cesium-native 0.67.0
Additional options for configuring a Tileset. More...
#include <Cesium3DTilesSelection/TilesetOptions.h>
| std::optional< std::string > | credit |
| A credit text for this tileset, if needed. | |
| bool | showCreditsOnScreen = false |
| Whether or not to display tileset's credits on the screen. | |
| double | maximumScreenSpaceError = 16.0 |
| The maximum number of pixels of error when rendering this tileset. This is used to select an appropriate level-of-detail. | |
| uint32_t | maximumSimultaneousTileLoads = 20 |
| The maximum number of tiles that may simultaneously be in the process of loading. | |
| bool | preloadAncestors = true |
| Indicates whether the ancestors of rendered tiles should be preloaded. Setting this to true optimizes the zoom-out experience and provides more detail in newly-exposed areas when panning. The down side is that it requires loading more tiles. | |
| bool | preloadSiblings = true |
| Indicates whether the siblings of rendered tiles should be preloaded. Setting this to true causes tiles with the same parent as a rendered tile to be loaded, even if they are culled. Setting this to true may provide a better panning experience at the cost of loading more tiles. | |
| uint32_t | loadingDescendantLimit = 20 |
| The number of loading descendant tiles that is considered "too
many". If a tile has too many loading descendants, that tile will be loaded and rendered before any of its descendants are loaded and rendered. This means more feedback for the user that something is happening at the cost of a longer overall load time. Setting this to 0 will cause each tile level to be loaded successively, significantly increasing load time. Setting it to a large number (e.g. 1000) will minimize the number of tiles that are loaded but tend to make detail appear all at once after a long wait. | |
| bool | forbidHoles = false |
| Never render a tileset with missing tiles. | |
| bool | enableFrustumCulling = true |
| Enable culling of tiles against the frustum. | |
| bool | enableOcclusionCulling = true |
| Enable culling of occluded tiles, as reported by the renderer. | |
| bool | delayRefinementForOcclusion = true |
| Wait to refine until the occlusion state of a tile is known. | |
| bool | enableFogCulling = true |
| Enable culling of tiles that cannot be seen through atmospheric fog. | |
| bool | enforceCulledScreenSpaceError = true |
| Whether culled tiles should be refined until they meet culledScreenSpaceError. | |
| double | culledScreenSpaceError = 64.0 |
| The screen-space error to refine until for culled tiles from disabled culling stages. | |
| int64_t | maximumCachedBytes = 512LL * 1024 * 1024 |
| The maximum number of bytes that may be cached. | |
| std::vector< FogDensityAtHeight > | fogDensityTable |
A table that maps the camera height above the ellipsoid to a fog density. Tiles that are in full fog are culled. The density of the fog increases as this number approaches 1.0 and becomes less dense as it approaches zero. The more dense the fog is, the more aggressively the tiles are culled. For example, if the camera is a height of 1000.0m above the ellipsoid, increasing the value to 3.0e-3 will cause many tiles close to the viewer be culled. Decreasing the value will push the fog further from the viewer, but decrease performance as more of the tiles are rendered. Tiles are culled when 1.0 - glm::exp(-(distance * distance * fogDensity * fogDensity)) is >= 1.0. | |
| bool | renderTilesUnderCamera = true |
| Whether to render tiles directly under the camera, even if they're not in the view frustum. | |
| std::vector< std::shared_ptr< ITileExcluder > > | excluders |
| A list of interfaces that are given an opportunity to exclude tiles from loading and rendering. If any of the excluders indicate that a tile should not be loaded, it will not be loaded. | |
| std::function< void(const TilesetLoadFailureDetails &)> | loadErrorCallback |
| A callback function that is invoked when a tileset resource fails to load. | |
| bool | enableLodTransitionPeriod = false |
| Whether to keep tiles loaded during a transition period when switching to a different LOD tile. | |
| float | lodTransitionLength = 1.0f |
| How long it should take to transition between tiles of different LODs, in seconds. | |
| bool | kickDescendantsWhileFadingIn = true |
| Whether to kick descendants while a tile is still fading in. | |
| double | mainThreadLoadingTimeLimit = 0.0 |
