CesiumGltf::Model Struct Reference
This class is not meant to be instantiated directly. Use Model instead. More...
#include <CesiumGltf/Model.h>
Inheritance diagram for CesiumGltf::Model:
CesiumGltf::ModelSpec CesiumUtility::ExtensibleObject
Public Types
typedef void ForEachRootNodeInSceneCallback(Model &gltf, Node &node)
 A callback function for forEachRootNodeInScene.
typedef void ForEachRootNodeInSceneConstCallback(const Model &gltf, const Node &node)
typedef void ForEachNodeInSceneCallback(Model &gltf, Node &node, const glm::dmat4 &transform)
 A callback function for forEachNodeInScene.
typedef void ForEachNodeInSceneConstCallback(const Model &gltf, const Node &node, const glm::dmat4 &transform)
typedef void ForEachPrimitiveInSceneCallback(Model &gltf, Node &node, Mesh &mesh, MeshPrimitive &primitive, const glm::dmat4 &transform)
 A callback function for forEachPrimitiveInScene.
typedef void ForEachPrimitiveInSceneConstCallback(const Model &gltf, const Node &node, const Mesh &mesh, const MeshPrimitive &primitive, const glm::dmat4 &transform)
CesiumUtility::ErrorList merge (Model &&rhs)
 Merges another model into this one.
void forEachRootNodeInScene (int32_t sceneID, std::function< ForEachRootNodeInSceneCallback > &&callback)
 Apply the given callback to the root nodes of the scene.
void forEachRootNodeInScene (int32_t sceneID, std::function< ForEachRootNodeInSceneConstCallback > &&callback) const
void forEachNodeInScene (int32_t sceneID, std::function< ForEachNodeInSceneCallback > &&callback)
 Apply the given callback to all nodes in the scene.
void forEachNodeInScene (int32_t sceneID, std::function< ForEachNodeInSceneConstCallback > &&callback) const
void forEachPrimitiveInScene (int32_t sceneID, std::function< ForEachPrimitiveInSceneCallback > &&callback)
 Apply the given callback to all relevant primitives.
void forEachPrimitiveInScene (int32_t sceneID, std::function< ForEachPrimitiveInSceneConstCallback > &&callback) const
void generateMissingNormalsSmooth ()
 Fills in smooth normals for any primitives with missing normals.
void addExtensionUsed (const std::string &extensionName)
 Adds an extension to the ModelSpec::extensionsUsed property, if it is not already present.
void addExtensionRequired (const std::string &extensionName)
 Adds an extension to the ModelSpec::extensionsRequired property, if it is not already present.
void removeExtensionUsed (const std::string &extensionName)
 Removes an extension from the ModelSpec::extensionsUsed property.
void removeExtensionRequired (const std::string &extensionName)
 Removes an extension from the ModelSpec::extensionsRequired property.
bool isExtensionUsed (const std::string &extensionName) const noexcept
 Determines whether a given extension name is listed in the model's ModelSpec::extensionsUsed property.
bool isExtensionRequired (const std::string &extensionName) const noexcept
 Determines whether a given extension name is listed in the model's ModelSpec::extensionsRequired property.
- Public Member Functions inherited from CesiumGltf::ModelSpec
static const T & getSafe (const std::vector< T > &items, int32_t index)
 Safely gets the element with a given index, returning a default instance if the index is outside the range.
static const T * getSafe (const std::vector< T > *pItems, int32_t index) noexcept
 Safely gets a pointer to the element with a given index, returning nullptr if the index is outside the range.
static T * getSafe (std::vector< T > *pItems, int32_t index) noexcept
Additional Inherited Members
- Public Attributes inherited from CesiumGltf::ModelSpec
std::vector< std::string > extensionsUsed
 Names of glTF extensions used in this asset.
std::vector< std::string > extensionsRequired
 Names of glTF extensions required to properly load this asset.
std::vector< CesiumGltf::Accessor > accessors
 An array of accessors.
std::vector< CesiumGltf::Animation > animations
 An array of keyframe animations.
