cesium-native 0.67.0
A 3D Tiles tileset, used for streaming massive heterogeneous 3D geospatial datasets. More...
#include <Cesium3DTilesSelection/Tileset.h>
| Tileset (const TilesetExternals &externals, std::unique_ptr< TilesetContentLoader > &&pCustomLoader, std::unique_ptr< Tile > &&pRootTile, const TilesetOptions &options=TilesetOptions()) | |
| Constructs a new instance with a given custom tileset loader. | |
| Tileset (const TilesetExternals &externals, const std::string &url, const TilesetOptions &options=TilesetOptions()) | |
| Constructs a new instance with a given URL. | |
| Tileset (const TilesetExternals &externals, int64_t ionAssetID, const std::string &ionAccessToken, const TilesetOptions &options=TilesetOptions(), const std::string &ionAssetEndpointUrl="https://api.cesium.com/") | |
| Constructs a new instance with the given asset ID on Cesium ion. | |
| Tileset (const TilesetExternals &externals, TilesetContentLoaderFactory &&loaderFactory, const TilesetOptions &options=TilesetOptions()) | |
| Constructs a new instance with the given TilesetContentLoaderFactory. | |
| ~Tileset () noexcept | |
| Destroys this tileset. | |
| CesiumAsync::SharedFuture< void > & | getAsyncDestructionCompleteEvent () |
| A future that resolves when this Tileset has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed. | |
| CesiumAsync::SharedFuture< void > & | getRootTileAvailableEvent () |
| A future that resolves when the details of the root tile of this tileset are available. The root tile may still be nullptr if the tileset failed to load (e.g., from an invalid URL). | |
| std::optional< CesiumUtility::Credit > | getUserCredit () const noexcept |
| Gets the CesiumUtility::Credit created from TilesetOptions::credit, if any. | |
| const std::vector< CesiumUtility::Credit > & | getTilesetCredits () const noexcept |
| Get tileset credits. | |
| void | setShowCreditsOnScreen (bool showCreditsOnScreen) noexcept |
| Sets whether or not the tileset's credits should be shown on screen. | |
| const CesiumUtility::CreditSource & | getCreditSource () const noexcept |
| Gets the CesiumUtility::CreditSource that identifies this tileset's credits with the CesiumUtility::CreditSystem. | |
| TilesetExternals & | getExternals () noexcept |
| Gets the TilesetExternals that summarize the external interfaces used by this tileset. | |
| const TilesetExternals & | getExternals () const noexcept |
| CesiumAsync::AsyncSystem & | getAsyncSystem () noexcept |
| Returns the CesiumAsync::AsyncSystem that is used for dispatching asynchronous tasks. | |
| const CesiumAsync::AsyncSystem & | getAsyncSystem () const noexcept |
| const TilesetOptions & | getOptions () const noexcept |
| Gets the TilesetOptions of this tileset. | |
| TilesetOptions & | getOptions () noexcept |
| const CesiumGeospatial::Ellipsoid & | getEllipsoid () const |
| Gets the CesiumGeospatial::Ellipsoid used by this tileset. | |
| CesiumGeospatial::Ellipsoid & | getEllipsoid () noexcept |
| const Tile * | getRootTile () const noexcept |
| Gets the root tile of this tileset. | |
| Tile * | getRootTile () noexcept |
| RasterOverlayCollection & | getOverlays () noexcept |
| Returns the RasterOverlayCollection of this tileset. | |
| const RasterOverlayCollection & | getOverlays () const noexcept |
| TilesetSharedAssetSystem & | getSharedAssetSystem () noexcept |
| Returns the TilesetSharedAssetSystem of this tileset. | |
| const TilesetSharedAssetSystem & | getSharedAssetSystem () const noexcept |
| const ViewUpdateResult & | updateViewOffline (const std::vector< ViewState > &frustums) |
| Updates this view but waits for all tiles that meet sse to finish loading and ready to be rendered before returning the function. This method is significantly slower than Tileset::updateView and should only be used for capturing movie or non-realtime situation. | |
| const ViewUpdateResult & | updateView (const std::vector< ViewState > &frustums, float deltaTime=0.0f) |
| Updates this view, returning the set of tiles to render in this view. | |
| int32_t | getNumberOfTilesLoaded () const |
| Gets the total number of tiles that are currently loaded. | |
| float | computeLoadProgress () noexcept |
| Gets the percentage of tiles that had been loaded for the default view group as of the last time it was updated. | |
| LoadedConstTileEnumerator | loadedTiles () const |
| Gets an object that can be used to enumerate the loaded tiles of this tileset. | |
| void | forEachLoadedTile (const std::function< void(const Tile &tile)> &callback) const |
| Invokes a function for each tile that is currently loaded. | |
| int64_t | getTotalDataBytes () const noexcept |
| Gets the total number of bytes of tile and raster overlay data that are currently loaded. | |
| const TilesetMetadata * | getMetadata (const Tile *pTile=nullptr) const |
| Gets the TilesetMetadata associated with the main or external tileset.json that contains a given tile. If the metadata is not yet loaded, this method returns nullptr. | |