| A soft limit on how long (in milliseconds) to spend on the main-thread part of tile loading each frame (each call to Tileset::loadTiles). A value of 0.0 indicates that all pending main-thread loads should be completed each tick. | |
| double | tileCacheUnloadTimeLimit = 0.0 |
| A soft limit on how long (in milliseconds) to spend unloading cached tiles each frame (each call to Tileset::loadTiles). A value of 0.0 indicates that the tile cache should not throttle unloading tiles. | |
| TilesetContentOptions | contentOptions |
| Options for configuring the parsing of a Tileset's content and construction of Gltf models. | |
| std::any | rendererOptions |
| Arbitrary data that will be passed to IPrepareRendererResources::prepareInLoadThread. | |
| CesiumGeospatial::Ellipsoid | ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 |
| The ellipsoid to use for this tileset. This value shouldn't be changed after the tileset is constructed. If you need to change a tileset's ellipsoid, please recreate the tileset. | |
| std::vector< CesiumAsync::IAssetAccessor::THeader > | requestHeaders |
| HTTP headers to attach to requests made for this tileset. | |
Definition at line 37 of file TilesetOptions.h.
| TilesetContentOptions Cesium3DTilesSelection::TilesetOptions::contentOptions |
Definition at line 275 of file TilesetOptions.h.
| std::optional<std::string> Cesium3DTilesSelection::TilesetOptions::credit |
Definition at line 41 of file TilesetOptions.h.
| double Cesium3DTilesSelection::TilesetOptions::culledScreenSpaceError = 64.0 |
When enforceCulledScreenSpaceError is true, culled tiles from disabled culling stages will be refined until they meet this screen-space error value.
Definition at line 151 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::delayRefinementForOcclusion = true |
Only applicable when enableOcclusionInfo is true. Enabling this option may cause a small delay between when a tile is needed according to the SSE and when the tile load is kicked off. On the other hand, this delay could allow the occlusion system to avoid loading a tile entirely if it is found to be unnecessary a few frames later.
Definition at line 125 of file TilesetOptions.h.
| CesiumGeospatial::Ellipsoid Cesium3DTilesSelection::TilesetOptions::ellipsoid = CesiumGeospatial::Ellipsoid::WGS84 |
If no ellipsoid is set, Ellipsoid::WGS84 will be used by default.
Definition at line 293 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::enableFogCulling = true |
Definition at line 130 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::enableFrustumCulling = true |
Definition at line 109 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::enableLodTransitionPeriod = false |
For each tile, TileRenderContent::getLodTransitionFadePercentage will indicate to the client how faded to render the tile throughout the transition. Tile fades can be used to mask LOD transitions and make them appear less abrupt and jarring.
Because each tile currently has only one transition fade percentage, it is recommended that this option be set to false when using multiple TilesetViewGroup instances.
Definition at line 226 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::enableOcclusionCulling = true |
Definition at line 114 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::enforceCulledScreenSpaceError = true |
When true, any culled tile from a disabled culling stage will be refined until it meets the specified culledScreenSpaceError. Otherwise, its screen-space error check will be disabled altogether and it will not bother to refine any futher.
Definition at line 141 of file TilesetOptions.h.
| std::vector<std::shared_ptr<ITileExcluder> > Cesium3DTilesSelection::TilesetOptions::excluders |
Definition at line 201 of file TilesetOptions.h.
| std::vector<FogDensityAtHeight> Cesium3DTilesSelection::TilesetOptions::fogDensityTable |
Definition at line 176 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::forbidHoles = false |
When true, the tileset will guarantee that the tileset will never be rendered with holes in place of tiles that are not yet loaded. It does this by refusing to refine a parent tile until all of its child tiles are ready to render. Thus, when the camera moves, we will always have something - even if it's low resolution - to render any part of the tileset that becomes visible. When false, overall loading will be faster, but newly-visible parts of the tileset may initially be blank.
