Cesium3DTilesSelection::ITwinRealityDataContentLoaderFactory Class Reference
A factory for creating a TilesetContentLoader from data from the iTwin Reality Management API. More...
#include <Cesium3DTilesSelection/ITwinRealityDataContentLoaderFactory.h>
Inheritance diagram for Cesium3DTilesSelection::ITwinRealityDataContentLoaderFactory:
Cesium3DTilesSelection::TilesetContentLoaderFactory
Public Types
using TokenRefreshCallback
 Callback to obtain a new access token for the iTwin API. Receives the previous access token as parameter.
- Public Types inherited from Cesium3DTilesSelection::TilesetContentLoaderFactory
using AuthorizationHeaderChangeListener
 The type of a callback called when the Authorization header used by a tileset loader has changed.
 ITwinRealityDataContentLoaderFactory (const std::string &realityDataId, const std::optional< std::string > &iTwinId, const std::string &iTwinAccessToken, TokenRefreshCallback &&tokenRefreshCallback)
 Creates a new factory for loading iTwin reality data.
 ITwinRealityDataContentLoaderFactory (const std::string &realityDataId, const std::optional< std::string > &iTwinId, const std::string &iTwinAccessToken, const std::string &iTwinRealityDataBaseURL, TokenRefreshCallback &&tokenRefreshCallback)
virtual CesiumAsync::Future< Cesium3DTilesSelection::TilesetContentLoaderResult< Cesium3DTilesSelection::TilesetContentLoader > > createLoader (const TilesetExternals &externals, const TilesetOptions &tilesetOptions, const AuthorizationHeaderChangeListener &headerChangeListener) override
 Creates an instance of the loader corresponding to this factory.
virtual bool isValid () const override
 Returns true if a valid TilesetContentLoader can be constructed from this factory.
Definition at line 17 of file ITwinRealityDataContentLoaderFactory.h.
Member Typedef Documentation
◆ TokenRefreshCallback
Initial value:
std::function<CesiumAsync::Future<CesiumUtility::Result<std::string>>(
const std::string&)>
Definition at line 24 of file ITwinRealityDataContentLoaderFactory.h.
◆ ITwinRealityDataContentLoaderFactory() [1/2]
Cesium3DTilesSelection::ITwinRealityDataContentLoaderFactory::ITwinRealityDataContentLoaderFactory ( const std::string & realityDataId,
const std::optional< std::string > & iTwinId,
const std::string & iTwinAccessToken,
TokenRefreshCallback && tokenRefreshCallback )
realityDataIdThe ID of the reality data to load.
iTwinId
The ID of the iTwin this reality data is associated with.
As described in the iTwin Reality Management API documentation:
The iTwinId parameter is optional, but it is preferable to provide it, because the permissions used to access the container are determined from the iTwin. With no iTwin specified, the operation can succeed in some cases (e.g. the user is the reality data's owner), but we recommend to provide a iTwinId.
iTwinAccessTokenThe access token to use to access the API.
tokenRefreshCallbackCallback that will be called to obtain a new access token when the provided one has expired.
◆ ITwinRealityDataContentLoaderFactory() [2/2]
const std::string & iTwinRealityDataBaseURL,
iTwinId
iTwinRealityDataBaseURLThe base URL to use to access the Reality Data API.
◆ createLoader()
virtual CesiumAsync::Future< Cesium3DTilesSelection::TilesetContentLoaderResult< Cesium3DTilesSelection::TilesetContentLoader > > Cesium3DTilesSelection::ITwinRealityDataContentLoaderFactory::createLoader ( const TilesetExternals & externals,
const TilesetOptions & tilesetOptions,
const AuthorizationHeaderChangeListener & headerChangeListener )
overridevirtual
externalsThe TilesetExternals.
tilesetOptionsThe TilesetOptions.
headerChangeListenerA callback that will be called when the Authorization header used by the tileset loader has changed.
A future that resolves to a TilesetContentLoaderResult.
Implements Cesium3DTilesSelection::TilesetContentLoaderFactory.
◆ isValid()
virtual bool Cesium3DTilesSelection::ITwinRealityDataContentLoaderFactory::isValid ( ) const
overridevirtual
