A two-dimensional, rectangular region on a globe, specified using longitude and latitude coordinates. The region is rectangular in terms of longitude-latitude coordinates, but may be far from rectangular on the actual globe surface. More...
#include <CesiumGeospatial/GlobeRectangle.h>
| constexpr | GlobeRectangle (double west, double south, double east, double north) noexcept |
| constexpr double | getWest () const noexcept |
| Returns the westernmost longitude, in radians. | |
| void | setWest (double value) noexcept |
| Sets the westernmost longitude, in radians. | |
| constexpr double | getSouth () const noexcept |
| Returns the southernmost latitude, in radians. | |
| void | setSouth (double value) noexcept |
| Sets the southernmost latitude, in radians. | |
| constexpr double | getEast () const noexcept |
| Returns the easternmost longitude, in radians. | |
| void | setEast (double value) noexcept |
| Sets the easternmost longitude, in radians. | |
| constexpr double | getNorth () const noexcept |
| Returns the northernmost latitude, in radians. | |
| void | setNorth (double value) noexcept |
| Sets the northernmost latitude, in radians. | |
| constexpr Cartographic | getSouthwest () const noexcept |
| Returns the Cartographic position of the south-west corner. | |
| constexpr Cartographic | getSoutheast () const noexcept |
| Returns the Cartographic position of the south-east corner. | |
| constexpr Cartographic | getNorthwest () const noexcept |
| Returns the Cartographic position of the north-west corner. | |
| constexpr Cartographic | getNortheast () const noexcept |
| Returns the Cartographic position of the north-east corner. | |
| constexpr CesiumGeometry::Rectangle | toSimpleRectangle () const noexcept |
| Returns this rectangle as a CesiumGeometry::Rectangle. | |
| constexpr double | computeWidth () const noexcept |
| Computes the width of this rectangle. | |
| constexpr double | computeHeight () const noexcept |
| Computes the height of this rectangle. | |
| Cartographic | computeCenter () const noexcept |
| Computes the Cartographic center position of this rectangle. | |
| bool | contains (const Cartographic &cartographic) const noexcept |
Returns true if this rectangle contains the given point. | |
| bool | isEmpty () const noexcept |
| Determines if this rectangle is empty. | |
| std::optional< GlobeRectangle > | computeIntersection (const GlobeRectangle &other) const noexcept |
| Computes the intersection of two rectangles. | |
| GlobeRectangle | computeUnion (const GlobeRectangle &other) const noexcept |
| Computes the union of this globe rectangle with another. | |
| glm::dvec2 | computeNormalizedCoordinates (const Cartographic &cartographic) const noexcept |
| Computes the normalized position of the given cartographic coordinate on this globe rectangle, with (0.0, 0.0) representing southwest and (1.0, 1.0) representing northeast. The returned coordinates vary linearly with longitude and latitude within the rectangle. | |
| std::pair< GlobeRectangle, std::optional< GlobeRectangle > > | splitAtAntiMeridian () const noexcept |
| Splits this rectangle at the anti-meridian (180 degrees longitude), if necessary. | |
| static constexpr GlobeRectangle | fromRectangleRadians (const CesiumGeometry::Rectangle &rectangle) noexcept |
Constructs a new GlobeRectangle from the provided Rectangle. | |
| static constexpr GlobeRectangle | fromDegrees (double westDegrees, double southDegrees, double eastDegrees, double northDegrees) noexcept |
| static bool | equals (const GlobeRectangle &left, const GlobeRectangle &right) noexcept |
| Checks whether two globe rectangles are exactly equal. | |
| static bool | equalsEpsilon (const GlobeRectangle &left, const GlobeRectangle &right, double relativeEpsilon) noexcept |
| Checks whether two globe rectangles are equal up to a given relative epsilon. | |
| static const GlobeRectangle | EMPTY |
| An empty rectangle. | |
| static const GlobeRectangle | MAXIMUM |
| The maximum rectangle. | |
The eastern coordinate may be less than the western coordinate, which indicates that the rectangle crosses the anti-meridian.
