#include <CesiumGeospatial/S2CellBoundingVolume.h>
| S2CellBoundingVolume (const S2CellID &cellID, double minimumHeight, double maximumHeight, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) | |
| Creates a new S2CellBoundingVolume. | |
| const S2CellID & | getCellID () const |
| Gets this bounding volume's cell ID. | |
| double | getMinimumHeight () const noexcept |
| Gets the minimum height of the cell. | |
| double | getMaximumHeight () const noexcept |
| Gets the maximum height of the cell. | |
| glm::dvec3 | getCenter () const noexcept |
| Gets the center of this bounding volume in ellipsoid-fixed (ECEF) coordinates. | |
| std::span< const glm::dvec3 > | getVertices () const noexcept |
| Gets the either corners of the bounding volume, in ellipsoid-fixed (ECEF) coordinates. | |
| CesiumGeometry::CullingResult | intersectPlane (const CesiumGeometry::Plane &plane) const noexcept |
| Determines on which side of a plane the bounding volume is located. | |
| double | computeDistanceSquaredToPosition (const glm::dvec3 &position) const noexcept |
| Computes the distance squared from a given position to the closest point on this bounding volume. The position must be expressed in ellipsoid-centered (ECEF) coordinates. | |
| std::span< const CesiumGeometry::Plane > | getBoundingPlanes () const noexcept |
| Gets the six planes that bound the volume. | |
| BoundingRegion | computeBoundingRegion (const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const noexcept |
| Computes the bounding begion that best fits this S2 cell volume. | |
A tile bounding volume specified as an S2 cell token with minimum and maximum heights. The bounding volume is a k DOP. A k-DOP is the Boolean intersection of extents along k directions.
Definition at line 22 of file S2CellBoundingVolume.h.
| CesiumGeospatial::S2CellBoundingVolume::S2CellBoundingVolume | ( | const S2CellID & | cellID, |
| double | minimumHeight, | ||
| double | maximumHeight, | ||
| const CesiumGeospatial::Ellipsoid & | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 ) |
| cellID | The S2 cell ID. |
| minimumHeight | The minimum height of the bounding volume. |
| maximumHeight | The maximum height of the bounding volume. |
| ellipsoid | The ellipsoid. |
noexcept |
noexcept |
| position | The position |
noexcept |
size() of 6.
Definition at line 40 of file S2CellBoundingVolume.h.
inlinenoexcept |
Definition at line 50 of file S2CellBoundingVolume.h.
inlinenoexcept |
Definition at line 45 of file S2CellBoundingVolume.h.
noexcept |
size() of 8.
noexcept |
| plane | The plane to test against. |
Inside if the entire region is on the side of the plane the normal is pointing.Outside if the entire region is on the opposite side.Intersecting if the region intersects the plane.
