Cesium3DTilesSelection::DebugTileStateDatabase Class Reference
Helps debug the tile selection algorithm by recording the state of tiles each frame to a SQLite database. More...
#include <Cesium3DTilesSelection/DebugTileStateDatabase.h>
 DebugTileStateDatabase (const std::string &databaseFilename)
 Creates a new instance.
void recordAllTileStates (int32_t frameNumber, const Tileset &tileset, const TilesetViewGroup &viewGroup)
 Records the state of all tiles that are currently loaded by the given tileset.
void recordTileState (int32_t frameNumber, const TilesetViewGroup &viewGroup, const Tile &tile)
 Records the state of a given tile.
void recordTileState (int32_t frameNumber, const Tile &tile, const std::unordered_map< const Tile *, TileSelectionState > &states)
Definition at line 19 of file DebugTileStateDatabase.h.
◆ DebugTileStateDatabase()
Cesium3DTilesSelection::DebugTileStateDatabase::DebugTileStateDatabase ( const std::string & databaseFilename)
databaseFilenameThe full path and filename of the output SQLite database.
◆ recordAllTileStates()
void Cesium3DTilesSelection::DebugTileStateDatabase::recordAllTileStates ( int32_t frameNumber,
const Tileset & tileset,
const TilesetViewGroup & viewGroup )
The state is obtained from the view group's TilesetViewGroup::getTraversalState by calling CesiumUtility::TreeTraversalState::slowlyGetPreviousStates.
frameNumberThe current frame number.
tilesetThe tileset.
viewGroupThe view group.
◆ recordTileState() [1/2]
void Cesium3DTilesSelection::DebugTileStateDatabase::recordTileState ( int32_t frameNumber,
const Tile & tile,
const std::unordered_map< const Tile *, TileSelectionState > & states )
The state is obtained from the provided map.
tileThe tile.
statesThe lookup table for tile states.
◆ recordTileState() [2/2]
const TilesetViewGroup & viewGroup,
const Tile & tile )
tileThe tile.