Definition at line 25 of file GlobeRectangle.h.
inlineconstexprnoexcept |
| west | The westernmost longitude, in radians, in the range [-Pi, Pi]. |
| south | The southernmost latitude, in radians, in the range [-Pi/2, Pi/2]. |
| east | The easternmost longitude, in radians, in the range [-Pi, Pi]. |
| north | The northernmost latitude, in radians, in the range [-Pi/2, Pi/2]. |
Definition at line 59 of file GlobeRectangle.h.
The result will be in radians, in the range [0, Pi*2].
Definition at line 211 of file GlobeRectangle.h.
noexcept |
This function assumes that the rectangle's coordinates are latitude and longitude in radians and produces a correct intersection, taking into account the fact that the same angle can be represented with multiple values as well as the wrapping of longitude at the anti-meridian. For a simple intersection that ignores these factors and can be used with projected coordinates, see CesiumGeometry::Rectangle::computeIntersection.
| other | The other rectangle to intersect with this one. |
std::nullopt if there is no intersection.
noexcept |
| cartographic | The cartographic coordinate to transform. |
noexcept |
| other | The other globe rectangle. |
Definition at line 197 of file GlobeRectangle.h.
noexcept |
The provided cartographic position must be within the longitude range [-Pi, Pi] and the latitude range [-Pi/2, Pi/2].
This will take into account the wrapping of the longitude at the anti-meridian.
staticnoexcept |
| left | The first rectangle. |
| right | The second rectangle. |
staticnoexcept |
| relativeEpsilon | The relative epsilon. |
inlinestaticconstexprnoexcept |
Creates a rectangle given the boundary longitude and latitude in degrees. The angles are converted to radians.
| westDegrees | The westernmost longitude in degrees in the range [-180.0, 180.0]. |
| southDegrees | The southernmost latitude in degrees in the range [-90.0, 90.0]. |
| eastDegrees | The easternmost longitude in degrees in the range [-180.0, 180.0]. |
| northDegrees | The northernmost latitude in degrees in the range [-90.0, 90.0]. |
Definition at line 101 of file GlobeRectangle.h.
The rectangle's minimum coordinates will be interpreted as the southwest position in radians and the maximum coordinates as the northeast in radians.
| rectangle | The rectangle defining the bounds of the new GlobeRectangle. |
Definition at line 77 of file GlobeRectangle.h.
Definition at line 136 of file GlobeRectangle.h.
Definition at line 146 of file GlobeRectangle.h.
Definition at line 177 of file GlobeRectangle.h.
Definition at line 170 of file GlobeRectangle.h.
Definition at line 126 of file GlobeRectangle.h.
Definition at line 163 of file GlobeRectangle.h.
Definition at line 156 of file GlobeRectangle.h.
Definition at line 116 of file GlobeRectangle.h.
noexcept |
An empty rectangle bounds no part of the globe, not even a single point.
inlinenoexcept |
Definition at line 141 of file GlobeRectangle.h.
inlinenoexcept |
Definition at line 151 of file GlobeRectangle.h.
inlinenoexcept |
Definition at line 131 of file GlobeRectangle.h.
inlinenoexcept |
Definition at line 121 of file GlobeRectangle.h.
noexcept |
If the rectangle does not cross the anti-meridian, the entire rectangle is returned in the first field of the pair and the second is std::nullopt. If it does cross the anti-meridian, this function returns two rectangles that touch but do not cross it. The larger of the two rectangles is returned in first and the smaller one is returned in second.
Definition at line 184 of file GlobeRectangle.h.
static |
An empty rectangle.
The rectangle has the following values:
west: Pisouth: Pi/2east: -Pinorth: -Pi/2 Definition at line 36 of file GlobeRectangle.h.
static |
west: -Pisouth: -Pi/2east: Pinorth: Pi/2 Definition at line 47 of file GlobeRectangle.h.
