A factory for creating a TilesetContentLoader for assets from Cesium ion. More...
#include <Cesium3DTilesSelection/CesiumIonTilesetContentLoaderFactory.h>
| CesiumIonTilesetContentLoaderFactory (uint32_t ionAssetID, const std::string &ionAccessToken, const std::string &ionAssetEndpointUrl="https://api.cesium.com/") | |
| Creates a new factory for loading a Cesium ion asset. | |
| virtual CesiumAsync::Future< Cesium3DTilesSelection::TilesetContentLoaderResult< Cesium3DTilesSelection::TilesetContentLoader > > | createLoader (const TilesetExternals &externals, const TilesetOptions &tilesetOptions, const AuthorizationHeaderChangeListener &headerChangeListener) override |
| Creates an instance of the loader corresponding to this factory. | |
| virtual bool | isValid () const override |
| Returns true if a valid TilesetContentLoader can be constructed from this factory. | |
Public Types inherited from Cesium3DTilesSelection::TilesetContentLoaderFactory | |
| using | AuthorizationHeaderChangeListener |
| The type of a callback called when the Authorization header used by a tileset loader has changed. | |
Definition at line 16 of file CesiumIonTilesetContentLoaderFactory.h.
| Cesium3DTilesSelection::CesiumIonTilesetContentLoaderFactory::CesiumIonTilesetContentLoaderFactory | ( | uint32_t | ionAssetID, |
| const std::string & | ionAccessToken, | ||
| const std::string & | ionAssetEndpointUrl = "https://api.cesium.com/" ) |
| ionAssetID | The Cesium ion asset ID to load. |
| ionAccessToken | The Cesium ion token to use to authorize requests to this asset. |
| ionAssetEndpointUrl | The Cesium ion endpoint to use. This can be changed to point to an instance of Cesium ion Self-Hosted. |
overridevirtual |
| externals | The TilesetExternals. |
| tilesetOptions | The TilesetOptions. |
| headerChangeListener | A callback that will be called when the Authorization header used by the tileset loader has changed. |
Implements Cesium3DTilesSelection::TilesetContentLoaderFactory.
overridevirtual |
