cesium-native 0.67.0
Options for configuring the parsing the contents of a Tileset, including construction of its glTF models. More...
#include <Cesium3DTilesSelection/TilesetContentOptions.h>
| CesiumGltfReader::GltfReaderOptions | toGltfReaderOptions () const |
| Extracts options related to loading glTFs to a new instance of CesiumGltfReader::GltfReaderOptions . | |
| bool | enableWaterMask = false |
| Whether to include a water mask within the Gltf extras. | |
| bool | generateMissingNormalsSmooth = false |
| Whether to generate smooth normals when normals are missing in the original Gltf. | |
| CesiumImage::Ktx2TranscodeTargets | ktx2TranscodeTargets |
| For each possible input transmission format, this struct names the ideal target gpu-compressed pixel format to transcode to. | |
| bool | applyTextureTransform = true |
Whether or not to transform texture coordinates during load when textures have the KHR_texture_transform extension. Set this to false if texture coordinates will be transformed another way, such as in a vertex shader. | |
| CesiumGltfReader::MeshPrimitiveModeOptions | primitiveModeOptions |
| Options for handling values of CesiumGltf::MeshPrimitive::Mode that appear in a glTF mesh primitive. | |
| CesiumGltfReader::SpzDecoderOptions | spzDecoderOptions |
| Options for decoding SPZ data within glTFs. | |
Definition at line 13 of file TilesetContentOptions.h.
| bool Cesium3DTilesSelection::TilesetContentOptions::applyTextureTransform = true |
Definition at line 46 of file TilesetContentOptions.h.
| bool Cesium3DTilesSelection::TilesetContentOptions::enableWaterMask = false |
Currently only applicable for quantized-mesh tilesets that support the water mask extension.
Definition at line 20 of file TilesetContentOptions.h.
| bool Cesium3DTilesSelection::TilesetContentOptions::generateMissingNormalsSmooth = false |
According to the Gltf spec: "When normals are not specified, client implementations should calculate flat normals." However, calculating flat normals requires duplicating vertices. This option allows the gltfs to be sent with explicit smooth normals when the original gltf was missing normals.
Definition at line 32 of file TilesetContentOptions.h.
| CesiumImage::Ktx2TranscodeTargets Cesium3DTilesSelection::TilesetContentOptions::ktx2TranscodeTargets |
Definition at line 38 of file TilesetContentOptions.h.
| CesiumGltfReader::MeshPrimitiveModeOptions Cesium3DTilesSelection::TilesetContentOptions::primitiveModeOptions |
Definition at line 52 of file TilesetContentOptions.h.
| CesiumGltfReader::SpzDecoderOptions Cesium3DTilesSelection::TilesetContentOptions::spzDecoderOptions |
Definition at line 57 of file TilesetContentOptions.h.
