cesium-native 0.67.0
Reports the results of Tileset::updateViewGroup. More...
#include <Cesium3DTilesSelection/ViewUpdateResult.h>
| std::vector< Tile::ConstPointer > | tilesToRenderThisFrame |
| The tiles that were selected by the tileset traversal this frame. These tiles should be rendered by the client. | |
| std::vector< double > | tileScreenSpaceErrorThisFrame |
| The computed screen space error of the tiles selected by the tileset traversal this frame. The values correspond to the tiles linked in tilesToRenderThisFrame, and may be used by the client to influence rendering behavior. | |
| std::unordered_set< Tile::ConstPointer > | tilesFadingOut |
| Tiles on this list are no longer selected for rendering. | |
| int32_t | workerThreadTileLoadQueueLength = 0 |
| The number of tiles in the worker thread load queue. | |
| int32_t | mainThreadTileLoadQueueLength = 0 |
| The number of tiles in the main thread load queue. | |
| uint32_t | tilesVisited = 0 |
| The number of tiles visited during tileset traversal this frame. | |
| uint32_t | culledTilesVisited = 0 |
| The number of culled tiles visited during tileset traversal this frame. | |
| uint32_t | tilesCulled = 0 |
| The number of tiles that were skipped because they were culled during tileset traversal this frame. | |
| uint32_t | tilesOccluded = 0 |
| The number of tiles occluded this frame. | |
| uint32_t | tilesWaitingForOcclusionResults = 0 |
| The number of tiles still waiting to obtain a TileOcclusionState this frame. | |
| uint32_t | tilesKicked = 0 |
| The number of tiles kicked from the render list this frame. | |
| uint32_t | maxDepthVisited = 0 |
| The maximum depth of the tile tree visited this frame. | |
| int32_t | frameNumber = 0 |
| The frame number. This is incremented every time Tileset::updateViewGroup is called. | |
Users of a Tileset will call Tileset::updateViewGroup and receive this structure so that they can update the state of their rendering system accordingly. The tileset will internally keep track the state of the tiles throughout the selection process, and use this structure to provide information about the state changes of tiles to clients.
Definition at line 21 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::culledTilesVisited = 0 |
Definition at line 68 of file ViewUpdateResult.h.
| int32_t Cesium3DTilesSelection::ViewUpdateResult::frameNumber = 0 |
Definition at line 96 of file ViewUpdateResult.h.
| int32_t Cesium3DTilesSelection::ViewUpdateResult::mainThreadTileLoadQueueLength = 0 |
Definition at line 58 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::maxDepthVisited = 0 |
Definition at line 90 of file ViewUpdateResult.h.
| std::vector<double> Cesium3DTilesSelection::ViewUpdateResult::tileScreenSpaceErrorThisFrame |
Definition at line 38 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::tilesCulled = 0 |
Definition at line 73 of file ViewUpdateResult.h.
| std::unordered_set<Tile::ConstPointer> Cesium3DTilesSelection::ViewUpdateResult::tilesFadingOut |
If TilesetOptions::enableLodTransitionPeriod is true they may be fading out. If a tile's TileRenderContent::getLodTransitionFadePercentage is 0 or LOD transitions are disabled, the tile should be hidden right away.
Definition at line 48 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::tilesKicked = 0 |
Definition at line 86 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::tilesOccluded = 0 |
Definition at line 77 of file ViewUpdateResult.h.
| std::vector<Tile::ConstPointer> Cesium3DTilesSelection::ViewUpdateResult::tilesToRenderThisFrame |
Tiles in this list may be fading in if TilesetOptions::enableLodTransitionPeriod is true.
Definition at line 30 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::tilesVisited = 0 |
Definition at line 63 of file ViewUpdateResult.h.
| uint32_t Cesium3DTilesSelection::ViewUpdateResult::tilesWaitingForOcclusionResults = 0 |
Definition at line 82 of file ViewUpdateResult.h.
| int32_t Cesium3DTilesSelection::ViewUpdateResult::workerThreadTileLoadQueueLength = 0 |
Definition at line 53 of file ViewUpdateResult.h.
