Cesium3DTilesSelection::TilesetExternals Class Referencefinal
External interfaces used by a Tileset. More...
#include <Cesium3DTilesSelection/TilesetExternals.h>
std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor
 An external CesiumAsync::IAssetAccessor.
std::shared_ptr< IPrepareRendererResources > pPrepareRendererResources
 An external IPrepareRendererResources.
CesiumAsync::AsyncSystem asyncSystem
 The async system to use to do work in threads.
std::shared_ptr< CesiumUtility::CreditSystem > pCreditSystem
 An external CesiumUtility::CreditSystem that can be used to manage credit strings and periodically query which credits to show and and which to remove from the screen.
std::shared_ptr< spdlog::logger > pLogger = spdlog::default_logger()
 A spdlog logger that will receive log messages.
std::shared_ptr< TileOcclusionRendererProxyPool > pTileOcclusionProxyPool
 A pool of renderer proxies to determine the occlusion state of tile bounding volumes.
CesiumUtility::IntrusivePointer< TilesetSharedAssetSystem > pSharedAssetSystem
 The shared asset system used to facilitate sharing of common assets, such as images, between and within tilesets.
std::shared_ptr< GltfModifier > pGltfModifier = {}
Not supposed to be used by clients.
Definition at line 30 of file TilesetExternals.h.
◆ asyncSystem
CesiumAsync::AsyncSystem Cesium3DTilesSelection::TilesetExternals::asyncSystem
The tileset will automatically call CesiumAsync::AsyncSystem::dispatchMainThreadTasks from Tileset::updateView.
Definition at line 49 of file TilesetExternals.h.
◆ pAssetAccessor
std::shared_ptr<CesiumAsync::IAssetAccessor> Cesium3DTilesSelection::TilesetExternals::pAssetAccessor
Definition at line 35 of file TilesetExternals.h.
◆ pCreditSystem
std::shared_ptr<CesiumUtility::CreditSystem> Cesium3DTilesSelection::TilesetExternals::pCreditSystem
Definition at line 56 of file TilesetExternals.h.
◆ pGltfModifier
std::shared_ptr<GltfModifier> Cesium3DTilesSelection::TilesetExternals::pGltfModifier = {}
Optional user-controlled tile loading post-processing stage that can modify the glTF meshes (e.g., split or merge them).
See also
Cesium3DTilesSelection::GltfModifier
Definition at line 88 of file TilesetExternals.h.
◆ pLogger
std::shared_ptr<spdlog::logger> Cesium3DTilesSelection::TilesetExternals::pLogger = spdlog::default_logger()
If not specified, defaults to spdlog::default_logger().
Definition at line 63 of file TilesetExternals.h.
◆ pPrepareRendererResources
std::shared_ptr<IPrepareRendererResources> Cesium3DTilesSelection::TilesetExternals::pPrepareRendererResources
Definition at line 40 of file TilesetExternals.h.
◆ pSharedAssetSystem
CesiumUtility::IntrusivePointer<TilesetSharedAssetSystem> Cesium3DTilesSelection::TilesetExternals::pSharedAssetSystem
Initial value:
static CesiumUtility::IntrusivePointer< TilesetSharedAssetSystem > getDefault()
Obtains an IntrusivePointer to the TilesetSharedAssetSystem singleton.
Definition at line 79 of file TilesetExternals.h.
◆ pTileOcclusionProxyPool
std::shared_ptr<TileOcclusionRendererProxyPool> Cesium3DTilesSelection::TilesetExternals::pTileOcclusionProxyPool
Initial value:
nullptr
If not specified, the traversal will not attempt to leverage occlusion information.
Definition at line 72 of file TilesetExternals.h.
