Raster image data for a tile in a quadtree. More...
#include <CesiumRasterOverlays/RasterOverlayTile.h>
Public Types | |
| enum class | LoadState { Placeholder = -2 , Failed = -1 , Unloaded = 0 , Loading = 1 , Loaded = 2 , Done = 3 } |
| Lifecycle states of a raster overlay tile. More... | |
| enum class | MoreDetailAvailable { No = 0 , Yes = 1 , Unknown = 2 } |
| Tile availability states. More... | |
| RasterOverlayTile (ActivatedRasterOverlay &activatedOverlay) noexcept | |
| Constructs a placeholder tile for the tile provider. | |
| RasterOverlayTile (ActivatedRasterOverlay &activatedOverlay, const glm::dvec2 &targetScreenPixels, const CesiumGeometry::Rectangle &imageryRectangle) noexcept | |
| Creates a new instance. | |
| ~RasterOverlayTile () | |
| Default destructor. | |
| ActivatedRasterOverlay & | getActivatedOverlay () noexcept |
| Gets the activated overlay that created this instance. | |
| const ActivatedRasterOverlay & | getActivatedOverlay () const noexcept |
| RasterOverlayTileProvider & | getTileProvider () noexcept |
| Returns the RasterOverlayTileProvider that is responsible for loading this tile's image. | |
| const RasterOverlayTileProvider & | getTileProvider () const noexcept |
| const RasterOverlay & | getOverlay () const noexcept |
| Gets the RasterOverlay associated with this instance. | |
| const CesiumGeometry::Rectangle & | getRectangle () const noexcept |
| Returns the CesiumGeometry::Rectangle that defines the bounds of this tile in the raster overlay's projected coordinates. | |
| glm::dvec2 | getTargetScreenPixels () const noexcept |
| Gets the number of screen pixels in each direction that should be covered by this tile's texture. | |
| LoadState | getState () const noexcept |
| Returns the current LoadState. | |
| const std::vector< CesiumUtility::Credit > & | getCredits () const noexcept |
| Returns the list of Credits needed for this tile. | |
| CesiumUtility::IntrusivePointer< const CesiumImage::ImageAsset > | getImage () const noexcept |
| Returns the image data for the tile. | |
| CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > | getImage () noexcept |
| void | loadInMainThread () |
| Create the renderer resources for the loaded image. | |
| void * | getRendererResources () const noexcept |
| Returns the renderer resources that have been created for this tile. | |
| void | setRendererResources (void *pValue) noexcept |
| Set the renderer resources for this tile. | |
| MoreDetailAvailable | isMoreDetailAvailable () const noexcept |
| Determines if more detailed data is available for the spatial area covered by this tile. | |
Public Member Functions inherited from CesiumUtility::ReferenceCounted< T, false > | |
Friends | |
| class | ActivatedRasterOverlay |
Instances of this clas represent tiles of a quadtree that have an associated image, which us used as an imagery overlay for tile geometry. The connection between the imagery data and the actual tile geometry is established via the Cesium3DTilesSelection::RasterMappedTo3DTile class, which combines a raster overlay tile with texture coordinates, to map the image on the geometry of a Cesium3DTilesSelection::Tile.
Definition at line 36 of file RasterOverlayTile.h.
strong |
Definition at line 42 of file RasterOverlayTile.h.
strong |
Values of this enumeration are returned by Cesium3DTilesSelection::RasterMappedTo3DTile::update, which in turn is called by TilesetContentManager::updateDoneState. These values are used to determine whether a leaf tile has been reached, but the associated raster tiles are not yet the most detailed ones that are available.
| Enumerator | |
| No | There are no more detailed raster tiles. |
| Yes | There are more detailed raster tiles. |
| Unknown | It is not known whether more detailed raster tiles are available. |
Definition at line 83 of file RasterOverlayTile.h.
noexcept |
The getState of this instance will always be LoadState::Placeholder.
| activatedOverlay | The ActivatedRasterOverlay. This object must remain valid for the entire lifetime of the tile. If the activated overlay is destroyed before the tile, undefined behavior will result. |
noexcept |
The tile will start in the Unloaded state, and will not begin loading until ActivatedRasterOverlay::loadTile or ActivatedRasterOverlay::loadTileThrottled is called.
| targetScreenPixels | The maximum number of pixels on the screen that this tile is meant to cover. The overlay image should be approximately this many pixels divided by the RasterOverlayOptions::maximumScreenSpaceError in order to achieve the desired level-of-detail, but it does not need to be exactly this size. |
| imageryRectangle | The rectangle that the returned image must cover. It is allowed to cover a slightly larger rectangle in order to maintain pixel alignment. It may also cover a smaller rectangle when the overlay itself does not cover the entire rectangle. |
noexcept |
inlinenoexcept |
Definition at line 186 of file RasterOverlayTile.h.
inlinenoexcept |
This will only contain valid image data if the getState of this tile is Loaded or Done.
Definition at line 199 of file RasterOverlayTile.h.
inlinenoexcept |
Definition at line 211 of file RasterOverlayTile.h.
inlinenoexcept |
Definition at line 162 of file RasterOverlayTile.h.
inlinenoexcept |
Definition at line 229 of file RasterOverlayTile.h.
inlinenoexcept |
Definition at line 180 of file RasterOverlayTile.h.
inlinenoexcept |
This is used to control which content (how highly detailed) the RasterOverlayTileProvider uses within the bounds of this tile.
Definition at line 173 of file RasterOverlayTile.h.
noexcept |
inlinenoexcept |
Definition at line 246 of file RasterOverlayTile.h.
| void CesiumRasterOverlays::RasterOverlayTile::loadInMainThread | ( | ) |
If the getState of this tile is not Loaded, then nothing will be done. Otherwise, the renderer resources will be prepared, so that they may later be obtained with getRendererResources, and the getState of this tile will change to Done.
inlinenoexcept |
This function is not supposed to be called by clients.
Definition at line 238 of file RasterOverlayTile.h.
friend |
Definition at line 260 of file RasterOverlayTile.h.
