Cesium3DTiles Namespace Reference
Classes for using 3D Tiles. More...
Classes
struct  Asset
 Metadata about the entire tileset. More...
struct  Availability
 An object describing the availability of a set of elements. More...
struct  BoundingVolume
 A bounding volume that encloses a tile or its content. At least one bounding volume property is required. Bounding volumes include box, region, or sphere. More...
struct  Buffer
 This class is not meant to be instantiated directly. Use Buffer instead. More...
struct  BufferCesium
 Holds Buffer properties that are specific to the 3D Tiles loader rather than part of the 3D Tiles spec. More...
struct  BufferSpec
 A buffer is a binary blob. It is either the binary chunk of the subtree file, or an external buffer referenced by a URI. More...
struct  BufferView
 A contiguous subset of a buffer. More...
struct  Class
 A class containing a set of properties. More...
struct  ClassProperty
 A single property of a metadata class. More...
struct  ClassStatistics
 Statistics about entities that conform to a class that was defined in a metadata schema. More...
struct  ConditionalContent
 Defines the structure of 3D Tiles content for the 3DTILES_content_conditional extension. More...
struct  ConditionalContentItem
 Defines the structure of a single content item in 3DTILES_content_conditional. More...
struct  Content
 Metadata about the tile's content and a link to the content. More...
struct  Enum
 An object defining the values of an enum. More...
struct  EnumValue
 An enum value. More...
struct  Extension3dTilesBoundingVolumeCylinder
 3D Tiles extension for cylinder region bounding volumes. More...
struct  Extension3dTilesBoundingVolumeS2
 3D Tiles extension for S2 bounding volumes. More...
struct  Extension3dTilesContentConditional
 Defines the structure of the extension object that is stored as the 3DTILES_content_conditional extension in a tileset JSON, and that summarizes the conditions that appear in the contents. More...
struct  Extension3dTilesContentConditionalDimensionsValue
 Extension3dTilesContentConditional Dimensions Value. More...
struct  Extension3dTilesEllipsoid
 3DTILES_ellipsoid extension data to define the referenced ellipsoid More...
struct  ExtensionContent3dTilesContentVoxels
 Voxel content type. More...
struct  ExtensionMetadataEntityMaxarContentGeoJson
 Enables loading optional metadata schema for GeoJSON properties. More...
struct  ExtensionSchemaMaxarContentGeoJson
 External metadata schema that describes the structure and validation rules for properties found in GeoJSON features within 3D Tiles content. This schema defines the expected property names, data types, constraints, and semantics that should be present in the 'properties' object of GeoJSON Feature objects. More...
struct  ExtensionSchemaMaxarContentGeoJsonGeometryValue
 ExtensionSchemaMaxarContentGeoJson Geometry Value. More...
struct  ExtensionSchemaMaxarContentGeoJsonPropertiesValue
 ExtensionSchemaMaxarContentGeoJson Properties Value. More...
struct  ExtensionTilesetMaxarContentGeoJson
 Enables loading GeoJSON content in 3D Tiles. This extension is declared at the tileset level to enable the use of GeoJSON content and optional properties metadata schemas in metadata entities. More...
struct  FoundMetadataProperty
 Holds the details of a found property in a MetadataEntity. More...
struct  GroupMetadata
 An object containing metadata about a group. More...
struct  ImplicitTiling
 This object allows a tile to be implicitly subdivided. Tile and content availability and metadata is stored in subtrees which are referenced externally. More...
struct  MetadataEntity
 An object containing a reference to a class from a metadata schema, and property values that conform to the properties of that class. More...
class  MetadataQuery
 Convenience functions for querying MetadataEntity instances. More...
struct  Padding
 The padding property specifies how many rows of attribute data in each dimension come from neighboring grids. More...
struct  Properties
 A dictionary object of metadata about per-feature properties. More...
struct  PropertyStatistics
 Statistics about property values. More...
struct  PropertyTable
 Properties conforming to a class, organized as property values stored in binary columnar arrays. More...
struct  PropertyTableProperty
 An array of binary property values. This represents one column of a property table, and contains one value of a certain property for each metadata entity. More...
struct  Schema
 An object defining classes and enums. More...
struct  Statistics
 Statistics about entities. More...
struct  Subtree
 An object describing the availability of tiles and content in a subtree, as well as availability of children subtrees. May also store metadata for available tiles and content. More...
struct  Subtrees
 An object describing the location of subtree files. More...
struct  Tile
 A tile in a 3D Tiles tileset. More...
struct  Tileset
 This class is not meant to be instantiated directly. Use Tileset instead. More...
struct  TilesetSpec
 A 3D Tiles tileset. More...
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: Cesium3DTiles Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px Cesium3DTiles[Cesium3DTiles] --> CesiumUtility[CesiumUtility] class CesiumUtility,Cesium3DTiles libraryNode
