CesiumGeospatial::Ellipsoid Class Referencefinal
A quadratic surface defined in Cartesian coordinates. More...
#include <CesiumGeospatial/Ellipsoid.h>
constexpr Ellipsoid (double x, double y, double z) noexcept
 Creates a new instance.
constexpr Ellipsoid (const glm::dvec3 &radii) noexcept
constexpr const glm::dvec3 & getRadii () const noexcept
 Returns the radii in x-, y-, and z-direction.
glm::dvec3 geodeticSurfaceNormal (const glm::dvec3 &position) const noexcept
 Computes the normal of the plane tangent to the surface of the ellipsoid at the provided position.
glm::dvec3 geodeticSurfaceNormal (const Cartographic &cartographic) const noexcept
glm::dvec3 cartographicToCartesian (const Cartographic &cartographic) const noexcept
 Converts the provided Cartographic to cartesian representation.
std::optional< Cartographic > cartesianToCartographic (const glm::dvec3 &cartesian) const noexcept
 Converts the provided cartesian to a Cartographic representation.
std::optional< glm::dvec3 > scaleToGeodeticSurface (const glm::dvec3 &cartesian) const noexcept
 Scales the given cartesian position along the geodetic surface normal so that it is on the surface of this ellipsoid.
std::optional< glm::dvec3 > scaleToGeocentricSurface (const glm::dvec3 &cartesian) const noexcept
 Scales the provided cartesian position along the geocentric surface normal so that it is on the surface of this ellipsoid.
constexpr double getMaximumRadius () const noexcept
 The maximum radius in any dimension.
constexpr double getMinimumRadius () const noexcept
 The minimum radius in any dimension.
constexpr bool operator== (const Ellipsoid &rhs) const noexcept
 Returns true if two elliposids are equal.
constexpr bool operator!= (const Ellipsoid &rhs) const noexcept
 Returns true if two elliposids are not equal.
static const Ellipsoid WGS84
 An Ellipsoid instance initialized to the WGS84 standard.
static const Ellipsoid UNIT_SPHERE
 An Ellipsoid with all three radii set to one meter.
The surface is defined by the equation (x / a)^2 + (y / b)^2 + (z / c)^2 = 1. This is primarily used by Cesium to represent the shape of planetary bodies. Rather than constructing this object directly, one of the provided constants is normally used.
See also
What is an ellipsoid?
Definition at line 39 of file Ellipsoid.h.
◆ Ellipsoid() [1/2]
CesiumGeospatial::Ellipsoid::Ellipsoid ( double x,
double y,
double z )
inlineconstexprnoexcept
xThe radius in x-direction.
yThe radius in y-direction.
zThe radius in z-direction.
Definition at line 62 of file Ellipsoid.h.
◆ Ellipsoid() [2/2]
CesiumGeospatial::Ellipsoid::Ellipsoid ( const glm::dvec3 & radii)
radiiThe radii in x-, y-, and z-direction.
Definition at line 70 of file Ellipsoid.h.
◆ cartesianToCartographic()
std::optional< Cartographic > CesiumGeospatial::Ellipsoid::cartesianToCartographic ( const glm::dvec3 & cartesian) const
noexcept
The result will be the empty optional if the given cartesian is at the center of this ellipsoid.
cartesianThe cartesian position.
The Cartographic representation, or the empty optional if the cartesian is at the center of this ellipsoid.
◆ cartographicToCartesian()
glm::dvec3 CesiumGeospatial::Ellipsoid::cartographicToCartesian ( const Cartographic & cartographic) const
noexcept
cartographicThe Cartographic position.
The cartesian representation.
◆ geodeticSurfaceNormal() [1/2]
glm::dvec3 CesiumGeospatial::Ellipsoid::geodeticSurfaceNormal ( const Cartographic & cartographic) const
noexcept
cartographicThe Cartographic position for which to to determine the surface normal.
The normal.
◆ geodeticSurfaceNormal() [2/2]
glm::dvec3 CesiumGeospatial::Ellipsoid::geodeticSurfaceNormal ( const glm::dvec3 & position) const
noexcept
positionThe cartesian position for which to to determine the surface normal.
The normal.
◆ getMaximumRadius()
double CesiumGeospatial::Ellipsoid::getMaximumRadius ( ) const
The maximum radius.
Definition at line 160 of file Ellipsoid.h.
◆ getMinimumRadius()
double CesiumGeospatial::Ellipsoid::getMinimumRadius ( ) const
The minimum radius.
Definition at line 169 of file Ellipsoid.h.
◆ getRadii()
const glm::dvec3 & CesiumGeospatial::Ellipsoid::getRadii ( ) const
Definition at line 83 of file Ellipsoid.h.
◆ operator!=()
bool CesiumGeospatial::Ellipsoid::operator!= ( const Ellipsoid & rhs) const
Definition at line 183 of file Ellipsoid.h.
◆ operator==()
bool CesiumGeospatial::Ellipsoid::operator== ( const Ellipsoid & rhs) const
Definition at line 176 of file Ellipsoid.h.
◆ scaleToGeocentricSurface()
std::optional< glm::dvec3 > CesiumGeospatial::Ellipsoid::scaleToGeocentricSurface ( const glm::dvec3 & cartesian) const
noexcept
cartesianThe cartesian position to scale.
The scaled position, or the empty optional if the cartesian is at the center of this ellipsoid.
◆ scaleToGeodeticSurface()
std::optional< glm::dvec3 > CesiumGeospatial::Ellipsoid::scaleToGeodeticSurface ( const glm::dvec3 & cartesian) const
noexcept
The result will be the empty optional if the position is at the center of this ellipsoid.
◆ UNIT_SPHERE
const Ellipsoid CesiumGeospatial::Ellipsoid::UNIT_SPHERE
static
Definition at line 53 of file Ellipsoid.h.
◆ WGS84
const Ellipsoid CesiumGeospatial::Ellipsoid::WGS84
static
The ellipsoid is initialized to the World Geodetic System (WGS84) standard, as defined in https://earth-info.nga.mil/GandG/publications/tr8350.2/wgs84fin.pdf.
Definition at line 48 of file Ellipsoid.h.
