◆ TileOcclusionState
Enumerator
The renderer does not yet know if the tile's bounding volume is occluded or not.
This can be due to the typical occlusion delay caused by buffered rendering or otherwise be due to postponed occlusion queries. We can choose to wait for the occlusion information to become available before commiting to load the tile. This might prevent unneeded tile loads at the cost of a small delay.
NotOccluded
The tile's bounding volume is known by the renderer to be visible.
Occluded
The tile's bounding volume is known by the renderer to be occluded.
Definition at line 15 of file TileOcclusionRendererProxy.h.
◆ TilesetLoadType
Enumerator
Unknown
An unknown load error.
CesiumIon
A Cesium ion asset endpoint.
TilesetJson
The root tileset.json.
Definition at line 17 of file TilesetLoadFailureDetails.h.
Function Documentation
◆ isBoundingVolumeVisible()
bool Cesium3DTilesSelection::isBoundingVolumeVisible ( const GeneralCullingVolume & cullingVolume,
const Cesium3DTiles::BoundingVolume & boundingVolume )
cullingVolumeThe general culling volume.
boundingVolumeThe bounding volume.
true if volumes intersect.