CesiumGltf::Asset asset
 Metadata about the glTF asset.
std::vector< CesiumGltf::Buffer > buffers
 An array of buffers.
std::vector< CesiumGltf::BufferView > bufferViews
 An array of bufferViews.
std::vector< CesiumGltf::Camera > cameras
 An array of cameras.
std::vector< CesiumGltf::ExternalAsset > externalAssets
 An array of external assets.
std::vector< CesiumGltf::File > files
 An array of file references.
std::vector< CesiumGltf::Image > images
 An array of images.
std::vector< CesiumGltf::Material > materials
 An array of materials.
std::vector< CesiumGltf::Mesh > meshes
 An array of meshes.
std::vector< CesiumGltf::Node > nodes
 An array of nodes.
std::vector< CesiumGltf::Sampler > samplers
 An array of samplers.
int32_t scene = -1
 The index of the default scene.
std::vector< CesiumGltf::Scene > scenes
 An array of scenes.
std::vector< CesiumGltf::Shape > shapes
 An array of shapes.
std::vector< CesiumGltf::Skin > skins
 An array of skins.
std::vector< CesiumGltf::Texture > textures
 An array of textures.
- Static Public Attributes inherited from CesiumGltf::ModelSpec
static constexpr const char * TypeName = "Model"
- Protected Member Functions inherited from CesiumGltf::ModelSpec
 ModelSpec ()=default
Definition at line 14 of file Model.h.
Member Typedef Documentation
◆ ForEachNodeInSceneCallback
typedef void CesiumGltf::Model::ForEachNodeInSceneCallback(Model &gltf, Node &node, const glm::dmat4 &transform)
Definition at line 73 of file Model.h.
◆ ForEachNodeInSceneConstCallback
typedef void CesiumGltf::Model::ForEachNodeInSceneConstCallback(const Model &gltf, const Node &node, const glm::dmat4 &transform)
Definition at line 105 of file Model.h.
◆ ForEachPrimitiveInSceneCallback
typedef void CesiumGltf::Model::ForEachPrimitiveInSceneCallback(Model &gltf, Node &node, Mesh &mesh, MeshPrimitive &primitive, const glm::dmat4 &transform)
Definition at line 118 of file Model.h.
◆ ForEachPrimitiveInSceneConstCallback
typedef void CesiumGltf::Model::ForEachPrimitiveInSceneConstCallback(const Model &gltf, const Node &node, const Mesh &mesh, const MeshPrimitive &primitive, const glm::dmat4 &transform)
Definition at line 153 of file Model.h.
◆ ForEachRootNodeInSceneCallback
typedef void CesiumGltf::Model::ForEachRootNodeInSceneCallback(Model &gltf, Node &node)
Definition at line 33 of file Model.h.
◆ ForEachRootNodeInSceneConstCallback
typedef void CesiumGltf::Model::ForEachRootNodeInSceneConstCallback(const Model &gltf, const Node &node)
Definition at line 39 of file Model.h.
◆ addExtensionRequired()
void CesiumGltf::Model::addExtensionRequired ( const std::string & extensionName)
Calling this function also adds the extension to extensionsUsed, if it's not already present.
extensionNameThe name of the required extension.
◆ addExtensionUsed()
void CesiumGltf::Model::addExtensionUsed ( const std::string & extensionName)
extensionNameThe name of the used extension.
◆ forEachNodeInScene() [1/2]
void CesiumGltf::Model::forEachNodeInScene ( int32_t sceneID,
std::function< ForEachNodeInSceneCallback > && callback )
If the given sceneID is non-negative and exists in the given glTF, then the given callback will be applied to all nodes in this scene.
If the given sceneId is negative, then the nodes that the callback will be applied to depends on the structure of the glTF model:
  • If the glTF model has a default scene, then it will be applied to all nodes in the default scene.
