Cesium3DTilesSelection::TilesetViewGroup Class Referencefinal
Represents a group of views that collectively select tiles from a particular Tileset. More...
#include <Cesium3DTilesSelection/TilesetViewGroup.h>
Inheritance diagram for Cesium3DTilesSelection::TilesetViewGroup:
Cesium3DTilesSelection::TileLoadRequester
Classes
struct  LoadQueueCheckpoint
 A checkpoint within this view group's load queue. More...
Public Types
using TraversalState
 The type of the CesiumUtility::TreeTraversalState used to track tile selection states for this view group.
 TilesetViewGroup () noexcept
 TilesetViewGroup (const TilesetViewGroup &rhs) noexcept
 Constructs a new instance as a copy of an existing one.
 TilesetViewGroup (TilesetViewGroup &&rhs) noexcept
 Moves an existing view group into a new one.
const ViewUpdateResult & getViewUpdateResult () const
 Gets the result from the last time this view group was updated by calling Tileset::updateViewGroup.
TraversalState & getTraversalState () noexcept
 Gets an object used to track the selection state of tiles as they are traversed for this view group.
const TraversalState & getTraversalState () const noexcept
void addToLoadQueue (const TileLoadTask &task, const std::shared_ptr< GltfModifier > &pModifier=nullptr)
 Adds a tile load task to this view group's load queue.
LoadQueueCheckpoint saveTileLoadQueueCheckpoint ()
 Saves a checkpoint of the tile load queue associated with this view group.
size_t restoreTileLoadQueueCheckpoint (const LoadQueueCheckpoint &checkpoint)
 Restores a previously-saved checkpoint of the tile load queue associated with this view group.
size_t getWorkerThreadLoadQueueLength () const
 Gets the number of tiles that are currently in the queue waiting to be loaded in the worker thread.
size_t getMainThreadLoadQueueLength () const
 Gets the number of tiles that are currently in the queue waiting to be loaded in the main thread.
void startNewFrame (const Tileset &tileset, const TilesetFrameState &frameState)
 Starts a new frame.
void finishFrame (const Tileset &tileset, const TilesetFrameState &frameState)
 Finishes the current frame.
float getPreviousLoadProgressPercentage () const
 Gets the previous load progress percentage for this view group as of the last time it was updated.
double getWeight () const override
void setWeight (double weight) noexcept
 Sets the weight of this view group relative to other tile requesters.
bool hasMoreTilesToLoadInWorkerThread () const override
const Tile * getNextTileToLoadInWorkerThread () override
bool hasMoreTilesToLoadInMainThread () const override
const Tile * getNextTileToLoadInMainThread () override
bool isCreditReferenced (CesiumUtility::Credit credit) const noexcept
 Checks if a given credit is referenced in the most recently completed frame.
- Public Member Functions inherited from Cesium3DTilesSelection::TileLoadRequester
void unregister () noexcept
 Unregister this requester with the {link Tileset} with which it is currently registered. Once unregistered, it will not influence tile loads until registered again.
bool isRegistered () const noexcept
 Determines if this requester is currently registered with a Tileset.
Additional Inherited Members
- Protected Member Functions inherited from Cesium3DTilesSelection::TileLoadRequester
 TileLoadRequester () noexcept
 TileLoadRequester (const TileLoadRequester &rhs) noexcept
 TileLoadRequester (TileLoadRequester &&rhs) noexcept
 Moves an existing instance into a new one.
virtual ~TileLoadRequester () noexcept
 Destroys this instance.
Create an instance of this class and pass it repeatedly to Tileset::updateViewGroup to select tiles suitable for rendering the tileset from a given view or set of views.
This class is intentionally decoupled from ViewState, such that clients are responsible for managing which views are represented by any particular group.
Definition at line 36 of file TilesetViewGroup.h.
Member Typedef Documentation
◆ TraversalState
Initial value:
Associates state (arbitrary data) with each node during partial, depth-first traversal of a tree....
Definition at line 43 of file TilesetViewGroup.h.
◆ TilesetViewGroup() [1/2]
Cesium3DTilesSelection::TilesetViewGroup::TilesetViewGroup ( const TilesetViewGroup & rhs)
noexcept
The new instance will be equivalent to the existing one, but it will not be registered with the Cesium3DTilesSelection::Tileset.
rhsThe view group to copy.
◆ TilesetViewGroup() [2/2]
Cesium3DTilesSelection::TilesetViewGroup::TilesetViewGroup ( TilesetViewGroup && rhs)
noexcept
The new instance will be registered with the Cesium3DTilesSelection::Tileset, and the old one will be unregistered.
rhsThe view group to move from.
◆ addToLoadQueue()
void Cesium3DTilesSelection::TilesetViewGroup::addToLoadQueue ( const TileLoadTask & task,
const std::shared_ptr< GltfModifier > & pModifier = nullptr )
Each tile may only be added once per call to startNewFrame. Adding a tile multiple times will lead to an assertion in debug builds and undefined behavior in release builds.
taskThe tile load task to add to the queue.
pModifierThe optional glTF modifier. If not nullptr, this method will also add the tile to load queue if it needs glTF modification. See TilesetExternals::pGltfModifier.
◆ finishFrame()
void Cesium3DTilesSelection::TilesetViewGroup::finishFrame ( const Tileset & tileset,
const TilesetFrameState & frameState )
This method updates the load progress percentage returned by getPreviousLoadProgressPercentage and makes sure credits used by this view group have been referenced on the CesiumUtility::CreditSystem.
tilesetThe tileset that is finishing the current frame.
frameStateThe state of the frame.
