Cesium3DTilesSelection::LoadedTileEnumerator Class Reference
A "virtual collection" that allows enumeration through the loaded tiles in a subtree rooted at a given Tile. More...
#include <Cesium3DTilesSelection/LoadedTileEnumerator.h>
Classes
class  iterator
 An iterator over Tile instances. More...
Public Types
using const_iterator = LoadedConstTileEnumerator::const_iterator
 An iterator over constant Tile instances.
 LoadedTileEnumerator (Tile *pRootTile) noexcept
 Creates a new instance to enumerate loaded tiles in the subtree rooted at pRootTile.
iterator begin () const noexcept
 Returns an iterator starting at the first tile.
iterator end () const noexcept
 Returns an iterator starting after the last tile.
For the purposes of this enumeration, a loaded tile is one that is in a TileLoadState other than TileLoadState::Unloaded, or that has any children (or other descendants) that meet this criteria. We check the latter criteria by looking at Tile::getReferenceCount.
Definition at line 113 of file LoadedTileEnumerator.h.
Member Typedef Documentation
◆ const_iterator
◆ LoadedTileEnumerator()
Cesium3DTilesSelection::LoadedTileEnumerator::LoadedTileEnumerator ( Tile * pRootTile)
explicitnoexcept
If pRootTile is nullptr, then the iteration is empty (begin==end). Otherwise, the iteration will include at least pRootTile, even if it is not loaded.
pRootTileThe root tile of the subtree.
