Cesium3DTilesSelection::ITwinCesiumCuratedContentLoaderFactory Class Reference
A factory for creating a TilesetContentLoader from data from the iTwin Cesium Curated Content API. More...
#include <Cesium3DTilesSelection/ITwinCesiumCuratedContentLoaderFactory.h>
Inheritance diagram for Cesium3DTilesSelection::ITwinCesiumCuratedContentLoaderFactory:
Cesium3DTilesSelection::TilesetContentLoaderFactory
 ITwinCesiumCuratedContentLoaderFactory (uint32_t iTwinCesiumContentID, const std::string &iTwinAccessToken)
 Creates a new factory for loading content from iTwin Cesium Curated Content.
 ITwinCesiumCuratedContentLoaderFactory (uint32_t iTwinCesiumContentID, const std::string &iTwinAccessToken, const std::string &iTwinURL)
virtual CesiumAsync::Future< Cesium3DTilesSelection::TilesetContentLoaderResult< Cesium3DTilesSelection::TilesetContentLoader > > createLoader (const TilesetExternals &externals, const TilesetOptions &tilesetOptions, const AuthorizationHeaderChangeListener &headerChangeListener) override
 Creates an instance of the loader corresponding to this factory.
virtual bool isValid () const override
 Returns true if a valid TilesetContentLoader can be constructed from this factory.
Additional Inherited Members
- Public Types inherited from Cesium3DTilesSelection::TilesetContentLoaderFactory
using AuthorizationHeaderChangeListener
 The type of a callback called when the Authorization header used by a tileset loader has changed.
Definition at line 18 of file ITwinCesiumCuratedContentLoaderFactory.h.
◆ ITwinCesiumCuratedContentLoaderFactory() [1/2]
Cesium3DTilesSelection::ITwinCesiumCuratedContentLoaderFactory::ITwinCesiumCuratedContentLoaderFactory ( uint32_t iTwinCesiumContentID,
const std::string & iTwinAccessToken )
iTwinCesiumContentIDThe ID of the item to load.
iTwinAccessTokenThe access token to use to access the API.
◆ ITwinCesiumCuratedContentLoaderFactory() [2/2]
const std::string & iTwinAccessToken,
const std::string & iTwinURL )
iTwinURLThe URL to use to access the API.
◆ createLoader()
virtual CesiumAsync::Future< Cesium3DTilesSelection::TilesetContentLoaderResult< Cesium3DTilesSelection::TilesetContentLoader > > Cesium3DTilesSelection::ITwinCesiumCuratedContentLoaderFactory::createLoader ( const TilesetExternals & externals,
const TilesetOptions & tilesetOptions,
const AuthorizationHeaderChangeListener & headerChangeListener )
overridevirtual
externalsThe TilesetExternals.
tilesetOptionsThe TilesetOptions.
headerChangeListenerA callback that will be called when the Authorization header used by the tileset loader has changed.
A future that resolves to a TilesetContentLoaderResult.
Implements Cesium3DTilesSelection::TilesetContentLoaderFactory.
◆ isValid()
virtual bool Cesium3DTilesSelection::ITwinCesiumCuratedContentLoaderFactory::isValid ( ) const
overridevirtual
