cesium-native 0.67.0
The loader interface to load the tile content. More...
#include <Cesium3DTilesSelection/TilesetContentLoader.h>
| virtual | ~TilesetContentLoader ()=default |
| Default virtual destructor. | |
| virtual CesiumAsync::Future< TileLoadResult > | loadTileContent (const TileLoadInput &input)=0 |
| Load the tile content. | |
| virtual TileChildrenResult | createTileChildren (const Tile &tile, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)=0 |
| Create the tile's children. | |
| virtual ITilesetHeightSampler * | getHeightSampler () |
| Gets an interface that can be used to efficiently query heights from this tileset. | |
| const TilesetContentManager * | getOwner () const noexcept |
Gets the TilesetContentManager that owns this loader. | |
| TilesetContentManager * | getOwner () noexcept |
| void | setOwner (TilesetContentManager &owner) noexcept |
Sets the TilesetContentManager that owns this loader. | |
| virtual void | setExternalSchema (CesiumGltf::Schema *schema) |
| Store a glTF schema object that will be used to parse metadata in a loader and its children. | |
| virtual CesiumUtility::IntrusivePointer< CesiumGltf::Schema > | getExternalSchema () |
| Get the external glTF schema object. | |
| virtual void | setOwnerOfNestedLoaders (TilesetContentManager &owner) noexcept |
| Called by setOwner to allow the loader to apply the new owner to any loaders that are aggregated by this one. | |
Definition at line 141 of file TilesetContentLoader.h.
pure virtual |
Note that: when receiving RetryLater status, client needs to load this tile's content first or its parent's content. The reason is that some tileset formats store the tile's children along with its content or store a whole subtree for every n-th level tile (e.g Quantized Mesh format). So unless the tile's content or the root tile of the subtree the tile is in is loaded, the loader won't know how to create the tile's children.
| tile | The tile to create children for. |
| ellipsoid | The CesiumGeospatial::Ellipsoid. |
Implemented in Cesium3DTilesSelection::EllipsoidTilesetLoader.
virtual |
inlinevirtual |
Some loaders may be able to query heights very efficiently by using a web service or by using an analytical model, e.g., when the "terrain" is a simple ellipsoid.
For loaders that have no particular way to query heights, this method will return nullptr, signaling that heights should be computed by downloading and sampling individual tiles.
nullptr if this loader has no particular way to do that. The returned instance must have a lifetime that is at least as long as the loader itself. Reimplemented in Cesium3DTilesSelection::EllipsoidTilesetLoader.
Definition at line 195 of file TilesetContentLoader.h.
pure virtual |
| input | The TileLoadInput that has the tile info and loading systems to load this tile's content |
virtual |
| schema | pointer to Schema. |