| CesiumAsync::Future< const TilesetMetadata * > | loadMetadata () |
| Asynchronously loads the metadata associated with the main tileset.json. | |
| CesiumAsync::Future< SampleHeightResult > | sampleHeightMostDetailed (const std::vector< CesiumGeospatial::Cartographic > &positions) |
| Initiates an asynchronous query for the height of this tileset at a list of cartographic positions (longitude and latitude). The most detailed available tiles are used to determine each height. | |
| TilesetViewGroup & | getDefaultViewGroup () |
| Gets the default view group that is used when calling updateView. | |
| const TilesetViewGroup & | getDefaultViewGroup () const |
| const ViewUpdateResult & | updateViewGroup (TilesetViewGroup &viewGroup, const std::vector< ViewState > &frustums, float deltaTime=0.0f) |
| Updates a view group, returning the set of tiles to render in this view. | |
| const ViewUpdateResult & | updateViewGroupOffline (TilesetViewGroup &viewGroup, const std::vector< ViewState > &frustums) |
| Updates a view group, returning the set of tiles to render in this view. Unlike updateViewGroup, this method blocks the calling thread until all tiles suitable for the views have been loaded. | |
| void | loadTiles () |
| Loads the tiles that are currently deemed the most important, across all height queries and TilesetViewGroup instances. | |
| void | updateTileContent (Tile &tile) |
| Updates the content of the given tile based on its current state. | |
| void | registerLoadRequester (TileLoadRequester &requester) |
| Registers a tile load requester with this Tileset. Registered tile load requesters get to influence which tiles are loaded when loadTiles is called. | |
| bool | waitForAllLoadsToComplete (double maximumWaitTimeInMilliseconds) |
| Waits until no tile loads are in progress. This function must be called from the main thread, and it blocks the caller (does not return) until all tile loads are complete. | |
| Tileset (const Tileset &rhs)=delete | |
| Tileset & | operator= (const Tileset &rhs)=delete |
This supports both tileset.json and *.tileset.gltf assets, as well as layer.json quantized-mesh assets.
| Cesium3DTilesSelection::Tileset::Tileset | ( | const TilesetExternals & | externals, |
| std::unique_ptr< TilesetContentLoader > && | pCustomLoader, | ||
| std::unique_ptr< Tile > && | pRootTile, | ||
| const TilesetOptions & | options = TilesetOptions() ) |
| externals | The external interfaces to use. |
| pCustomLoader | The custom loader used to load the tileset and tile content. |
| pRootTile | The root tile that is associated with the custom loader |
| options | Additional options for the tileset. |
| const std::string & | url, | ||
| url | The URL of the tileset. |
| int64_t | ionAssetID, | ||
| const std::string & | ionAccessToken, | ||
| const TilesetOptions & | options = TilesetOptions(), | ||
| const std::string & | ionAssetEndpointUrl = "https://api.cesium.com/" ) |
| ionAssetID | The ID of the Cesium ion asset to use. |
| ionAccessToken | The Cesium ion access token authorizing access to the asset. |
| ionAssetEndpointUrl | The URL of the ion asset endpoint. Defaults to Cesium ion but a custom endpoint can be specified. |
| TilesetContentLoaderFactory && | loaderFactory, | ||
| loaderFactory | The factory to use to create the TilesetContentLoader. |
noexcept |
Destroying the tileset will immediately (before the destructor returns) unload as much tile content as possible. However, tiles that are currently in the process of being loaded cannot be unloaded immediately. These tiles will be unloaded asynchronously some time after this destructor returns. To be notified of completion of the async portion of the tileset destruction, subscribe to getAsyncDestructionCompleteEvent.
noexcept |
To get the load progress of a view group other than the default, call TilesetViewGroup::getPreviousLoadProgressPercentage.
| void Cesium3DTilesSelection::Tileset::forEachLoadedTile | ( | const std::function< void(const Tile &tile)> & | callback | ) | const |
| callback | The function to invoke. |
inlinenoexcept |
inlinenoexcept |
| TilesetViewGroup & Cesium3DTilesSelection::Tileset::getDefaultViewGroup | ( | ) |
| const TilesetViewGroup & Cesium3DTilesSelection::Tileset::getDefaultViewGroup | ( | ) | const |
inlinenoexcept |
inlinenoexcept |
inlinenoexcept |
| const TilesetMetadata * Cesium3DTilesSelection::Tileset::getMetadata | ( | const Tile * | pTile = nullptr | ) | const |
If this tileset's root tile is not yet available, this method returns nullptr.
If the tileset has a TilesetMetadata::schemaUri, it will not necessarily have been loaded yet.
If the provided tile is not the root tile of a tileset.json, this method walks up the Tile::getParent chain until it finds the closest root and then returns the metadata associated with the corresponding tileset.json.
