CesiumGeometry::BoundingSphere Class Referencefinal
A bounding sphere with a center and a radius. More...
#include <CesiumGeometry/BoundingSphere.h>
constexpr BoundingSphere (const glm::dvec3 &center, double radius) noexcept
 Construct a new instance.
constexpr const glm::dvec3 & getCenter () const noexcept
 Gets the center of the bounding sphere.
constexpr double getRadius () const noexcept
 Gets the radius of the bounding sphere.
CullingResult intersectPlane (const Plane &plane) const noexcept
 Determines on which side of a plane this boundings sphere is located.
double computeDistanceSquaredToPosition (const glm::dvec3 &position) const noexcept
 Computes the distance squared from a position to the closest point on this bounding sphere. Returns 0 if the point is inside the sphere.
bool contains (const glm::dvec3 &position) const noexcept
 Computes whether the given position is contained within the bounding sphere.
BoundingSphere transform (const glm::dmat4 &transformation) const noexcept
 Transforms this bounding sphere to another coordinate system using a 4x4 matrix.
Definition at line 16 of file BoundingSphere.h.
◆ BoundingSphere()
CesiumGeometry::BoundingSphere::BoundingSphere ( const glm::dvec3 & center,
double radius )
inlineconstexprnoexcept
centerThe center of the bounding sphere.
radiusThe radius of the bounding sphere.
Definition at line 24 of file BoundingSphere.h.
◆ computeDistanceSquaredToPosition()
double CesiumGeometry::BoundingSphere::computeDistanceSquaredToPosition ( const glm::dvec3 & position) const
noexcept
positionThe position.
The distance squared from the position to the closest point on this bounding sphere.
// Sort bounding spheres from back to front
glm::dvec3 cameraPosition = anyOldCameraPosition();
std::vector<BoundingSphere> spheres = anyOldSphereArray();
std::sort(
spheres.begin(),
spheres.end(),
[&cameraPosition](auto& a, auto& b) {
return a.computeDistanceSquaredToPosition(cameraPosition) >
b.computeDistanceSquaredToPosition(cameraPosition);
◆ contains()
bool CesiumGeometry::BoundingSphere::contains ( const glm::dvec3 & position) const
noexcept
Whether the position is contained within the bounding sphere.
◆ getCenter()
const glm::dvec3 & CesiumGeometry::BoundingSphere::getCenter ( ) const
Definition at line 30 of file BoundingSphere.h.
◆ getRadius()
double CesiumGeometry::BoundingSphere::getRadius ( ) const
Definition at line 37 of file BoundingSphere.h.
◆ intersectPlane()
CullingResult CesiumGeometry::BoundingSphere::intersectPlane ( const Plane & plane) const
noexcept
planeThe plane to test against.
◆ transform()
BoundingSphere CesiumGeometry::BoundingSphere::transform ( const glm::dmat4 & transformation) const
noexcept
If the transformation has non-uniform scale, the bounding sphere's radius is scaled by the largest scale value among the transformation's axes.
transformationThe transformation.
The bounding sphere in the new coordinate system.
