Cesium3DTilesSelection::TileOcclusionRendererProxy Class Referenceabstract
An interface for client renderers to use to represent tile bounding volumes that should be occlusion tested. More...
#include <Cesium3DTilesSelection/TileOcclusionRendererProxy.h>
virtual TileOcclusionState getOcclusionState () const =0
 Get the occlusion state for this tile. If this is OcclusionUnavailable, the traversal may decide to wait for the occlusion result to become available in future frames.
Protected Member Functions
virtual void reset (const Tile *pTile)=0
 Reset this proxy to target a new tile. If nullptr, this proxy is back in the pool and will not be used for further occlusion until reset is called again with an actual tile.
Friends
class TileOcclusionRendererProxyPool
Definition at line 43 of file TileOcclusionRendererProxy.h.
◆ getOcclusionState()
virtual TileOcclusionState Cesium3DTilesSelection::TileOcclusionRendererProxy::getOcclusionState ( ) const
pure virtual
Client implementation note: Do not return OcclusionUnavailable if the occlusion for this tile will never become available, otherwise the tile may not refine while waiting for occlusion. In such a case return NotOccluded so the traversal can assume it is known to be visible.
The occlusion state of this tile.
◆ reset()
virtual void Cesium3DTilesSelection::TileOcclusionRendererProxy::reset ( const Tile * pTile)
protectedpure virtual
pTileThe tile that this proxy represents or nullptr if the proxy is back in the pool.
◆ TileOcclusionRendererProxyPool
friend class TileOcclusionRendererProxyPool
friend
Definition at line 60 of file TileOcclusionRendererProxy.h.
