Cesium3DTilesSelection::TileLoadResult Struct Reference
Store the result of loading a tile content after invoking TilesetContentLoader::loadTileContent. More...
#include <Cesium3DTilesSelection/TileLoadResult.h>
static TileLoadResult createFailedResult (std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor, std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest)
 Create a result with Failed state.
static TileLoadResult createRetryLaterResult (std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor, std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest)
 Create a result with RetryLater state.
TileContentKind contentKind
 The content type of the tile.
CesiumGeometry::Axis glTFUpAxis = CesiumGeometry::Axis::Y
 The up axis of glTF content.
std::optional< Cesium3DTiles::BoundingVolume > updatedBoundingVolume
 A tile can potentially store a more fit bounding volume along with its content. If this field is set, the tile's bounding volume will be updated after the loading is finished.
std::optional< Cesium3DTiles::BoundingVolume > updatedContentBoundingVolume
 A tile can potentially store a more fit content bounding volume along with its content. If this field is set, the tile's content bounding volume will be updated after the loading is finished.
std::optional< CesiumRasterOverlays::RasterOverlayDetails > rasterOverlayDetails
 Holds details of the TileRenderContent that are useful for raster overlays.
 The asset accessor that was used to retrieve this tile, and that should be used to retrieve further resources referenced by the tile.
 The request that is created to download the tile content.
std::function< void(Tile &)> tileInitializer
 A callback that is invoked in the main thread immediately when the loading is finished. This callback is useful when the content request has other fields like geometric error, children (in the case of TileExternalContent), etc, to override the existing fields.
TileLoadResultState state
 The result of loading a tile. Note that if the state is Failed or RetryLater, none of the fields above (including TileLoadResult::tileInitializer) will be applied to a tile when the loading is finished.
CesiumGeospatial::Ellipsoid ellipsoid
 The ellipsoid that this tile uses.
std::optional< Cesium3DTiles::BoundingVolume > initialBoundingVolume
 The bounding volume initially loaded with the tile.
std::optional< Cesium3DTiles::BoundingVolume > initialContentBoundingVolume
 The content bounding volume initially loaded with the tile, if any.
Definition at line 76 of file TileLoadResult.h.
◆ createFailedResult()
static TileLoadResult Cesium3DTilesSelection::TileLoadResult::createFailedResult ( std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor,
std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest )
static
pAssetAccessorThe IAssetAccessor used to load tiles.
pCompletedRequestThe failed request
◆ createRetryLaterResult()
static TileLoadResult Cesium3DTilesSelection::TileLoadResult::createRetryLaterResult ( std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor,
static
◆ contentKind
TileContentKind Cesium3DTilesSelection::TileLoadResult::contentKind
Definition at line 80 of file TileLoadResult.h.
◆ ellipsoid
CesiumGeospatial::Ellipsoid Cesium3DTilesSelection::TileLoadResult::ellipsoid
Initial value:
static const Ellipsoid UNIT_SPHERE
An Ellipsoid with all three radii set to one meter.
Definition Ellipsoid.h:53
This value is only guaranteed to be accurate when TileLoadResult::state is equal to TileLoadResultState::Success.
Definition at line 142 of file TileLoadResult.h.
◆ glTFUpAxis
CesiumGeometry::Axis Cesium3DTilesSelection::TileLoadResult::glTFUpAxis = CesiumGeometry::Axis::Y
Definition at line 85 of file TileLoadResult.h.
◆ initialBoundingVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTilesSelection::TileLoadResult::initialBoundingVolume
Initial value:
std::nullopt
If there was an "original" bounding volume for this tile (for example, in the case of 3D Tiles, the "boundingVolume" property), this will be that original value before any modifications are performed. This is in contrast to updatedBoundingVolume, which contains the modified bounding volume for the tile.
Definition at line 154 of file TileLoadResult.h.
◆ initialContentBoundingVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTilesSelection::TileLoadResult::initialContentBoundingVolume
Initial value:
std::nullopt
This is the equivalent to initialBoundingVolume for the content bounding volume. See updatedContentBoundingVolume for the modified content bounding volume.
Definition at line 164 of file TileLoadResult.h.
◆ pAssetAccessor
std::shared_ptr<CesiumAsync::IAssetAccessor> Cesium3DTilesSelection::TileLoadResult::pAssetAccessor
Definition at line 112 of file TileLoadResult.h.
◆ pCompletedRequest
std::shared_ptr<CesiumAsync::IAssetRequest> Cesium3DTilesSelection::TileLoadResult::pCompletedRequest
Definition at line 117 of file TileLoadResult.h.
◆ rasterOverlayDetails
std::optional<CesiumRasterOverlays::RasterOverlayDetails> Cesium3DTilesSelection::TileLoadResult::rasterOverlayDetails
Definition at line 106 of file TileLoadResult.h.
◆ state
TileLoadResultState Cesium3DTilesSelection::TileLoadResult::state
Definition at line 134 of file TileLoadResult.h.
◆ tileInitializer
std::function<void(Tile&)> Cesium3DTilesSelection::TileLoadResult::tileInitializer
Definition at line 126 of file TileLoadResult.h.
◆ updatedBoundingVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTilesSelection::TileLoadResult::updatedBoundingVolume
Definition at line 92 of file TileLoadResult.h.
◆ updatedContentBoundingVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTilesSelection::TileLoadResult::updatedContentBoundingVolume
Definition at line 99 of file TileLoadResult.h.
