CesiumGeospatial::BoundingRegion Class Referencefinal
A bounding volume specified as a longitude/latitude bounding box and a minimum and maximum height. More...
#include <CesiumGeospatial/BoundingRegion.h>
 BoundingRegion (const GlobeRectangle &rectangle, double minimumHeight, double maximumHeight, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Constructs a new bounding region.
const GlobeRectangle & getRectangle () const noexcept
 Gets the bounding rectangle of the region.
double getMinimumHeight () const noexcept
 Gets the minimum height of the region.
double getMaximumHeight () const noexcept
 Gets the maximum height of the region.
const CesiumGeometry::OrientedBoundingBox & getBoundingBox () const noexcept
 Gets an oriented bounding box containing this region.
CesiumGeometry::CullingResult intersectPlane (const CesiumGeometry::Plane &plane) const noexcept
 Determines on which side of a plane the bounding region is located.
double computeDistanceSquaredToPosition (const glm::dvec3 &position, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept
 Computes the distance-squared from a position in ellipsoid-centered Cartesian coordinates to the closest point in this bounding region.
double computeDistanceSquaredToPosition (const Cartographic &position, const Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept
 Computes the distance-squared from a longitude-latitude-height position to the closest point in this bounding region.
double computeDistanceSquaredToPosition (const Cartographic &cartographicPosition, const glm::dvec3 &cartesianPosition) const noexcept
 Computes the distance-squared from a position to the closest point in this bounding region, when the longitude-latitude-height and ellipsoid-centered Cartesian coordinates of the position are both already known.
BoundingRegion computeUnion (const BoundingRegion &other, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept
 Computes the union of this bounding region with another.
static bool equals (const BoundingRegion &left, const BoundingRegion &right) noexcept
 Checks whether two bounding regions are exactly equal.
static bool equalsEpsilon (const BoundingRegion &left, const BoundingRegion &right, double relativeEpsilon) noexcept
 Checks whether two bounding regions are equal up to a given relative epsilon.
Definition at line 20 of file BoundingRegion.h.
◆ BoundingRegion()
CesiumGeospatial::BoundingRegion::BoundingRegion ( const GlobeRectangle & rectangle,
const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 )
rectangleThe bounding rectangle of the region.
minimumHeightThe minimum height in meters.
maximumHeightThe maximum height in meters.
ellipsoidThe ellipsoid on which this region is defined.
◆ computeDistanceSquaredToPosition() [1/3]
double CesiumGeospatial::BoundingRegion::computeDistanceSquaredToPosition ( const Cartographic & cartographicPosition,
const glm::dvec3 & cartesianPosition ) const
noexcept
cartographicPositionThe position as a longitude-latitude-height.
cartesianPositionThe position as ellipsoid-centered Cartesian coordinates.
The distance-squared from the position to the closest point in the bounding region.
◆ computeDistanceSquaredToPosition() [2/3]
double CesiumGeospatial::BoundingRegion::computeDistanceSquaredToPosition ( const Cartographic & position,
const Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) const
noexcept
positionThe position.
◆ computeDistanceSquaredToPosition() [3/3]
double CesiumGeospatial::BoundingRegion::computeDistanceSquaredToPosition ( const glm::dvec3 & position,
noexcept
If the position cannot be converted into cartograpic coordinates for the given ellipsoid (because it is close to the center of the ellipsoid), then this function will return the squared distance between the given position and the closest point of the bounding box that is enclosed in this region.
◆ computeUnion()
BoundingRegion CesiumGeospatial::BoundingRegion::computeUnion ( const BoundingRegion & other,
const CesiumGeospatial::Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) const
noexcept
otherThe other bounding region.
The union.
◆ equals()
static bool CesiumGeospatial::BoundingRegion::equals ( const BoundingRegion & left,
const BoundingRegion & right )
staticnoexcept
leftThe first region.
rightThe second region.
Whether the regions are equal
◆ equalsEpsilon()
static bool CesiumGeospatial::BoundingRegion::equalsEpsilon ( const BoundingRegion & left,
const BoundingRegion & right,
double relativeEpsilon )
staticnoexcept
relativeEpsilonThe relative epsilon.
Whether the regions are epsilon-equal
◆ getBoundingBox()
const CesiumGeometry::OrientedBoundingBox & CesiumGeospatial::BoundingRegion::getBoundingBox ( ) const
inlinenoexcept
Definition at line 56 of file BoundingRegion.h.
◆ getMaximumHeight()
double CesiumGeospatial::BoundingRegion::getMaximumHeight ( ) const
inlinenoexcept
Definition at line 51 of file BoundingRegion.h.
◆ getMinimumHeight()
double CesiumGeospatial::BoundingRegion::getMinimumHeight ( ) const
inlinenoexcept
Definition at line 46 of file BoundingRegion.h.
◆ getRectangle()
const GlobeRectangle & CesiumGeospatial::BoundingRegion::getRectangle ( ) const
inlinenoexcept
Definition at line 39 of file BoundingRegion.h.
◆ intersectPlane()
CesiumGeometry::CullingResult CesiumGeospatial::BoundingRegion::intersectPlane ( const CesiumGeometry::Plane & plane) const
noexcept
planeThe plane to test against.
The CesiumGeometry::CullingResult
  • Inside if the entire region is on the side of the plane the normal is pointing.
  • Outside if the entire region is on the opposite side.
  • Intersecting if the region intersects the plane.
