Cesium3DTilesSelection::RasterMappedTo3DTile Class Referencefinal
The result of applying a CesiumRasterOverlays::RasterOverlayTile to geometry. More...
#include <Cesium3DTilesSelection/RasterMappedTo3DTile.h>
Public Types
enum class  AttachmentState { Unattached = 0 , TemporarilyAttached = 1 , Attached = 2 }
 The states indicating whether the raster tile is attached to the geometry. More...
 RasterMappedTo3DTile (const CesiumUtility::IntrusivePointer< CesiumRasterOverlays::RasterOverlayTile > &pRasterTile, int32_t textureCoordinateIndex)
 Creates a new instance.
CesiumRasterOverlays::RasterOverlayTile * getLoadingTile () noexcept
 Returns a CesiumRasterOverlays::RasterOverlayTile that is currently loading.
const CesiumRasterOverlays::RasterOverlayTile * getLoadingTile () const noexcept
CesiumRasterOverlays::RasterOverlayTile * getReadyTile () noexcept
 Returns the CesiumRasterOverlays::RasterOverlayTile that represents the imagery data that is ready to render.
const CesiumRasterOverlays::RasterOverlayTile * getReadyTile () const noexcept
int32_t getTextureCoordinateID () const noexcept
 Returns an identifier for the texture coordinates of this tile.
void setTextureCoordinateID (int32_t textureCoordinateID) noexcept
 Sets the texture coordinate ID.
const glm::dvec2 & getTranslation () const noexcept
 Returns the translation that converts between the geometry texture coordinates and the texture coordinates that should be used to sample this raster texture.
const glm::dvec2 & getScale () const noexcept
 Returns the scaling that converts between the geometry texture coordinates and the texture coordinates that should be used to sample this raster texture.
AttachmentState getState () const noexcept
 Indicates whether this overlay tile is currently attached to its owning geometry tile.
CesiumRasterOverlays::RasterOverlayTile::MoreDetailAvailable update (IPrepareRendererResources &prepareRendererResources, Tile &tile)
 Update this tile during the update of its owner.
bool isMoreDetailAvailable () const noexcept
 Determines if more detailed data is available for the spatial area covered by this tile.
void detachFromTile (IPrepareRendererResources &prepareRendererResources, Tile &tile) noexcept
 Detach the raster from the given tile.
bool loadThrottled () noexcept
 Does a throttled load of the mapped CesiumRasterOverlays::RasterOverlayTile.
static RasterMappedTo3DTile * mapOverlayToTile (double maximumScreenSpaceError, CesiumRasterOverlays::ActivatedRasterOverlay &activatedOverlay, Tile &tile, std::vector< CesiumGeospatial::Projection > &missingProjections, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Creates a maping between a CesiumRasterOverlays::RasterOverlay and a Tile.
Instances of this class are used by a Tile in order to map imagery data that is given as CesiumRasterOverlays::RasterOverlayTile instances to the 2D region that is covered by the tile geometry.
Definition at line 27 of file RasterMappedTo3DTile.h.
Member Enumeration Documentation
◆ AttachmentState
Enumerator
Unattached
This raster tile is not yet attached to the geometry at all.
TemporarilyAttached
This raster tile is attached to the geometry, but it is a temporary, low-res version usable while the full-res version is loading.
Attached
This raster tile is attached to the geometry.
Definition at line 33 of file RasterMappedTo3DTile.h.
◆ RasterMappedTo3DTile()
Cesium3DTilesSelection::RasterMappedTo3DTile::RasterMappedTo3DTile ( const CesiumUtility::IntrusivePointer< CesiumRasterOverlays::RasterOverlayTile > & pRasterTile,
int32_t textureCoordinateIndex )
pRasterTileThe CesiumRasterOverlays::RasterOverlayTile that is mapped to the geometry.
textureCoordinateIndexThe index of the texture coordinates to use with this mapped raster overlay.
◆ detachFromTile()
void Cesium3DTilesSelection::RasterMappedTo3DTile::detachFromTile ( IPrepareRendererResources & prepareRendererResources,
Tile & tile )
noexcept
prepareRendererResourcesThe IPrepareRendererResources used to detach raster overlay from the tile geometry
tileThe owner tile.
◆ getLoadingTile() [1/2]
const CesiumRasterOverlays::RasterOverlayTile * Cesium3DTilesSelection::RasterMappedTo3DTile::getLoadingTile ( ) const
inlinenoexcept
The caller has to check the exact state of this tile, using Tile::getState.
The tile that is loading, or nullptr.
Definition at line 79 of file RasterMappedTo3DTile.h.
