A dictionary object of metadata about per-feature properties. More...
#include <Cesium3DTiles/Properties.h>
| double | maximum = double() |
| The maximum value of this property of all the features in the tileset. The maximum value shall not be smaller than the minimum value. | |
| double | minimum = double() |
| The minimum value of this property of all the features in the tileset. The maximum value shall not be smaller than the minimum value. | |
| static constexpr const char * | TypeName = "Properties" |
Definition at line 12 of file Properties.h.
Definition at line 37 of file Properties.h.
| double Cesium3DTiles::Properties::maximum = double() |
Definition at line 23 of file Properties.h.
| double Cesium3DTiles::Properties::minimum = double() |
Definition at line 29 of file Properties.h.
Definition at line 17 of file Properties.h.
