Cesium3DTilesSelection::RasterOverlayCollection Class Referencefinal
A collection of CesiumRasterOverlays::RasterOverlay instances that are associated with a Tileset. More...
#include <Cesium3DTilesSelection/RasterOverlayCollection.h>
Public Types
using const_iterator
 A constant iterator for CesiumRasterOverlays::RasterOverlay instances.
 RasterOverlayCollection (const LoadedTileEnumerator &loadedTiles, const TilesetExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) noexcept
 Creates a new instance.
void setLoadedTileEnumerator (const LoadedTileEnumerator &loadedTiles)
 Provides a new LoadedTileEnumerator to use to update loaded tiles when a raster overlay is added or removed.
 RasterOverlayCollection (const RasterOverlayCollection &rhs)=delete
 Deleted Copy constructor.
 RasterOverlayCollection (RasterOverlayCollection &&rhs) noexcept=default
 Move constructor.
RasterOverlayCollection & operator= (const RasterOverlayCollection &rhs)=delete
 Deleted copy assignment.
RasterOverlayCollection & operator= (RasterOverlayCollection &&rhs) noexcept=default
 Move assignment.
 ~RasterOverlayCollection () noexcept
 Destroys the collection.
const std::vector< CesiumUtility::IntrusivePointer< CesiumRasterOverlays::ActivatedRasterOverlay > > & getActivatedOverlays () const noexcept
 Gets the activated raster overlays in this collection.
void add (const CesiumUtility::IntrusivePointer< const CesiumRasterOverlays::RasterOverlay > &pOverlay) noexcept
 Adds the given CesiumRasterOverlays::RasterOverlay to this collection.
void remove (const CesiumUtility::IntrusivePointer< const CesiumRasterOverlays::RasterOverlay > &pOverlay) noexcept
 Remove the given CesiumRasterOverlays::RasterOverlay from this collection.
void remove (const CesiumUtility::IntrusivePointer< CesiumRasterOverlays::RasterOverlay > &pOverlay) noexcept
void remove (const CesiumUtility::IntrusivePointer< CesiumRasterOverlays::ActivatedRasterOverlay > &pActivated) noexcept
 Remove the given CesiumRasterOverlays::ActivatedRasterOverlay from this collection.
std::vector< CesiumGeospatial::Projection > addTileOverlays (Tile &tile, const TilesetOptions &tilesetOptions) noexcept
 Adds raster overlays to a new Tile.
TileRasterOverlayStatus updateTileOverlays (Tile &tile, const TilesetOptions &tilesetOptions) noexcept
 Updates the raster overlays associated with a tile.
void updateTileOverlaysForReplacedContent (Tile &tile, double maximumScreenSpaceError) noexcept
 Updates the raster overlays mapped to a tile after the tile's content has been replaced, such as by a GltfModifier.
const_iterator begin () const noexcept
 Returns an iterator at the beginning of this collection.
const_iterator end () const noexcept
 Returns an iterator at the end of this collection.
size_t size () const noexcept
 Gets the number of overlays in the collection.
The raster overlay instances may be added to the raster overlay collection of a tileset that is returned with Tileset::getOverlays. When the tileset is loaded, one CesiumRasterOverlays::RasterOverlayTileProvider will be created for each raster overlay that had been added. The raster overlay tile provider instances will be passed to the CesiumRasterOverlays::RasterOverlayTile instances that they create when the tiles are updated.
Definition at line 70 of file RasterOverlayCollection.h.
Member Typedef Documentation
◆ const_iterator
Initial value:
GetOverlayFunctor,
CesiumUtility::TransformIterator< GetOverlayFunctor, std::vector< CesiumUtility::IntrusivePointer< CesiumRasterOverlays::ActivatedRasterOverlay > >::const_iterator > const_iterator
A RasterOverlay that has been activated for use. While a RasterOverlayTileProvider can be used direct...
An iterator that wraps another iterator and applies a transformation function to each element as it i...
Definition at line 239 of file RasterOverlayCollection.h.
◆ RasterOverlayCollection() [1/3]
Cesium3DTilesSelection::RasterOverlayCollection::RasterOverlayCollection ( const LoadedTileEnumerator & loadedTiles,
const TilesetExternals & externals,
noexcept
loadedTilesAn enumerator for the loaded tiles. The raster overlay collection will copy this enumerator, and the copy must remain valid for the lifetime of the overlay collection or until setLoadedTileEnumerator is called with a new enumerator.
externalsA collection of loading system to load a raster overlay
◆ RasterOverlayCollection() [2/3]
Cesium3DTilesSelection::RasterOverlayCollection::RasterOverlayCollection ( const RasterOverlayCollection & rhs)
delete
rhsThe other instance.
◆ RasterOverlayCollection() [3/3]
Cesium3DTilesSelection::RasterOverlayCollection::RasterOverlayCollection ( RasterOverlayCollection && rhs)
defaultnoexcept
Move constructor.
◆ add()
void Cesium3DTilesSelection::RasterOverlayCollection::add ( const CesiumUtility::IntrusivePointer< const CesiumRasterOverlays::RasterOverlay > & pOverlay)
noexcept
pOverlayThe pointer to the overlay. This may not be nullptr.
◆ addTileOverlays()
std::vector< CesiumGeospatial::Projection > Cesium3DTilesSelection::RasterOverlayCollection::addTileOverlays ( Tile & tile,
const TilesetOptions & tilesetOptions )
noexcept
The tile should be in the TileLoadState::Unloaded or TileLoadState::FailedTemporarily state.
Any existing raster overlays on the tile will be cleared.
tileThe tile for which to add the overlays.
tilesetOptionsThe TilesetOptions for the tileset to which the tile belongs.
The list of projections required by the overlays that were added to the tile.
◆ operator=() [1/2]
RasterOverlayCollection & Cesium3DTilesSelection::RasterOverlayCollection::operator= ( const RasterOverlayCollection & rhs)
delete
◆ operator=() [2/2]
RasterOverlayCollection & Cesium3DTilesSelection::RasterOverlayCollection::operator= ( RasterOverlayCollection && rhs)
defaultnoexcept
Move assignment.
◆ setLoadedTileEnumerator()
void Cesium3DTilesSelection::RasterOverlayCollection::setLoadedTileEnumerator ( const LoadedTileEnumerator & loadedTiles)
loadedTilesThe new loaded tile enumerator.
◆ updateTileOverlays()
TileRasterOverlayStatus Cesium3DTilesSelection::RasterOverlayCollection::updateTileOverlays ( Tile & tile,
noexcept
This method is called internally for each tile that is rendered, and gives the raster overlay system a chance to replace raster overlay placeholders with real tiles. Its return value is also used to determine whether or not this tile should be upsampled in order to attach further raster overlay detail.
tileThe tile for which to update the overlays.
Details of the raster overlays attached to this tile.
◆ updateTileOverlaysForReplacedContent()
void Cesium3DTilesSelection::RasterOverlayCollection::updateTileOverlaysForReplacedContent ( Tile & tile,
double maximumScreenSpaceError )
noexcept
The tile's existing mappings must already be detached from its previous content, and its TileRenderContent must already hold the new content and its CesiumRasterOverlays::RasterOverlayDetails.
Mapped raster overlay tiles that still cover the new content are kept, so that they can be reattached right away. Other overlays are mapped to the tile again, which may require loading new raster overlay tiles. If the new content is empty, all raster overlays are removed from the tile.
This method does not attach any raster overlay tiles. They will be attached by the next call to updateTileOverlays.
tileThe tile whose content was replaced.
maximumScreenSpaceErrorThe maximum screen-space error of the tileset to which the tile belongs.