◆ getLoadingTile() [2/2]
inlinenoexcept
Definition at line 73 of file RasterMappedTo3DTile.h.
◆ getReadyTile() [1/2]
const CesiumRasterOverlays::RasterOverlayTile * Cesium3DTilesSelection::RasterMappedTo3DTile::getReadyTile ( ) const
inlinenoexcept
This will be nullptr when the tile data has not yet been loaded.
The tile, or nullptr.
Definition at line 96 of file RasterMappedTo3DTile.h.
◆ getReadyTile() [2/2]
inlinenoexcept
Definition at line 91 of file RasterMappedTo3DTile.h.
◆ getScale()
const glm::dvec2 & Cesium3DTilesSelection::RasterMappedTo3DTile::getScale ( ) const
inlinenoexcept
See also
getTranslation
The scaling.
Definition at line 145 of file RasterMappedTo3DTile.h.
◆ getState()
AttachmentState Cesium3DTilesSelection::RasterMappedTo3DTile::getState ( ) const
inlinenoexcept
When a raster overlay tile is attached to a geometry tile, IPrepareRendererResources::attachRasterInMainThread is invoked. When it is detached, IPrepareRendererResources::detachRasterInMainThread is invoked.
Definition at line 156 of file RasterMappedTo3DTile.h.
◆ getTextureCoordinateID()
int32_t Cesium3DTilesSelection::RasterMappedTo3DTile::getTextureCoordinateID ( ) const
inlinenoexcept
The texture coordinates for this raster are found in the glTF as an attribute named _CESIUMOVERLAY_n where n is this value.
The texture coordinate ID.
Definition at line 108 of file RasterMappedTo3DTile.h.
◆ getTranslation()
const glm::dvec2 & Cesium3DTilesSelection::RasterMappedTo3DTile::getTranslation ( ) const
inlinenoexcept
rasterCoordinates = geometryCoordinates * scale + translation
The translation.
Definition at line 132 of file RasterMappedTo3DTile.h.
◆ isMoreDetailAvailable()
bool Cesium3DTilesSelection::RasterMappedTo3DTile::isMoreDetailAvailable ( ) const
noexcept
◆ loadThrottled()
bool Cesium3DTilesSelection::RasterMappedTo3DTile::loadThrottled ( )
noexcept
If the mapped tile is already in the process of loading or it has already finished loading, this method does nothing and returns true. If too many loads are already in progress, this method does nothing and returns false. Otherwise, it begins the asynchronous process to load the tile and returns true.
◆ mapOverlayToTile()
static RasterMappedTo3DTile * Cesium3DTilesSelection::RasterMappedTo3DTile::mapOverlayToTile ( double maximumScreenSpaceError,
CesiumRasterOverlays::ActivatedRasterOverlay & activatedOverlay,
Tile & tile,
std::vector< CesiumGeospatial::Projection > & missingProjections,
static
The returned mapping will be to a placeholder CesiumRasterOverlays::RasterOverlayTile if the overlay's tile provider is not yet ready (i.e. it's still a placeholder) or if the overlap between the tile and the raster overlay cannot yet be determined because the projected rectangle of the tile is not yet known.
Returns a pointer to the created RasterMappedTo3DTile in the Tile's Tile::getMappedRasterTiles collection. Note that this pointer may become invalid as soon as another item is added to or removed from this collection.
maximumScreenSpaceErrorThe maximum screen space error that is used for the current tile
activatedOverlayThe activated overlay to map to the tile.
tileThe tile to which to map the overlay.
missingProjectionsThe list of projections for which there are not yet any texture coordiantes. On return, the given overlay's Projection may be added to this collection if the Tile does not yet have texture coordinates for the Projection and the Projection is not already in the collection.
A pointer the created mapping, which may be to a placeholder, or nullptr if no mapping was created at all because the Tile does not overlap the raster overlay.
◆ setTextureCoordinateID()
void Cesium3DTilesSelection::RasterMappedTo3DTile::setTextureCoordinateID ( int32_t textureCoordinateID)
inlinenoexcept
See also
textureCoordinateIDThe ID.
Definition at line 119 of file RasterMappedTo3DTile.h.
◆ update()
CesiumRasterOverlays::RasterOverlayTile::MoreDetailAvailable Cesium3DTilesSelection::RasterMappedTo3DTile::update ( IPrepareRendererResources & prepareRendererResources,
Tile & tile )
This is only supposed to be called by TilesetContentManager::updateDoneState. It will return whether there is a more detailed version of the raster data available.
prepareRendererResourcesThe IPrepareRendererResources used to create render resources for raster overlay
tileThe owner tile.
The CesiumRasterOverlays::RasterOverlayTile::MoreDetailAvailable state.