Consider calling loadMetadata instead, which will return a future that only resolves after the root tile is loaded and the schemaUri, if any, has been resolved.
| pTile | The tile. If this parameter is nullptr, the metadata for the main tileset.json is returned. |
inlinenoexcept |
inlinenoexcept |
noexcept |
noexcept |
This may be nullptr if there is currently no root tile.
noexcept |
| CesiumAsync::SharedFuture< void > & Cesium3DTilesSelection::Tileset::getRootTileAvailableEvent | ( | ) |
Moreover, the root tile's content (e.g., 3D model) will not necessarily have been loaded yet when this future resolves.
noexcept |
| LoadedConstTileEnumerator Cesium3DTilesSelection::Tileset::loadedTiles | ( | ) | const |
Before the root tile is available, this method will return an enumerator that is empty, and that instance will remain empty even after the root tile is available.
Once the root tile is available (see getRootTile and getRootTileAvailableEvent), the returned instance will remain valid until the tileset is destroyed.
While the returned enumerator itself will remain valid as long as the Tileset does, a given iteration may be invalidated by any operation that modifies the Tile hierarchy.
| CesiumAsync::Future< const TilesetMetadata * > Cesium3DTilesSelection::Tileset::loadMetadata | ( | ) |
Before the returned future resolves, the root tile of this tileset will be loaded and the TilesetMetadata::schemaUri will be loaded if one has been specified.
If the tileset or schemaUri fail to load, the returned future will reject.
| void Cesium3DTilesSelection::Tileset::loadTiles | ( | ) |
In order to minimize tile load latency, this method should be called frequently, such as once per render frame. It will return quickly when there is no work to do.
| void Cesium3DTilesSelection::Tileset::registerLoadRequester | ( | TileLoadRequester & | requester | ) |
If the given requester is already registered with this Tileset, this method does nothing.
To unregister a load requester, call TileLoadRequester::unregister.
| requester | The requester to register. |
| CesiumAsync::Future< SampleHeightResult > Cesium3DTilesSelection::Tileset::sampleHeightMostDetailed | ( | const std::vector< CesiumGeospatial::Cartographic > & | positions | ) |
The height of the input positions is ignored. The output height is expressed in meters above the ellipsoid (usually WGS84), which should not be confused with a height above mean sea level.
Note that Tileset::updateView must be called periodically, or else the returned Future will never resolve. If you are not using this tileset for visualization, you can call updateView with an empty list of frustums.
| positions | The positions for which to sample heights. |
noexcept |
| showCreditsOnScreen | Whether the credits should be shown on screen. |
| void Cesium3DTilesSelection::Tileset::updateTileContent | ( | Tile & | tile | ) |
This may involve steps such as updating tile properties based on content, creating tile children, handling tile unloading, and more.
Tileset.| tile | The tile to update. |
| const ViewUpdateResult & Cesium3DTilesSelection::Tileset::updateView | ( | const std::vector< ViewState > & | frustums, |
| float | deltaTime = 0.0f ) |
Calling this method is equivalent to calling updateViewGroup with the default view group (getDefaultViewGroup) and then calling loadTiles.
| frustums | The ViewState's that the view should be updated for |
| deltaTime | The amount of time that has passed since the last call to updateView, in seconds. |
updateView or until the tileset is destroyed, whichever comes first. | const ViewUpdateResult & Cesium3DTilesSelection::Tileset::updateViewGroup | ( | TilesetViewGroup & | viewGroup, |
| const std::vector< ViewState > & | frustums, | ||
This method should typically be called once per "render frame", but it may be called at different rates for different view groups.
Users must also periodically call loadTiles, which will start or continue the asynchronous process of loading tiles that are needed across all view groups.
| viewGroup | The view group to update. The first time updateViewGroup is called, simply create a new TilesetViewGroup to pass as this parameter. For successive calls to updateViewGroup, pass this same instance. |
| frustums | The ViewState instances that are observing the tileset in this view group. |
updateViewGroup or until the view group is destroyed, whichever comes first. | const ViewUpdateResult & Cesium3DTilesSelection::Tileset::updateViewGroupOffline | ( | TilesetViewGroup & | viewGroup, |
| const std::vector< ViewState > & | frustums ) |
This method is significantly slower than updateViewGroup and should only be used for capturing a movie or for other non-realtime situations.
updateViewGroup or until the view group is destroyed, whichever comes first. | const ViewUpdateResult & Cesium3DTilesSelection::Tileset::updateViewOffline | ( | const std::vector< ViewState > & | frustums | ) |
updateView or until the tileset is destroyed, whichever comes first. | bool Cesium3DTilesSelection::Tileset::waitForAllLoadsToComplete | ( | double | maximumWaitTimeInMilliseconds | ) |
| maximumWaitTimeInMilliseconds | The maximum time to wait for tile loads to complete, in milliseconds. If this time is exceeded, the function will return even if some tile loads are still in progress. |
