Holds the metadata associated with a Tileset or an external tileset. This holds all of the fields of Cesium3DTiles::Tileset except for the root tile. More...
#include <Cesium3DTilesSelection/TilesetMetadata.h>
| CesiumAsync::SharedFuture< void > & | loadSchemaUri (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor) |
| Asynchronously loads the schema from the schemaUri. If the schemaUri does not contain a value, this method does nothing and returns an already-resolved future. | |
| Cesium3DTiles::Asset | asset |
| Metadata about the entire tileset. | |
| std::unordered_map< std::string, Cesium3DTiles::Properties > | properties |
| A dictionary object of metadata about per-feature properties. | |
| std::optional< Cesium3DTiles::Schema > | schema |
An object defining the structure of metadata classes and enums. When this is defined, then schemaUri shall be undefined. | |
| std::optional< std::string > | schemaUri |
The URI (or IRI) of the external schema file. When this is defined, then schema shall be undefined. | |
| std::optional< Cesium3DTiles::Statistics > | statistics |
| An object containing statistics about metadata entities. | |
| std::vector< Cesium3DTiles::GroupMetadata > | groups |
An array of groups that tile content may belong to. Each element of this array is a metadata entity that describes the group. The tile content group property is an index into this array. | |
| std::optional< Cesium3DTiles::MetadataEntity > | metadata |
| A metadata entity that is associated with this tileset. | |
| std::optional< double > | geometricError |
| The error, in meters, introduced if this tileset is not rendered. At runtime, the geometric error is used to compute screen space error (SSE), i.e., the error measured in pixels. | |
| std::vector< std::string > | extensionsUsed |
| Names of 3D Tiles extensions used somewhere in this tileset. | |
| std::vector< std::string > | extensionsRequired |
Names of 3D Tiles extensions required to properly load this tileset. Each element of this array shall also be contained in extensionsUsed. | |
Definition at line 29 of file TilesetMetadata.h.
| CesiumAsync::SharedFuture< void > & Cesium3DTilesSelection::TilesetMetadata::loadSchemaUri | ( | const CesiumAsync::AsyncSystem & | asyncSystem, |
| const std::shared_ptr< CesiumAsync::IAssetAccessor > & | pAssetAccessor ) |
Calling this method multiple times will return the same shared future each time, unless the schemaUri is changed. In that case, when this method is called, the previous load is canceled and the new one begins.
| asyncSystem | The async system used to do work in threads. |
| pAssetAccessor | The asset accessor used to request the schema from the schemaUri. |
| Cesium3DTiles::Asset Cesium3DTilesSelection::TilesetMetadata::asset |
Definition at line 37 of file TilesetMetadata.h.
| std::vector<std::string> Cesium3DTilesSelection::TilesetMetadata::extensionsRequired |
Definition at line 89 of file TilesetMetadata.h.
| std::vector<std::string> Cesium3DTilesSelection::TilesetMetadata::extensionsUsed |
Definition at line 83 of file TilesetMetadata.h.
| std::optional<double> Cesium3DTilesSelection::TilesetMetadata::geometricError |
Definition at line 78 of file TilesetMetadata.h.
| std::vector<Cesium3DTiles::GroupMetadata> Cesium3DTilesSelection::TilesetMetadata::groups |
Definition at line 66 of file TilesetMetadata.h.
| std::optional<Cesium3DTiles::MetadataEntity> Cesium3DTilesSelection::TilesetMetadata::metadata |
Definition at line 71 of file TilesetMetadata.h.
| std::unordered_map<std::string, Cesium3DTiles::Properties> Cesium3DTilesSelection::TilesetMetadata::properties |
Definition at line 42 of file TilesetMetadata.h.
| std::optional<Cesium3DTiles::Schema> Cesium3DTilesSelection::TilesetMetadata::schema |
Definition at line 48 of file TilesetMetadata.h.
| std::optional<std::string> Cesium3DTilesSelection::TilesetMetadata::schemaUri |
Definition at line 54 of file TilesetMetadata.h.
| std::optional<Cesium3DTiles::Statistics> Cesium3DTilesSelection::TilesetMetadata::statistics |
Definition at line 59 of file TilesetMetadata.h.