Definition at line 104 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::kickDescendantsWhileFadingIn = true |
This property is ignored if enableLodTransitionPeriod is false.
This does not delay loading of descendants, but it keeps them off the render list while the tile is fading in. If this is false, the tile currently fading in will pop in to full opacity if descendants are rendered (this counteracts the benefits of LOD transition blending).
Definition at line 251 of file TilesetOptions.h.
| std::function<void(const TilesetLoadFailureDetails&)> Cesium3DTilesSelection::TilesetOptions::loadErrorCallback |
Tileset resources include a Cesium ion asset endpoint, a tileset's root tileset.json or layer.json, an individual tile's content, or an implicit tiling subtree.
Definition at line 211 of file TilesetOptions.h.
| uint32_t Cesium3DTilesSelection::TilesetOptions::loadingDescendantLimit = 20 |
The number of loading descendant tiles that is considered "too many". If a tile has too many loading descendants, that tile will be loaded and rendered before any of its descendants are loaded and rendered. This means more feedback for the user that something is happening at the cost of a longer overall load time. Setting this to 0 will cause each tile level to be loaded successively, significantly increasing load time. Setting it to a large number (e.g. 1000) will minimize the number of tiles that are loaded but tend to make detail appear all at once after a long wait.
Definition at line 91 of file TilesetOptions.h.
| float Cesium3DTilesSelection::TilesetOptions::lodTransitionLength = 1.0f |
When a tile refines or unrefines to a higher or lower LOD tile, a fade can optionally be applied to smooth the transition. This value determines how many seconds the whole transition should take. Note that the old tile doesn't start fading out until the new tile fully fades in.
Definition at line 239 of file TilesetOptions.h.
| double Cesium3DTilesSelection::TilesetOptions::mainThreadLoadingTimeLimit = 0.0 |
Setting this to too low of a value will impede overall tile load progress, creating a discernable load latency.
Definition at line 262 of file TilesetOptions.h.
| int64_t Cesium3DTilesSelection::TilesetOptions::maximumCachedBytes = 512LL * 1024 * 1024 |
Note that this value, even if 0, will never cause tiles that are needed for rendering to be unloaded. However, if the total number of loaded bytes is greater than this value, tiles will be unloaded until the total is under this number or until only required tiles remain, whichever comes first.
Definition at line 162 of file TilesetOptions.h.
| double Cesium3DTilesSelection::TilesetOptions::maximumScreenSpaceError = 16.0 |
When a tileset uses the older layer.json / quantized-mesh format rather than 3D Tiles, this value is effectively divided by 8.0. So the default value of 16.0 corresponds to the standard value for quantized-mesh terrain of 2.0.
Definition at line 57 of file TilesetOptions.h.
| uint32_t Cesium3DTilesSelection::TilesetOptions::maximumSimultaneousTileLoads = 20 |
Definition at line 63 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::preloadAncestors = true |
Definition at line 71 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::preloadSiblings = true |
Definition at line 79 of file TilesetOptions.h.
| std::any Cesium3DTilesSelection::TilesetOptions::rendererOptions |
This object is copied and given to tile preparation threads, so it must be inexpensive to copy.
Definition at line 284 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::renderTilesUnderCamera = true |
This is useful for detecting the camera's collision with terrain and other models. NOTE: This option currently only works with tiles that use a region as their bounding volume. It is ignored for other bounding volume types.
Definition at line 194 of file TilesetOptions.h.
| std::vector<CesiumAsync::IAssetAccessor::THeader> Cesium3DTilesSelection::TilesetOptions::requestHeaders |
Definition at line 298 of file TilesetOptions.h.
| bool Cesium3DTilesSelection::TilesetOptions::showCreditsOnScreen = false |
Definition at line 46 of file TilesetOptions.h.
| double Cesium3DTilesSelection::TilesetOptions::tileCacheUnloadTimeLimit = 0.0 |
Definition at line 269 of file TilesetOptions.h.
