CesiumGeometry::QuadtreeTileID Struct Referencefinal
Uniquely identifies a node in a quadtree. More...
#include <CesiumGeometry/QuadtreeTileID.h>
constexpr QuadtreeTileID (uint32_t level_, uint32_t x_, uint32_t y_) noexcept
 Creates a new instance.
constexpr bool operator== (const QuadtreeTileID &other) const noexcept
 Returns true if two identifiers are equal.
constexpr bool operator!= (const QuadtreeTileID &other) const noexcept
 Returns true if two identifiers are not equal.
uint32_t computeInvertedX (const QuadtreeTilingScheme &tilingScheme) const noexcept
 Computes the inverse x-coordinate of this tile ID.
uint32_t computeInvertedY (const QuadtreeTilingScheme &tilingScheme) const noexcept
 Computes the inverse y-coordinate of this tile ID.
constexpr QuadtreeTileID getParent () const noexcept
 Gets the ID of the parent of the tile with this ID.
uint32_t level
 The level of this tile ID, with 0 being the root tile.
uint32_t x
 The x-coordinate of this tile ID.
uint32_t y
 The y-coordinate of this tile ID.
This is one form of a Cesium3DTilesSelection::TileID.
The identifier is composed of the level (with 0 being the level of the root tile), the x- and y-coordinate of the tile, referring to a grid coordinate system at the respective level.
Definition at line 20 of file QuadtreeTileID.h.
◆ QuadtreeTileID()
CesiumGeometry::QuadtreeTileID::QuadtreeTileID ( uint32_t level_,
uint32_t x_,
uint32_t y_ )
inlineconstexprnoexcept
level_The level of the node, with 0 being the root
x_The x-coordinate of the tile
y_The y-coordinate of the tile
Definition at line 29 of file QuadtreeTileID.h.
◆ computeInvertedX()
uint32_t CesiumGeometry::QuadtreeTileID::computeInvertedX ( const QuadtreeTilingScheme & tilingScheme) const
noexcept
This will compute the inverse x-coordinate of this tile ID, based on the given tiling scheme, which provides the number of tiles in x-direction for the level of this tile ID.
tilingSchemeThe QuadtreeTilingScheme.
The inverted x-coordinate.
◆ computeInvertedY()
uint32_t CesiumGeometry::QuadtreeTileID::computeInvertedY ( const QuadtreeTilingScheme & tilingScheme) const
noexcept
This will compute the inverse y-coordinate of this tile ID, based on the given tiling scheme, which provides the number of tiles in y-direction for the level of this tile ID.
The inverted y-coordinate.
◆ getParent()
QuadtreeTileID CesiumGeometry::QuadtreeTileID::getParent ( ) const
If this method is called on a level zero tile, it returns itself.
The ID of the parent tile.
Definition at line 80 of file QuadtreeTileID.h.
◆ operator!=()
bool CesiumGeometry::QuadtreeTileID::operator!= ( const QuadtreeTileID & other) const
Definition at line 43 of file QuadtreeTileID.h.
◆ operator==()
bool CesiumGeometry::QuadtreeTileID::operator== ( const QuadtreeTileID & other) const
Definition at line 35 of file QuadtreeTileID.h.
◆ level
uint32_t CesiumGeometry::QuadtreeTileID::level
Definition at line 90 of file QuadtreeTileID.h.
◆ x
uint32_t CesiumGeometry::QuadtreeTileID::x
Definition at line 95 of file QuadtreeTileID.h.
◆ y
uint32_t CesiumGeometry::QuadtreeTileID::y
Definition at line 100 of file QuadtreeTileID.h.
