TileLoadResult.h
3#include <Cesium3DTilesSelection/BoundingVolume.h>
4#include <Cesium3DTilesSelection/TileContent.h>
5#include <CesiumAsync/IAssetRequest.h>
6#include <CesiumGeometry/Axis.h>
7#include <CesiumGeospatial/Ellipsoid.h>
8#include <CesiumGltf/Model.h>
9#include <CesiumRasterOverlays/RasterOverlayDetails.h>
10
11#include <functional>
12#include <memory>
13#include <optional>
14#include <variant>
15
16namespace Cesium3DTilesSelection {
17
18class Tile;
19
38using TileContentKind = std::variant<
43
71
76struct CESIUM3DTILESSELECTION_API TileLoadResult {
81
86
92 std::optional<BoundingVolume> updatedBoundingVolume;
93
99 std::optional<BoundingVolume> updatedContentBoundingVolume;
100
105 std::optional<CesiumRasterOverlays::RasterOverlayDetails>
107
112 std::shared_ptr<CesiumAsync::IAssetAccessor> pAssetAccessor;
113
117 std::shared_ptr<CesiumAsync::IAssetRequest> pCompletedRequest;
118
126 std::function<void(Tile&)> tileInitializer;
127
135
144
154 std::optional<BoundingVolume> initialBoundingVolume = std::nullopt;
155
163 std::optional<BoundingVolume> initialContentBoundingVolume = std::nullopt;
164
173 std::shared_ptr<CesiumAsync::IAssetAccessor> pAssetAccessor,
174 std::shared_ptr<CesiumAsync::IAssetRequest> pCompletedRequest);
175
184 std::shared_ptr<CesiumAsync::IAssetAccessor> pAssetAccessor,
185 std::shared_ptr<CesiumAsync::IAssetRequest> pCompletedRequest);
186};
187
188} // namespace Cesium3DTilesSelection
A tile in a Tileset.
Definition Tile.h:123
Definition Ellipsoid.h:39
static const Ellipsoid UNIT_SPHERE
An Ellipsoid with all three radii set to one meter.
Definition Ellipsoid.h:53
@ Failed
Something went wrong while loading this tile and it will not be retried.
Definition Tile.h:97
std::variant< TileUnknownContent, TileEmptyContent, TileExternalContent, CesiumGltf::Model > TileContentKind
Store the content of the tile after finishing loading tile using TilesetContentLoader::loadTileConten...
TileLoadResultState
Indicate the status of Cesium3DTilesSelection::TilesetContentLoader::loadTileContent and Cesium3DTile...
@ Success
The operation is successful and all the fields in TileLoadResult or TileChildrenResult are applied to...
@ RetryLater
The operation requires the client to retry later due to some background work happenning and none of t...
Axis
An enum describing the x, y, and z axes.
Definition Axis.h:10
@ Y
The y-axis.
Definition Axis.h:19
A content tag that indicates a tile has no content.
Definition TileContent.h:46
A content tag that indicates a tile content points to an external tileset. When this tile is loaded,...
Definition TileContent.h:54
Store the result of loading a tile content after invoking TilesetContentLoader::loadTileContent.
std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest
The request that is created to download the tile content.
TileLoadResultState state
The result of loading a tile. Note that if the state is Failed or RetryLater, none of the fields abov...
TileContentKind contentKind
The content type of the tile.
std::function< void(Tile &)> tileInitializer
A callback that is invoked in the main thread immediately when the loading is finished....
CesiumGeospatial::Ellipsoid ellipsoid
The ellipsoid that this tile uses.
std::optional< BoundingVolume > updatedContentBoundingVolume
A tile can potentially store a more fit content bounding volume along with its content....
std::optional< CesiumRasterOverlays::RasterOverlayDetails > rasterOverlayDetails
Holds details of the TileRenderContent that are useful for raster overlays.
std::optional< BoundingVolume > updatedBoundingVolume
A tile can potentially store a more fit bounding volume along with its content. If this field is set,...
static TileLoadResult createFailedResult(std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor, std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest)
Create a result with Failed state.
std::optional< BoundingVolume > initialBoundingVolume
The bounding volume initially loaded with the tile.
std::optional< BoundingVolume > initialContentBoundingVolume
The content bounding volume initially loaded with the tile, if any.
The asset accessor that was used to retrieve this tile, and that should be used to retrieve further r...
static TileLoadResult createRetryLaterResult(std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor, std::shared_ptr< CesiumAsync::IAssetRequest > pCompletedRequest)
Create a result with RetryLater state.
CesiumGeometry::Axis glTFUpAxis
The up axis of glTF content.
A content tag that indicates the TilesetContentLoader does not know if a tile's content will point to...
Definition TileContent.h:23
Definition Model.h:14