  • Otherwise, it will be applied to all nodes in the first scene.
  • Otherwise (if the glTF model does not contain any scenes), it will be applied to the first node.
  • Otherwise (if there are no scenes and no nodes), then this method will do nothing.
sceneIDThe scene ID (index)
callbackThe callback to apply
◆ forEachNodeInScene() [2/2]
std::function< ForEachNodeInSceneConstCallback > && callback ) const
◆ forEachPrimitiveInScene() [1/2]
void CesiumGltf::Model::forEachPrimitiveInScene ( int32_t sceneID,
std::function< ForEachPrimitiveInSceneCallback > && callback )
If the given sceneID is non-negative and exists in the given glTF, then the given callback will be applied to all meshes of this scene.
If the given sceneId is negative, then the meshes that the callback will be applied to depends on the structure of the glTF model:
  • If the glTF model has a default scene, then it will be applied to all meshes of the default scene.
  • Otherwise, it will be applied to all meshes of the the first scene.
  • Otherwise (if the glTF model does not contain any scenes), it will be applied to all meshes that can be found by starting a traversal at the root node.
  • Otherwise (if there are no scenes and no nodes), then all meshes will be traversed.
◆ forEachPrimitiveInScene() [2/2]
std::function< ForEachPrimitiveInSceneConstCallback > && callback ) const
◆ forEachRootNodeInScene() [1/2]
void CesiumGltf::Model::forEachRootNodeInScene ( int32_t sceneID,
std::function< ForEachRootNodeInSceneCallback > && callback )
If the given sceneID is non-negative and exists in the given glTF, then the given callback will be applied to all root nodes of this scene.
  • If the glTF model has a default scene, then it will be applied to all root nodes of the default scene.
  • Otherwise, it will be applied to all root nodes of the first scene.
◆ forEachRootNodeInScene() [2/2]
std::function< ForEachRootNodeInSceneConstCallback > && callback ) const
◆ getSafe() [1/3]
static const T & CesiumGltf::Model::getSafe ( const std::vector< T > & items,
int32_t index )
inlinestatic
Template Parameters
TThe type of the array.
itemsThe array.
indexThe index of the array element to retrieve.
The requested element, or a default instance if the index is invalid.
Definition at line 181 of file Model.h.
◆ getSafe() [2/3]
static const T * CesiumGltf::Model::getSafe ( const std::vector< T > * pItems,
int32_t index )
inlinestaticnoexcept
Template Parameters
pItemsThe array.
A pointer to the requested element, or nullptr if the index is invalid.
Definition at line 202 of file Model.h.
◆ getSafe() [3/3]
static T * CesiumGltf::Model::getSafe ( std::vector< T > * pItems,
int32_t index )
Template Parameters
pItemsThe array.
Definition at line 221 of file Model.h.
◆ isExtensionRequired()
bool CesiumGltf::Model::isExtensionRequired ( const std::string & extensionName) const
noexcept
extensionNameThe extension name to check.
True if the extension is found in extensionsRequired; otherwise, false.
◆ isExtensionUsed()
bool CesiumGltf::Model::isExtensionUsed ( const std::string & extensionName) const
noexcept
True if the extension is found in extensionsUsed; otherwise, false.
◆ merge()
CesiumUtility::ErrorList CesiumGltf::Model::merge ( Model && rhs)
After this method returns, this Model contains all of the elements that were originally in it plus all of the elements that were in rhs. Element indices are updated accordingly. However, element indices in CesiumUtility::ExtensibleObject::extras, if any, are not updated.
rhsThe model to merge into this one.
◆ removeExtensionRequired()
void CesiumGltf::Model::removeExtensionRequired ( const std::string & extensionName)
Calling this function also removes the extension from extensionsUsed.
◆ removeExtensionUsed()
void CesiumGltf::Model::removeExtensionUsed ( const std::string & extensionName)
