Cesium3DTilesSelection::EllipsoidTilesetLoader Class Reference
A loader that will generate a tileset by tesselating the surface of an ellipsoid, producing a simple globe tileset without any terrain features. More...
#include <Cesium3DTilesSelection/EllipsoidTilesetLoader.h>
Inheritance diagram for Cesium3DTilesSelection::EllipsoidTilesetLoader:
Cesium3DTilesSelection::TilesetContentLoader Cesium3DTilesSelection::ITilesetHeightSampler
 EllipsoidTilesetLoader (const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
CesiumAsync::Future< TileLoadResult > loadTileContent (const TileLoadInput &input) override
 Load the tile content.
TileChildrenResult createTileChildren (const Tile &tile, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) override
 Create the tile's children.
ITilesetHeightSampler * getHeightSampler () override
 Gets an interface that can be used to efficiently query heights from this tileset.
CesiumAsync::Future< SampleHeightResult > sampleHeights (const CesiumAsync::AsyncSystem &asyncSystem, std::vector< CesiumGeospatial::Cartographic > &&positions) override
 Queries the heights at a list of locations.
- Public Member Functions inherited from Cesium3DTilesSelection::TilesetContentLoader
virtual ~TilesetContentLoader ()=default
 Default virtual destructor.
const TilesetContentManager * getOwner () const noexcept
 Gets the TilesetContentManager that owns this loader.
TilesetContentManager * getOwner () noexcept
void setOwner (TilesetContentManager &owner) noexcept
 Sets the TilesetContentManager that owns this loader.
virtual void setExternalSchema (CesiumGltf::Schema *schema)
 Store a glTF schema object that will be used to parse metadata in a loader and its children.
virtual CesiumUtility::IntrusivePointer< CesiumGltf::Schema > getExternalSchema ()
 Get the external glTF schema object.
static std::unique_ptr< Tileset > createTileset (const TilesetExternals &externals, const TilesetOptions &options=TilesetOptions{})
 Creates a new tileset with this loader.
Additional Inherited Members
- Protected Member Functions inherited from Cesium3DTilesSelection::TilesetContentLoader
virtual void setOwnerOfNestedLoaders (TilesetContentManager &owner) noexcept
 Called by setOwner to allow the loader to apply the new owner to any loaders that are aggregated by this one.
Definition at line 12 of file EllipsoidTilesetLoader.h.
◆ EllipsoidTilesetLoader()
Cesium3DTilesSelection::EllipsoidTilesetLoader::EllipsoidTilesetLoader ( const CesiumGeospatial::Ellipsoid & ellipsoid = CesiumGeospatial::Ellipsoid::WGS84)
◆ createTileChildren()
TileChildrenResult Cesium3DTilesSelection::EllipsoidTilesetLoader::createTileChildren ( const Tile & tile,
overridevirtual
Note that: when receiving RetryLater status, client needs to load this tile's content first or its parent's content. The reason is that some tileset formats store the tile's children along with its content or store a whole subtree for every n-th level tile (e.g Quantized Mesh format). So unless the tile's content or the root tile of the subtree the tile is in is loaded, the loader won't know how to create the tile's children.
tileThe tile to create children for.
The TileChildrenResult that stores the tile's children
Implements Cesium3DTilesSelection::TilesetContentLoader.
◆ createTileset()
static std::unique_ptr< Tileset > Cesium3DTilesSelection::EllipsoidTilesetLoader::createTileset ( const TilesetExternals & externals,
const TilesetOptions & options = TilesetOptions{} )
static
externalsThe external interfaces to use.
optionsAdditional options for the tileset.
◆ getHeightSampler()
ITilesetHeightSampler * Cesium3DTilesSelection::EllipsoidTilesetLoader::getHeightSampler ( )
overridevirtual
Some loaders may be able to query heights very efficiently by using a web service or by using an analytical model, e.g., when the "terrain" is a simple ellipsoid.
For loaders that have no particular way to query heights, this method will return nullptr, signaling that heights should be computed by downloading and sampling individual tiles.
The interface that can be used to efficiently query heights from this loader, or nullptr if this loader has no particular way to do that. The returned instance must have a lifetime that is at least as long as the loader itself.
Reimplemented from Cesium3DTilesSelection::TilesetContentLoader.
◆ loadTileContent()
CesiumAsync::Future< TileLoadResult > Cesium3DTilesSelection::EllipsoidTilesetLoader::loadTileContent ( const TileLoadInput & input)
overridevirtual
inputThe TileLoadInput that has the tile info and loading systems to load this tile's content
The future of TileLoadResult that stores the tile's content
◆ sampleHeights()
CesiumAsync::Future< SampleHeightResult > Cesium3DTilesSelection::EllipsoidTilesetLoader::sampleHeights ( const CesiumAsync::AsyncSystem & asyncSystem,
std::vector< CesiumGeospatial::Cartographic > && positions )
overridevirtual
asyncSystemThe async system used to do work in threads.
positionsThe positions at which to query heights. The height field of each CesiumGeospatial::Cartographic is ignored.
A future that will be resolved when the heights have been queried.
Implements Cesium3DTilesSelection::ITilesetHeightSampler.
