cesium-native 0.67.0
A raster overlay made from rasterizing a set of CartographicPolygon objects. The resulting overlay is monochromatic - white where pixels are inside of the polygons, and black where they are not. More...
#include <CesiumRasterOverlays/RasterizedPolygonsOverlay.h>
| RasterizedPolygonsOverlay (const std::string &name, const std::vector< CesiumGeospatial::CartographicPolygon > &polygons, bool invertSelection, const CesiumGeospatial::Ellipsoid &ellipsoid, const CesiumGeospatial::Projection &projection, const RasterOverlayOptions &overlayOptions={}) | |
| Creates a new RasterizedPolygonsOverlay. | |
| virtual CesiumAsync::Future< CreateTileProviderResult > | createTileProvider (const CreateRasterOverlayTileProviderParameters ¶meters) const override |
| Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future. | |
| const std::vector< CesiumGeospatial::CartographicPolygon > & | getPolygons () const noexcept |
| Gets the polygons that are being rasterized to create this overlay. | |
| bool | getInvertSelection () const noexcept |
Gets the value of the invertSelection value passed to the constructor. | |
| const CesiumGeospatial::Ellipsoid & | getEllipsoid () const noexcept |
| Gets the ellipsoid that this overlay is being generated for. | |
Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay | |
| RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions()) | |
| Creates a new instance. | |
| CesiumAsync::SharedFuture< void > & | getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem) |
| A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed. | |
| const std::string & | getName () const noexcept |
| Gets the name of this overlay. | |
| RasterOverlayOptions & | getOptions () noexcept |
| Gets options for this overlay. | |
| const RasterOverlayOptions & | getOptions () const noexcept |
| CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > | activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const |
| Activates this overlay. | |
| CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > | createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const |
| Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously. | |
Public Member Functions inherited from CesiumUtility::ReferenceCounted< T, false > | |
Public Types inherited from CesiumRasterOverlays::RasterOverlay | |
| using | CreateTileProviderResult |
| A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful. | |
Definition at line 25 of file RasterizedPolygonsOverlay.h.
| CesiumRasterOverlays::RasterizedPolygonsOverlay::RasterizedPolygonsOverlay | ( | const std::string & | name, |
| const std::vector< CesiumGeospatial::CartographicPolygon > & | polygons, | ||
| bool | invertSelection, | ||
| const CesiumGeospatial::Ellipsoid & | ellipsoid, | ||
| const CesiumGeospatial::Projection & | projection, | ||
| const RasterOverlayOptions & | overlayOptions = {} ) |
| name | The user-given name of this polygon layer. |
| polygons | The CartographicPolygon objects to rasterize. |
| invertSelection | If true, the overlay's colors will be inverted. The pixels inside of polygons will be black, and those outside will be white. |
| ellipsoid | The ellipsoid that this RasterOverlay is being generated for. |
| projection | The projection that this RasterOverlay is being generated for. |
| overlayOptions | Options to use for this RasterOverlay. |
overridevirtual |
| parameters | The parameters for creating the tile provider. |
Implements CesiumRasterOverlays::RasterOverlay.
inlinenoexcept |
Definition at line 73 of file RasterizedPolygonsOverlay.h.
inlinenoexcept |
Definition at line 68 of file RasterizedPolygonsOverlay.h.
inlinenoexcept |
Definition at line 60 of file RasterizedPolygonsOverlay.h.
