Cesium3DTilesSelection::TileIdUtilities Struct Reference
Utility functions related to TileID objects. More...
#include <Cesium3DTilesSelection/TileID.h>
static std::string createTileIdString (const TileID &tileId)
 Creates an unspecified string representation of the given TileID.
static bool isLoadable (const TileID &tileID)
 Determines if a tile ID is a loadable identifier. All IDs are loadable except for a blank string.
Definition at line 44 of file TileID.h.
◆ createTileIdString()
static std::string Cesium3DTilesSelection::TileIdUtilities::createTileIdString ( const TileID & tileId)
static
The returned string will contain information about the given tile ID, depending on its type. The exact format and contents of this string is not specified. This is mainly intended for printing informative log messages.
tileIdThe tile ID
The string
◆ isLoadable()
static bool Cesium3DTilesSelection::TileIdUtilities::isLoadable ( const TileID & tileID)
static
tileIDThe tile ID to check.
true for all tile IDs except for a blank string.