◆ getNextTileToLoadInMainThread()
const Tile * Cesium3DTilesSelection::TilesetViewGroup::getNextTileToLoadInMainThread ( )
overridevirtual
Gets the next Tile that this requester would like loaded in the main thread.When hasMoreTilesToLoadInMainThread returns false, this method can and should return nullptr. However, when that method returns true, this method must return a valid Tile pointer.The returned tile must have a reference count greater than zero. Otherwise, the Tile would be immediately eligible for unloading, so it doesn't make sense to load it. In debug builds, this is enforced with an assertion. In release builds, unreferenced tiles are silently ignored.
The next tile to load in the main thread.
Implements Cesium3DTilesSelection::TileLoadRequester.
◆ getNextTileToLoadInWorkerThread()
const Tile * Cesium3DTilesSelection::TilesetViewGroup::getNextTileToLoadInWorkerThread ( )
overridevirtual
Gets the next Tile that this requester would like loaded in a worker thread.When hasMoreTilesToLoadInWorkerThread returns false, this method can and should return nullptr. However, when that method returns true, this method must return a valid Tile pointer.The returned tile must have a reference count greater than zero. Otherwise, the Tile would be immediately eligible for unloading, so it doesn't make sense to load it. In debug builds, this is enforced with an assertion. In release builds, unreferenced tiles are silently ignored.
The next tile to load in a worker thread.
◆ getPreviousLoadProgressPercentage()
float Cesium3DTilesSelection::TilesetViewGroup::getPreviousLoadProgressPercentage ( ) const
This method reports the progress as of the last call to finishFrame.
The reported percentage is computed as:
\(100.0\frac{totalTilesVisited - tilesNeedingLoading}{totalTilesVisited}\)
When loading is complete, this method will return exactly 100.0.
◆ getTraversalState() [1/2]
const TraversalState & Cesium3DTilesSelection::TilesetViewGroup::getTraversalState ( ) const
inlinenoexcept
Definition at line 89 of file TilesetViewGroup.h.
◆ getTraversalState() [2/2]
inlinenoexcept
Definition at line 86 of file TilesetViewGroup.h.
◆ getViewUpdateResult()
ViewUpdateResult & Cesium3DTilesSelection::TilesetViewGroup::getViewUpdateResult ( )
◆ getWeight()
double Cesium3DTilesSelection::TilesetViewGroup::getWeight ( ) const
overridevirtual
Gets the weight of this requester relative to others.Most requesters should return a weight of 1.0. When all requesters have the same weight, they will all have an equal opportunity to load tiles. If one requester's weight is 2.0 and the rest are 1.0, that requester will have twice as many opportunities to load tiles as the others.A very high weight will prevent all other requesters from loading tiles until this requester has none left to load. A very low weight (but above 0.0!) will allow all other requesters to finish loading tiles before this one starts.
The weight of this requester, which must be greater than 0.0.
◆ hasMoreTilesToLoadInMainThread()
bool Cesium3DTilesSelection::TilesetViewGroup::hasMoreTilesToLoadInMainThread ( ) const
overridevirtual
Determines if this requester has any more tiles that need to be loaded in the main thread. To determine if a particular Tile needs to be loaded in the main thread, call Tile::needsMainThreadLoading.
true if this requester has further tiles that need loading by the main thread; otherwise, false.
◆ hasMoreTilesToLoadInWorkerThread()
bool Cesium3DTilesSelection::TilesetViewGroup::hasMoreTilesToLoadInWorkerThread ( ) const
overridevirtual
Determines if this requester has any more tiles that need to be loaded in a worker thread. To determine if a particular Tile needs to be loaded in a worker thread, call Tile::needsWorkerThreadLoading.
true if this requester has further tiles that need loading by a worker thread; otherwise, false.
◆ isCreditReferenced()
bool Cesium3DTilesSelection::TilesetViewGroup::isCreditReferenced ( CesiumUtility::Credit credit) const
noexcept
Note that this method checks the most recently completed frame. So, after a call to finishFrame (the common case), this method will check the frame that was just finished. If called in between calls to startNewFrame and finishFrame (i.e., during the course of a call to Tileset::updateViewGroup), it will check the frame prior to the current, in-progress one, because the current one has not yet been completed.
creditThe credit to test.
True if the credit was referenced in this view group's most recently completed frame.
◆ restoreTileLoadQueueCheckpoint()
size_t Cesium3DTilesSelection::TilesetViewGroup::restoreTileLoadQueueCheckpoint ( const LoadQueueCheckpoint & checkpoint)
Restoring a checkpoint discards all tiles from the queue that were requested, with a call to addToLoadQueue, since the checkpoint was created.
This method should only be called in between calls to startNewFrame and finishFrame.
checkpointThe previously-created checkpoint.
The number of tiles that were discarded from the queue as a result of restoring the checkpoint.
◆ saveTileLoadQueueCheckpoint()
LoadQueueCheckpoint Cesium3DTilesSelection::TilesetViewGroup::saveTileLoadQueueCheckpoint ( )
The saved checkpoint can later be restored by calling restoreTileLoadQueueCheckpoint.
The checkpoint.
◆ setWeight()
void Cesium3DTilesSelection::TilesetViewGroup::setWeight ( double weight)
noexcept
See getWeight for an explanation of the meaning of the weight.
weightThe new weight for this view group.
◆ startNewFrame()
void Cesium3DTilesSelection::TilesetViewGroup::startNewFrame ( const Tileset & tileset,
Starts a new frame.
This method clears the set of tiles to be loaded so that a new set can be selected. It also makes the current tile selection state the previous one and releases references to tiles in the old previous one.
tilesetThe tileset that is starting the new frame.
frameStateThe state of the new frame.
