cesium-native 0.67.0
The state of the view that is used during the traversal of a tileset. More...
#include <Cesium3DTilesSelection/ViewState.h>
| ViewState (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, const glm::dvec2 &viewportSize, double horizontalFieldOfView, double verticalFieldOfView, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new instance. | |
| ViewState (const glm::dmat4 &viewMatrix, const glm::dmat4 &projectionMatrix, const glm::dvec2 &viewportSize, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new instance of a view state with a general projection, including skewed perspective and orthographic projections. | |
| ViewState (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, const glm::dvec2 &viewportSize, double left, double right, double bottom, double top, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new instance of a view state with an orthographic projection. | |
| ViewState (const Cesium3DTiles::BoundingVolume &boundingVolume, std::shared_ptr< ViewStateMeasureDelegate > pMeasureDelegate, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new instance of a view state from a bounding volume associated with a geographic area, as opposed to a viewing projection. This constructor does not specify a viewport, and so doesn't use Screen Space Error (SSE) as a selection criteria. Instead, a user-supplied functor object calculates a measure used as a standin for SSE. | |
| const glm::dvec3 & | getPosition () const noexcept |
| Gets the position of the camera in Earth-centered, Earth-fixed coordinates. | |
| const glm::dvec3 & | getDirection () const noexcept |
| Gets the look direction of the camera in Earth-centered, Earth-fixed coordinates. | |
| glm::dvec3 | getUp () const noexcept |
| Gets the up direction of the camera in Earth-centered, Earth-fixed coordinates. | |
| const std::optional< CesiumGeospatial::Cartographic > & | getPositionCartographic () const noexcept |
| Gets the position of the camera as a longitude / latitude / height. | |
| const glm::dvec2 & | getViewportSize () const noexcept |
| Gets the size of the viewport in pixels. | |
| double | getHorizontalFieldOfView () const noexcept |
| Gets the horizontal field-of-view angle in radians. This is only valid for a symmetric perspective projection. | |
| double | getVerticalFieldOfView () const noexcept |
| Gets the vertical field-of-view angle in radians. This is only valid for a symmetric perspective projection. | |
| const glm::dmat4 & | getViewMatrix () const noexcept |
| Gets the view matrix for the ViewState. | |
| const glm::dmat4 & | getProjectionMatrix () const noexcept |
| Gets the projection matrix for the ViewState. | |
| bool | isBoundingVolumeVisible (const Cesium3DTiles::BoundingVolume &boundingVolume) const noexcept |
| Returns whether the given Cesium3DTiles::BoundingVolume is visible for this camera. | |
| double | computeDistanceSquaredToBoundingVolume (const Cesium3DTiles::BoundingVolume &boundingVolume) const noexcept |
| Computes the squared distance to the given Cesium3DTiles::BoundingVolume. | |
| double | computeScreenSpaceError (double geometricError, double distance) const noexcept |
| Computes the screen space error from a given geometric error. | |
| double | computeScreenSpaceError (const Tile &tile, double distance, uint32_t depth) const noexcept |
| Computes the screen space error. | |
| bool | isContentVisible (const Tile &tile) const noexcept |
| Reports whether a tile's content is visible. This will use the ViewStateVisibilityDelegate on this ViewState if specified, otherwise this returns true by default. | |
| std::shared_ptr< ViewStateMeasureDelegate > | getMeasureDelegate () const |
| Get the measure delegate object. | |
| void | setMeasureDelegate (std::shared_ptr< ViewStateMeasureDelegate > pMeasureDelegate) |
| Set the measure delegate object. | |
| std::shared_ptr< ViewStateVisibilityDelegate > | getVisibilityDelegate () const |
| Get the visibility delegate object. | |
| void | setVisibilityDelegate (std::shared_ptr< ViewStateVisibilityDelegate > pVisibilityDelegate) |
| Set the visibility delegate object. | |
| static ViewState | create (const glm::dvec3 &position, const glm::dvec3 &direction, const glm::dvec3 &up, const glm::dvec2 &viewportSize, double horizontalFieldOfView, double verticalFieldOfView, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) |
| Creates a new instance of a view state with a symmetric perspective projection. | |
An instance of a view state can be created with the create function.
