CesiumRasterOverlays::RasterOverlay Class Referenceabstract
The base class for a rasterized image that can be draped over a Cesium3DTilesSelection::Tileset. The image may be very, very high resolution, so only small pieces of it are mapped to the Tileset at a time. More...
#include <CesiumRasterOverlays/RasterOverlay.h>
Inheritance diagram for CesiumRasterOverlays::RasterOverlay:
CesiumUtility::ReferenceCounted< T, false > CesiumRasterOverlays::AzureMapsRasterOverlay CesiumRasterOverlays::BingMapsRasterOverlay CesiumRasterOverlays::DebugColorizeTilesRasterOverlay CesiumRasterOverlays::GoogleMapTilesRasterOverlay CesiumRasterOverlays::IonRasterOverlay CesiumRasterOverlays::RasterizedPolygonsOverlay CesiumRasterOverlays::TileMapServiceRasterOverlay CesiumRasterOverlays::UrlTemplateRasterOverlay CesiumRasterOverlays::WebMapServiceRasterOverlay CesiumRasterOverlays::WebMapTileServiceRasterOverlay CesiumVectorOverlays::GeoJsonDocumentRasterOverlay CesiumVectorOverlays::VectorTilesRasterOverlay
Public Types
using CreateTileProviderResult
 A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful.
 RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
 Creates a new instance.
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem)
 A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
const std::string & getName () const noexcept
 Gets the name of this overlay.
RasterOverlayOptions & getOptions () noexcept
 Gets options for this overlay.
const RasterOverlayOptions & getOptions () const noexcept
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Activates this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider (const CreateRasterOverlayTileProviderParameters &parameters) const =0
 Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future.
void addReference () const
Instances of this class can be added to the Cesium3DTilesSelection::RasterOverlayCollection that is returned by Cesium3DTilesSelection::Tileset::getOverlays.
Instances of this class must be allocated on the heap, and their lifetimes must be managed with CesiumUtility::IntrusivePointer.
See also
IonRasterOverlay
Definition at line 140 of file RasterOverlay.h.
Member Typedef Documentation
◆ CreateTileProviderResult
Initial value:
nonstd::expected<
Details on a failure while attempting to load a raster overlay tile.
Definition at line 219 of file RasterOverlay.h.
◆ RasterOverlay()
CesiumRasterOverlays::RasterOverlay::RasterOverlay ( const std::string & name,
const RasterOverlayOptions & overlayOptions = RasterOverlayOptions() )
nameThe user-given name of this overlay layer.
overlayOptionsThe RasterOverlayOptions for this instance.
◆ activate()
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > CesiumRasterOverlays::RasterOverlay::activate ( const RasterOverlayExternals & externals,
const CesiumGeospatial::Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) const
This method is called by a Cesium3DTilesSelection::RasterOverlayCollection when an overlay is added to it. The returned ActivatedRasterOverlay is used by the collection to manage the overlay.
externalsThe external interfaces for use by the raster overlay.
The activated overlay.
◆ createPlaceholder()
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > CesiumRasterOverlays::RasterOverlay::createPlaceholder ( const RasterOverlayExternals & externals,
The placeholder.
◆ createTileProvider()
virtual CesiumAsync::Future< CreateTileProviderResult > CesiumRasterOverlays::RasterOverlay::createTileProvider ( const CreateRasterOverlayTileProviderParameters & parameters) const
pure virtual
◆ getAsyncDestructionCompleteEvent()
CesiumAsync::SharedFuture< void > & CesiumRasterOverlays::RasterOverlay::getAsyncDestructionCompleteEvent ( const CesiumAsync::AsyncSystem & asyncSystem)
asyncSystemThe AsyncSystem to use for the returned SharedFuture, if required. If this method is called multiple times, all invocations must pass CesiumAsync::AsyncSystem instances that compare equal to each other.
◆ getName()
const std::string & CesiumRasterOverlays::RasterOverlay::getName ( ) const
inlinenoexcept
Definition at line 170 of file RasterOverlay.h.
◆ getOptions() [1/2]
const RasterOverlayOptions & CesiumRasterOverlays::RasterOverlay::getOptions ( ) const
inlinenoexcept
Definition at line 178 of file RasterOverlay.h.
◆ getOptions() [2/2]
inlinenoexcept
Definition at line 175 of file RasterOverlay.h.
