Cesium3DTilesSelection::TileExternalContent Struct Reference
A content tag that indicates a tile content points to an external tileset. When this tile is loaded, all the tiles in the external tileset will become children of this external content tile. More...
#include <Cesium3DTilesSelection/TileContent.h>
Inheritance diagram for Cesium3DTilesSelection::TileExternalContent:
 TileExternalContent (bool implicit=false)
 Construct the external content object.
TilesetMetadata metadata
 The metadata associated with this tileset.
bool isImplicit
 Indicates that the tile is the root of an implicit tileset.
Definition at line 59 of file TileContent.h.
◆ TileExternalContent()
Cesium3DTilesSelection::TileExternalContent::TileExternalContent ( bool implicit = false)
implicitWhether the tile is the root of an implicit tileset.
Definition at line 66 of file TileContent.h.
◆ isImplicit
bool Cesium3DTilesSelection::TileExternalContent::isImplicit
Definition at line 76 of file TileContent.h.
◆ metadata
TilesetMetadata Cesium3DTilesSelection::TileExternalContent::metadata
Definition at line 71 of file TileContent.h.
