CesiumGeometry::OrientedBoundingBox Class Referencefinal
A bounding volume defined as a closed and convex cuboid with any orientation. More...
#include <CesiumGeometry/OrientedBoundingBox.h>
 OrientedBoundingBox (const glm::dvec3 &center, const glm::dmat3 &halfAxes) noexcept
constexpr const glm::dvec3 & getCenter () const noexcept
 Gets the center of the box.
constexpr const glm::dmat3 & getHalfAxes () const noexcept
 Gets the three orthogonal half-axes of the bounding box. Equivalently, the transformation matrix to rotate and scale a 2x2x2 cube centered at the origin.
constexpr const glm::dmat3 & getInverseHalfAxes () const noexcept
 Gets the inverse transformation matrix, to rotate from world space to local space relative to the box.
constexpr const glm::dvec3 & getLengths () const noexcept
 Gets the lengths of the box on each local axis respectively.
CullingResult intersectPlane (const Plane &plane) const noexcept
 Determines on which side of a plane the bounding box is located.
double computeDistanceSquaredToPosition (const glm::dvec3 &position) const noexcept
 Computes the distance squared from a given position to the closest point on this bounding volume. The bounding volume and the position must be expressed in the same coordinate system.
bool contains (const glm::dvec3 &position) const noexcept
 Computes whether the given position is contained within the bounding box.
OrientedBoundingBox transform (const glm::dmat4 &transformation) const noexcept
 Transforms this bounding box to another coordinate system using a 4x4 matrix.
AxisAlignedBox toAxisAligned () const noexcept
 Converts this oriented bounding box to an axis-aligned bounding box.
BoundingSphere toSphere () const noexcept
 Converts this oriented bounding box to a bounding sphere.
static OrientedBoundingBox fromAxisAligned (const AxisAlignedBox &axisAligned) noexcept
 Creates an oriented bounding box from the given axis-aligned bounding box.
static OrientedBoundingBox fromSphere (const BoundingSphere &sphere) noexcept
 Creates an oriented bounding box from the given bounding sphere.
See also
BoundingSphere
BoundingRegion
Definition at line 22 of file OrientedBoundingBox.h.
◆ OrientedBoundingBox()
CesiumGeometry::OrientedBoundingBox::OrientedBoundingBox ( const glm::dvec3 & center,
const glm::dmat3 & halfAxes )
inlinenoexcept
centerThe center of the box.
halfAxesThe three orthogonal half-axes of the bounding box. Equivalently, the transformation matrix to rotate and scale a 2x2x2 cube centered at the origin.
// Create an OrientedBoundingBox using a transformation matrix, a position
// where the box will be translated, and a scale.
glm::dvec3 center = glm::dvec3(1.0, 0.0, 0.0);
glm::dmat3 halfAxes = glm::dmat3(
glm::dvec3(1.0, 0.0, 0.0),
glm::dvec3(0.0, 3.0, 0.0),
glm::dvec3(0.0, 0.0, 2.0));
auto obb = OrientedBoundingBox(center, halfAxes);
Definition at line 34 of file OrientedBoundingBox.h.
◆ computeDistanceSquaredToPosition()
double CesiumGeometry::OrientedBoundingBox::computeDistanceSquaredToPosition ( const glm::dvec3 & position) const
noexcept
positionThe position
The estimated distance squared from the bounding box to the point.
// Sort bounding boxes from back to front
glm::dvec3 cameraPosition = anyOldCameraPosition();
std::vector<OrientedBoundingBox> boxes = anyOldBoxArray();
std::sort(boxes.begin(), boxes.end(), [&cameraPosition](auto& a, auto& b) {
return a.computeDistanceSquaredToPosition(cameraPosition) >
b.computeDistanceSquaredToPosition(cameraPosition);
◆ contains()
bool CesiumGeometry::OrientedBoundingBox::contains ( const glm::dvec3 & position) const
noexcept
positionThe position.
Whether the position is contained within the bounding box.
◆ getCenter()
const glm::dvec3 & CesiumGeometry::OrientedBoundingBox::getCenter ( ) const
inlineconstexprnoexcept
Definition at line 49 of file OrientedBoundingBox.h.
◆ getHalfAxes()
const glm::dmat3 & CesiumGeometry::OrientedBoundingBox::getHalfAxes ( ) const
Definition at line 58 of file OrientedBoundingBox.h.
◆ getInverseHalfAxes()
const glm::dmat3 & CesiumGeometry::OrientedBoundingBox::getInverseHalfAxes ( ) const
Definition at line 66 of file OrientedBoundingBox.h.
◆ getLengths()
const glm::dvec3 & CesiumGeometry::OrientedBoundingBox::getLengths ( ) const
Definition at line 73 of file OrientedBoundingBox.h.
◆ intersectPlane()
CullingResult CesiumGeometry::OrientedBoundingBox::intersectPlane ( const Plane & plane) const
noexcept
planeThe plane to test against.
◆ transform()
OrientedBoundingBox CesiumGeometry::OrientedBoundingBox::transform ( const glm::dmat4 & transformation) const
noexcept
transformationThe transformation.
The oriented bounding box in the new coordinate system.