Definition at line 81 of file ViewState.h.
| Cesium3DTilesSelection::ViewState::ViewState | ( | const glm::dvec3 & | position, |
| const glm::dvec3 & | direction, | ||
| const glm::dvec3 & | up, | ||
| const glm::dvec2 & | viewportSize, | ||
| double | horizontalFieldOfView, | ||
| double | verticalFieldOfView, | ||
| const CesiumGeospatial::Ellipsoid & | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) |
| position | The position of the eye point of the camera. |
| direction | The view direction vector of the camera. |
| up | The up vector of the camera. |
| viewportSize | The size of the viewport, in pixels. |
| horizontalFieldOfView | The horizontal field-of-view (opening) angle of the camera, in radians. |
| verticalFieldOfView | The vertical field-of-view (opening) angle of the camera, in radians. |
| ellipsoid | The ellipsoid that will be used to compute the cartographic position from the cartesian position. Default value: CesiumGeospatial::Ellipsoid::WGS84. |
| Cesium3DTilesSelection::ViewState::ViewState | ( | const glm::dmat4 & | viewMatrix, |
| const glm::dmat4 & | projectionMatrix, | ||
| viewMatrix | The view's view matrix i.e., the inverse of its pose |
| projectionMatrix | see e.g. CesiumGeometry::Transforms::createPerspectiveMatrix |
| double | left, | ||
| double | right, | ||
| double | bottom, | ||
| double | top, | ||
| left | left distance of near plane edge from center |
| right | right distance of near plane edge |
| bottom | bottom distance of near plane edge |
| top | top distance of near plane edge |
| Cesium3DTilesSelection::ViewState::ViewState | ( | const Cesium3DTiles::BoundingVolume & | boundingVolume, |
| std::shared_ptr< ViewStateMeasureDelegate > | pMeasureDelegate, | ||
| boundingVolume | The geographic viewing volume |
| pMeasureDelegate | std::shared_ptr to the delegate that implements measure calculation |
| ellipsoid | The ellipsoid that will be used to compute the cartographic position and other parameters for tile selection. |
noexcept |
Computes the squared euclidean distance from the position of this camera to the closest point of the given bounding volume.
| boundingVolume | The bounding volume |
noexcept |
Computes the screen space error (SSE) that results from a tile's geometric error, when it is viewed with this camera at the specified distance.
The given distance will be clamped to a small positive value if it is negative or too close to zero.
If the ViewState object was created with a measure delegate, that is called for this computation. Otherwise. the projection-based screen space error calculation is performed.
| tile | The tile |
| distance | The tile's distance from the ViewState origin. |
| depth | The tile's depth in in the tileset hierarchy. |
noexcept |
Computes the screen space error (SSE) that results from the given geometric error, when it is viewed with this camera from the given distance.
| geometricError | The geometric error |
| distance | The viewing distance |
static |
inlinenoexcept |
Definition at line 199 of file ViewState.h.
Definition at line 339 of file ViewState.h.
inlinenoexcept |
Definition at line 193 of file ViewState.h.
inlinenoexcept |
The result may be std::nullopt if the Cartesian position is very near the center of the Ellipsoid.
Definition at line 219 of file ViewState.h.
inlinenoexcept |
Definition at line 250 of file ViewState.h.
inlinenoexcept |
Definition at line 205 of file ViewState.h.
inlinenoexcept |
Definition at line 245 of file ViewState.h.
inlinenoexcept |
Definition at line 226 of file ViewState.h.
Definition at line 356 of file ViewState.h.
noexcept |
Returns whether the given bounding volume is visible for this camera, meaning that the given volume is at least partially contained in the frustum of this camera.
inlinenoexcept |
| tile | The tile. |
Definition at line 328 of file ViewState.h.
| pMeasureDelegate | The measure delegate. |
Definition at line 347 of file ViewState.h.
| pVisibilityDelegate | The visibility delegate. |
Definition at line 364 of file ViewState.h.
